complex
07-13-2004, 05:58 PM
GTRay,, this is what i ended up with..........
I didnt make it but i had input in the design, how did it turn out??
I wanna add a neon light in there, what do you guys recomend?
Why is this the forum going so slow?!
complex
07-14-2004, 05:34 PM
DAMNIT!I guess, since i didnt follow the trend of putting the sub in the pass thru opening i get 93 reads and no replys!!!!!!!!!
snowrydr01
07-14-2004, 06:04 PM
haha yeah too many people are killing the function of the pass through, ill give you props about the rotor cut out buddy, i REALY like the fans to keep it cool under the cover too. Did you dynamat the trunk, have you noticed any rattle with the rear facing sub?
mikeb
07-14-2004, 06:36 PM
that is real unique
I like it
very clean
well done
complex
07-14-2004, 09:26 PM
yup the rotor cut out was a last minute idea....no dynamat yet, some rattle heard from outside the car.....final step is to put a neon cable around the rotor and fans.thanks for the pity replys. :confused:
snowrydr01
07-14-2004, 10:18 PM
haha pitty replys eyy thats funny. have you tried to fire your sub forward, did that reduce the rattle?
DreamWarrior
08-05-2004, 03:55 PM
Are those the amp's fans or did you mount those? Just curious, can't make out the AMP brand and I'm not familiar with the logo.
Looks good though! I would have made the box a little less...a box and tried to form fit it, but other than that, great idea!
complex
08-05-2004, 10:48 PM
mounted those fans because the amp heating up and shutting off after a while.........that was the whole idea behind it.Its a Autotek SX-5750, perfect in all ways but one.What do you mean by "a little less...a box and tried to form fit it" i dont get it.
DreamWarrior
08-11-2004, 02:17 PM
From the pictures the speaker box has lots of extra room on both sides which make it look like it was just set into the trunk. I'd have form fitted it so that it looked flush mounted against the rear wall of the trunk. However, that would have sucked up more trunk room.
09Factor
08-16-2004, 12:37 AM
I dig the Wolvie fan grills ! X-men wing in the works ?
