High Rev Beep
Old Jul 11, 2004 | 11:53 AM
billytkid's Avatar
High Rev Beep
Hi Ive searched the forums and couldnt find the answer - so here is another question!
While test driving yesterday I took the revs to the max - but no warning beep :@(
Is this usual with the UK cars, or has anyone in the UK heard the beep?
Please dont say this is just the US that have it
I WANT BEEP IN MY CAR!!
Old Jul 11, 2004 | 12:39 PM
wakeech's Avatar
mostly harmless
no they all have it. it is quite quiet (radio off, windows up, not talking), and it's more of a high pitched electronic tone than a "beep".
try it when merging onto the freeway (in 1st or 2nd gear), and you'll hear it. 8500rpm and up.
Old Jul 11, 2004 | 01:05 PM
Nemesis8's Avatar
Bigus Rotus
Is there a way to turn up it's volume
Old Jul 11, 2004 | 01:34 PM
poolsidenaz's Avatar
I heard my twice yesterday :D Even with the radio on, but not blasting.
Old Jul 11, 2004 | 01:37 PM
StealthTL's Avatar
Metatron
beep...BEEEP!
It is fairly easy to get at, the buzzer is mounted on the back of the gauges.
I tried to run wires out to an aux buzzer (Sonalert) with no luck, the signal is weak, it is grounded to produce tone, and if you ground it yourself it buzzes all the time.
It would take an electronic-type-guy to come up with some kind of relay circuit - way beyond my pitiful skills........(but I WOULD buy one - hint, hint!) :p
S
Old Jul 11, 2004 | 01:44 PM
thew's Avatar
Thews8
you could go to Radio shack buy a small lapel mic and tape it to the buzzer. then run the mic into your drivers side speaker. this will take a little work but that way you could have your own volum **** to.. However.. its not really that important. the rev limiter kicks in at around 9k so you cant over rev it. Once you learn the shifting curve the silly shift chime will annoy you
Shankapotamus3
Mar 14, 2021 03:53 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
garryg
Australia/New Zealand Forum
Oct 1, 2015 04:54 PM
Jb4ker96
Sep 27, 2015 10:06 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
