Gulf RX-8 Forum Serving TX, OK, AR, LA, MS
warm interior - any Texas folks get the extra insulation?
Old Jul 10, 2004 | 04:59 PM
brillo's Avatar
Go Texas Longhorns!
my a/c seems to work fine, but the car does tend to run a bit hot on the inside area.
I'm going to get the extra insulation put in, has anyone else done this? Did it help?
its not so bad that its really bothersome, but i do notice that i feel like I sweat more through the seats. Just curious, as we live in prolly the warmest climate.
anyone think a larger radiator or other solution might help cool the car down?
Old Jul 10, 2004 | 09:53 PM
DrKillJoY's Avatar
heh.. sounds like a rotary to me!
while I havent owned an 8'... I have found that nearly all rotaries tend to carry extra heat through the transmission tunnel and directly above wherever the exhausst is run... (under the passenger seat in my cars)
Old Jul 11, 2004 | 01:00 AM
brillo's Avatar
Go Texas Longhorns!
i asked this in the general tech forum too, will a higher flow Cat help? Do the stock Cats build up excess heat?
Old Jul 11, 2004 | 08:02 AM
DrKillJoY's Avatar
I don't know if anthing will help.. higher exhaust temps in general are an inherent trait of the rotary.
Old Jul 11, 2004 | 08:56 AM
rev-2-9k's Avatar
Space Cadet
The factory says the engine cover is to keep the hood from warping. A cat is probably a good idea, go check how low your O2 sensor hangs and you will want to replace it just for that. Not to mention this is one part that plays a role in the over rated horsepower fiasco.
Old Jul 12, 2004 | 01:50 AM
MrWigggles's Avatar
My interior got warm the first few days I had the car, but from that point on I have only noticed it a couple times on occasion. Got it last October and just got the A/C amplifier upgrade recently - very nice improvement.
If my car acted like it did the first week I had it, I would be getting the additional insulation, but the way it is right now, I don't think it will be worth it. However, for those upgrading their cat, having the insulation there might help with sound reduction not just heat reduction.
Rev-2-9k, Could you send me a message about what catalytic converter you are using.
-Mr. Wigggles
Old Jul 12, 2004 | 01:05 PM
brillo's Avatar
Go Texas Longhorns!
its seems to have gotten better, it may be that the cat is so new is needs a few hundred miles to breakin?
Old Jul 12, 2004 | 08:35 PM
Papa Smurg's Avatar
Brillo or anyone,
I've had the same problem with my 8. I have had the insulator pad installed; however, the pad has not helped at all. In my opinion it is hotter now. Have you had this same problem? If so have you been able to get it to a normal temperature? I have allowed email response so you can respond or I will check back with this posting.
Old Jul 12, 2004 | 09:41 PM
brillo's Avatar
Go Texas Longhorns!
well, mine has gotten better with time, how new is your car? its been pretty hot here but its not bothering me as much now....my car has about 280 miles on it.
Old Jul 12, 2004 | 09:48 PM
Papa Smurg's Avatar
My car is fairly new. About 4000 miles. Purchased it in April. It's pretty hot here, too. I live in Miami, FL. At night when it is cooler the car is still pretty hot. My Mazda service consulatant so far has told me there is nothing more that they can do. How long ago did you have the heating pad installed? You say it got better with time....
Old Jul 13, 2004 | 11:27 AM
brillo's Avatar
Go Texas Longhorns!
its not installed yet. it just seemed over the weekend that the heat from the center console has lessened somewhat, the cup holders still get warm, but I don't fel like its getting into the cabin as much. I noticed when driving yesterday with no shoes the pedals could get a little warm.
cliffkemp
Dec 24, 2024 10:48 AM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
nferguson88
Oct 6, 2015 12:45 PM
Eliseo Esquivel
Sep 30, 2015 08:28 PM
Tgiolitto100
Sep 29, 2015 10:52 AM
