Any down side to lowering?
Old Jul 9, 2004 | 06:26 AM
cockerchumps's Avatar
I have ordered a set of lowered (25mm) and stiffened springs. Do I need to consider anything else after fittment ? Will tracking etc be affected? Does lowering alter toe in/out or any other things that I know not much about?
C
Old Jul 9, 2004 | 09:42 AM
shelleys_man_06's Avatar
Not anymore
Well, in the general case, altering your suspension is going to change the original settings on your car. After you're done, get an alignment. Are the spring rates fixed on your set or are they progressive? I think if you do a search there's more stuff on this .
Old Jul 9, 2004 | 09:44 AM
Not anymore
If you want to know more, here's a pretty good link on suspensions.
http://www.chris-longhurst.com/carbi...ion_bible.html
I hope it answers any questions you have. Knowledge is power :D!!
Old Jul 9, 2004 | 11:15 AM
Sputnik's Avatar
Yes, you need to get an alignment afterwards. If it's not dropped an extreme amount, drive the car a day or so before getting an alignment, so that everything settles in first.
And when installing springs, tighten the suspension bolts while the car is on it's suspension, not while it's on the jackstands.
---jps
Old Jul 10, 2004 | 03:14 AM
astromer's Avatar
are coil overs for lowering the car as well?
_________________________------------
Tip the world over on its side and everything loose will land in Los Angeles.
body kits andy
Old Jul 10, 2004 | 11:21 AM
Not anymore
body kits andy
Coilovers are a spring and shock assembly in one package. They offer lots of adjustability. For example, JIC's FLT-A2 offers 16-way adjustability, which means you can switch from soft to hard or vice-versa with a turn of the spanner wrench. Tein offers the EDFC, which controls ride height from inside the car (or wherever) through stepper motors. This is much better than physically turning a spanner wrench every time you want to adjust the height. Unfortunately, as far as I'm concerned, Tein only offers the EDFC for its products only. The most interesting suspension is Praxis' air suspension systems. I wrote a thread about it. Try a search. I think it's really interesting, and I would love to try it out on the RX-8 if it ever becomes available (Praxis systems are vehicle-specific). To answer your question, yes coilovers have the ability to lower or raise the ride height.
Old Jul 11, 2004 | 04:29 AM
gr8rx's Avatar
actually tiens edfc is a damping controling system which means you can adjust the pressure inside the shock for a stiffer or a more comfortable ride,( from inside the car)you still have to use a wrench if you want to adjust ride hight unfortunately, edfc is very cool for ride comfort on the highway, or racing at the track cause you can adjust in cabin and dont have to pop the hood and get out, it even has presets so you can adjust while driving if you wish
Old Jul 11, 2004 | 11:18 AM
Not anymore
Oh. Sorry about that :o. Can't you tell I haven't read the specs on the EDFC?
Old Jul 11, 2004 | 02:02 PM
GooOnYou's Avatar
Gig 'em
I've heard that getting stiffer springs without changing the stock struts will place more strain on the struts and might shorten their life.
Old Jul 11, 2004 | 02:18 PM
Not anymore
That's not necessarily true. You can get lowering/stiffer springs, and the stock shocks will not compromise. If you were going to keep your stock shocks, then a softer spring would help in longevity. Of course, too stiff a spring, say 1000 lbm/in, they might cause some serious wear on your shocks.
Old Jul 12, 2004 | 11:58 AM
RX8_Buckeye's Avatar
'O' - 'H' !!! ...
I explained (from an engineering standpoint) in an old thread why I thought it was possible that OEM shock life could be reduced by installing stiffer springs.
https://www.rx8club.com/showthread.p...9&page=2&pp=15
(2nd page near the bottom)
Basically, stiffer springs reduce the damping ratio of the vehicle bounce mode, thus the OEM shocks will experience more cycles during a given amount of driving. Every suspension component has a certain fatigue life, or number of cycles until failure. Therefore, life will be shortened if cycles accumulate at a faster rate.
However, the decrease in life could be insignificant. I don't claim to have even a rough idea of how much the life of the shocks could be shortened.
Old Jul 13, 2004 | 10:53 PM
Fanman's Avatar
I have seen some springs that adjust from .5" (Racing Beat) to 1.0-1.5" (H&R, Eibach). I got the RB's. A 1.5" drop scares me as I have seem some kids get 1.5"-2.0" drops and their cars handled like garbage around the track. and on the strret. It was as if the springs were made out of inferior material. The ride got bouncy (and the fenderlip hit the tires on bumps) and the handling got compromised.
Old Jul 13, 2004 | 11:41 PM
Not anymore
The harsh ride could be from cutting the bumpstops. It doesn't always have to be the material of the spring. Stiffer springs means a harsher ride. The point is not to select the ride height, but the stiffness of the spring, though the former is important for lowering the center of gravity.
mitchrx8
Sep 13, 2015 08:05 AM
Tsurugi
Sep 7, 2015 08:27 PM
PTQLam
Sep 5, 2015 01:14 PM
blkswan
Sep 2, 2015 10:04 PM
