the8freak
07-04-2004, 11:40 AM
is this a good combination? does anyone have any better suggestions or comments on this?
2x jl 10w7's
HiFonics Brutus 1ch 1000w amp
2x jl 10w7's
View Full Version : sub/amp question, real quick the8freak 07-04-2004, 11:40 AM is this a good combination? does anyone have any better suggestions or comments on this? 2x jl 10w7's HiFonics Brutus 1ch 1000w amp bassoon811 07-22-2004, 08:28 PM since you havent gotten any replys i like the subs but i never liked mixing subs with different amps, if your gonna spring for w7's you should get jl amps. I think the 10 can take 500 watts so i would get two 500/1. HardHitter 07-24-2004, 03:09 AM The 10W7's can take around 1000W RMS, 12W7's can take around 1500W RMS, 13.5W7's can take around 2000W RMS. JL has their subs underrated in power, if you know what you're doing they'll take the power and laugh at you. I have 750W to my 12W7 and it's barelly moving. Two 10's will be a 1.5ohm level so you'll need to get an amp that puts out around 1800W @ 1.5 ohms giving each 10W7 around 750W. Port the suckers and you'll be set. Good luck, if you need anything just contact me. I've been in car audio for a long time and I build/install stuff on my own. You can check out my sounddomain page at www.sounddomain.com/id/hardhitter2k3 Good luck! abbid 07-24-2004, 11:20 AM my friend has 2 10w7s in his eclipse mated with 2 500/1s. each sub gets its own. The installers at first told him he needs only 1000watts total, so they sold him one amp and they bridged it wrong and blew his amp for him. Needless to say he got those 2 500/1s for 250 dollars for a pair. P.S i dont know if you want that much bass, when there is that much bass, everything starts to fall apart eventually. just my 2 cents |
