Aug. Sport Compact Car - Tien EDFC (Electronic Damping Force Controller)
Old Jul 3, 2004 | 08:16 PM
brillo's Avatar
Go Texas Longhorns!
Looks like Tien has this EDFC (Electronic Damping Force Controller) kit out for the 8 in Japan, according to the article in the Aug Sport Compact car (its was on a white 8), its a computer controled suspension that can be adjusted from inside the car to various conditions.
This is really cool, here is the website, although the 8 isn't listed yet. Hopefully this will be out soon.
http://www.tein.com/edfc.html
Old Jul 4, 2004 | 08:32 PM
shelleys_man_06's Avatar
Not anymore
The EDFC has been out for a while, for other cars. It's an intersting device, and I would like to see what kind of flexibility it would have on an RX-8.
Old Jul 4, 2004 | 11:06 PM
Kel Rx8's Avatar
if your not 1st your last
im assuming it will be $2500.00 or so ??
Old Jul 5, 2004 | 06:18 PM
cuscorex's Avatar
爆 走 RE风 林 火 山
the coilovers is actualli available for awhile in our local mkt.but they are onli compatible on Type Flex & Super Street.both models are comfort-street used thou.hardcore track fans might find it 'not enuff' even @ the 'hardest' settings
Old Jul 7, 2004 | 03:30 PM
bassik277's Avatar
From what I've heard from many Tein users, the Flex coilovers are plenty stiff enough at its stiffest for hardcore track use, and are comparable in terms of dampening to the HKS hypermax, and JIC's, and I've heard that they are more durable then JIC coilovers.
Old Jul 7, 2004 | 04:16 PM
Not anymore
Are there any non-JDM companies that sell coilover shocks for the RX-8? Also, the EDFC is only compatible with Tein products, no?
Old Jul 7, 2004 | 05:28 PM
bassik277's Avatar
As of now, I dont believe that there are any non-jdm coilover manufacturers, although there are many non-jdm springs available, as well as struts and sways, but no shocks. Yes the EDFC is only compatible with Tein Products, (a marketing strategy).
Old Jan 5, 2007 | 07:44 AM
goldwave84's Avatar
So, on the softest setting, is it actually softer than stock rx8 ride? I find this very interesting...
Old Jan 5, 2007 | 10:19 AM
Red Devil's Avatar
I have the Flex coilovers. Can't say I think they're softer than the OEM ride. But they are definitely daily driveable.
Old Jan 5, 2007 | 12:47 PM
goldwave84's Avatar
Red devil, you can control them from inside your car right?
Old Jan 5, 2007 | 01:17 PM
Red Devil's Avatar
I didn't opt for the EDFC, so personally no. But with the Tein Flex, yes you can adjust the dampers from inside the car.
Just to clarify, as sometimes some get confused, you cannot adjust ride height with the EDFC, just dampening. If you want to change your ride height, you need to remove and adjust each coilover assembly.
Old Jan 5, 2007 | 02:16 PM
goldwave84's Avatar
Well, I have seen one or 2 companies which give you up to 18 settings that you can control. With those 18 settings, do you think the lowest would be softer than the stock car?
Its funny you mentioned that you cannot adjust ride height. I am wondering, is there anything out there that can help lower/raise you car with a touch of a button? Just curious...
Old Jan 5, 2007 | 02:30 PM
Old Jan 5, 2007 | 04:01 PM
Red Devil's Avatar
I have no idea what you're looking for, so I'm just going to suggest you search.
Take the Tein Flex for what it is. Just a very basic coilover. Not much about them is high tech, if anything. Even the dampening adjustability is nothing spectacular as it's one dimensional. But it does let you play around a little bit. Since I daily drive my RX-8, I don't need to put on something like a Koni28, but I also didn't just want springs.
Old Jan 5, 2007 | 05:36 PM
RoXanneBlack8's Avatar
stop flooding ur engines
i have type flex and the edfc and ill tell u right now dont buy into the "soft" and "hard" wording....
the edfc on its "softest" is still brutally stiffer than stock.
damping force will change only so much of the ride....remember the front of this thing has 500lb springs. thats over double the stiffness of stock, ease the tension on the damper all u want and the springs will still knock out teeth
ps many companies brag about the # of setting they can change on the dampers, tein has 32 settings. its technically 16 settings bc they use "half" turns to get the #'s in between......(eg...a numer 19 setting is actually the number between 9 and 10 in the '16' mode) it allows a more precise adjustment. but in all honesty on the street 9,10, and 11 all feel the same. but 00 and 16 are worlds apart....maybe its just me but on setting 16 i feel it handles the best
Old Jan 5, 2007 | 10:10 PM
goldwave84's Avatar
Yes, you make very good points. Alright, when I get some good info, Ill post it up.
F51
Aug 2, 2021 04:07 AM
Dokuji
Nov 1, 2016 02:51 PM
rotorocks
47
May 11, 2016 03:23 PM
AussieGray
Jul 16, 2015 03:58 AM
04MazdaMan
Jul 15, 2015 08:23 PM
