RX-8 to use a 9.3" clutch
Old Mar 15, 2003 | 04:36 PM
MrWigggles's Avatar
Mazda now shows the clutch to be:
"Single Dry Plate (236 x 160)"
I don't know what the second number means but the 236 mm translates into 9.3". With 236 as the outer diameter, the 160 might be the inner diameter.
Interestingly, 236mm I believe was the clutch size of the FD RX-7.
It is a good sized clutch for only 159 lb-ft of torque.
-Mr. Wigggles
drebbrnator
Dec 27, 2018 07:02 PM
BigMikeATL
May 26, 2016 12:31 AM
rotorocks
47
May 11, 2016 03:23 PM
EfrainOlivares
Aug 14, 2015 06:17 PM
