Drop in filter
Old Jul 2, 2004 | 10:15 AM
otrovago's Avatar
Drop in filter
Which drop in filter should one go with?
Racing Beat
Greenfilter
K&N Dorp in (couldn't find a link )
Mazdaspeed Drop in (coulnd't find a link )
Old Jul 2, 2004 | 01:16 PM
psionic1's Avatar
I just got a Green drop in, and the car seems to breathe easier. It's the first time that I have used a drop in, but after all the reading, and "Searching" in these forums, the Green seemed to be the best way to go...
Old Jul 2, 2004 | 01:25 PM
Fanman's Avatar
Get the Afe/Racing Beat Drop In. It seems the best. You can get a Mazdaspeed air filter in Canzoomers. It is $$$$.
Old Jul 3, 2004 | 10:22 AM
djantlive's Avatar
they dont really do much to add hp. maybe 2 hp and not noticeable. nice thing is they are reuseable which is easy on the wallet if you can wait for the washed filter to dry before you put back in.
Old Jul 3, 2004 | 12:18 PM
cas2themoe's Avatar
PoloRican Rotary
How about the K&N Typhoon Kit? It's saying 9.5 HP increase with the manual, that would be a cheap upgrade for basically 10 HP. But are you looking just for a drop in?
Old Jul 3, 2004 | 12:24 PM
mysql101's Avatar
Who is claiming close to 10 hp with the k&n? You can barely even do that with a straight pipe and a tuned exhaust.
Old Jul 3, 2004 | 12:30 PM
thew's Avatar
Thews8
green in my 8 makes a bigger diffrance in Sound. more throatie intake sound. as far as hp .. non noticed but it does sound like its purring when you step on it
Old Jul 3, 2004 | 02:03 PM
cas2themoe's Avatar
PoloRican Rotary
This is off of their website................ http://www.knfilterchargers.com/sear...Prod=69-6030TB
Old Jul 3, 2004 | 04:30 PM
StphNieuw's Avatar
I had a K&N filter in my previous Protégé and I really didn't notice the benefit, besides that it sounded better and revved a little smoother, most likely due to my other filter being dirty. I did see that on the link provided above there was a 10 degree difference in temperature which could explain the horsepower gains. In modern cars, such as the RX-8 you really will not get much more power out of an intake unless you upgrade the ECU, intake, and exhaust and even then the results aren’t that phenomenal. I once read that you really won't feel a difference until you get an additional 20HP.
Old Jul 3, 2004 | 05:48 PM
cas2themoe's Avatar
PoloRican Rotary
You could have a point there, maybe they should have tested it on the same day. Never even noticed that, but that would be great if it really did give us a extra 9.5 HP.
Old Jul 3, 2004 | 09:01 PM
mlino01's Avatar
I run Green and love it high quality build to Go Green!
Old Jul 3, 2004 | 11:40 PM
Fanman's Avatar
Many people have the K&N and there is no way it adds 10 hp, and the only noticeable difference was on the high end, and it made quite a bit of noise. It also cause CEL & rough idle in some of the RX8'ers on this board.
Old Jul 3, 2004 | 11:56 PM
DjGO's Avatar
i can quote you on that i have to send it back for my money back.
Old Jul 5, 2004 | 08:18 PM
otrovago's Avatar
since, I've decided to go with the racing beat exhaust, I'm probly gona go with their drop in filter.... Even do I'm buying a green filter for my wife's montero. I've read very good things about the green filter. I don't really have any info for the RB drop in but I've heard and read very good things about their other aftermarket parts..:D
Old Aug 6, 2004 | 03:29 PM
mysql101's Avatar
I installed the green filter today.
I don't notice any change in exhaust note (with borla), and I don't notice any gains by my butt dyno.
On the other hand, if the green filter made my exhaust louder, I would be tempted to remove it from the car.
Old Aug 6, 2004 | 03:51 PM
Norseman's Avatar
I've owned many cars over the years, and always been able to change my own air filters. But I'll be darned if the instructions in the Owner's Manual work. Unhooked the flamin clips, detached the electrical connector (that's another bugger to get off) and tried to "lift" off the air filter cover. Who is Mazda kidding? All right, those of you who have done it successfully, how do you REALLY get the danged cover off? Thanks.
Old Aug 6, 2004 | 03:57 PM
mysql101's Avatar
I unscrewed the big rubber hose that the top of the air filter box connects to. I then unhooked the two clips, and was able to push the opening enough to slip the old filter out.
The green filter is much thinner, and was able to get in without too much trouble.
Earlier today, I was in the same situation as you, I didn't see how to get the damn thing out properly, and came here to search the boards. No luck, so I winged it.
Old Aug 6, 2004 | 09:13 PM
Japan8's Avatar
Int'l Man of Mystery
K&N and RB... or at least RB says it does make more horsepower (sound like more than 3 or 4 they rated the cat-back), but as they said.... 100db at WOT. A loud piece of equipment...
Old Aug 6, 2004 | 09:24 PM
Nemesis8's Avatar
Bigus Rotus
AFE from RB for me - nice quality.
Old Aug 7, 2004 | 12:08 AM
mdawgx24's Avatar
I have the green filter. I like it, though I'm not sure I would say it gives a throatier tone -- I thought it made the engine sound cleaner -- you know, as if it's breathing easier. No really noticeable power gains, but it all adds up.
Old Aug 7, 2004 | 12:18 AM
cortc's Avatar
MS Drop-in = better throttle response (Maybe 2hp)...
Old Aug 7, 2004 | 12:38 AM
REXNdBst's Avatar
With an NA car don't expect to gain too much power to the wheels with intakes or exhaust.
Old Aug 8, 2004 | 02:18 AM
Mikelikes2drive's Avatar
I have the MS drop in filter and it makes a noticeable difference in throttle response. I mean its not huge but you can tell... it also makes my exhaust sound better... it breathes easier. I really like it. I recommend it if you wanna drop the extra cash
Old Aug 8, 2004 | 03:08 AM
thew's Avatar
Thews8
Greeeeeeeeennnnnnnnn
Old Aug 9, 2004 | 12:09 PM
otrovago's Avatar
hmm, I installed the RB filter, and it's louder than stock, you can hear it at hi-revs. No change in power that I can feel do...
