m flash with cz unit ok?
Old Jul 1, 2004 | 07:43 PM
jaehyun127's Avatar
Today, i had the CZ 1.1 mod in, and went to the dealer for a 5k service... I don't think the Mazda service station realized the unit was in because i forgot to turn it off...
Well, i got the MSP04 (i think that is the m-flash) done today with the CZ 1.1 unit installed...
Is that oK?
I am asking because i know the cz unit reads and learns the ecu, but not sure if the unit is ok if it is reflashed with the unit still on...
can someone help me on this??
I have yet to drive it because my keys JDM key is being programmed.
Old Jul 1, 2004 | 09:33 PM
RX-8 friend's Avatar
It'll be fine. Our unit is only actually connected to TPS, MAF, and the ignition outputs. None of those has anything to do with the programming signals. You will probably want to get the latest map in the Canzoomer unit. You will need the programming cable and program to put it in yourself. The latest maps are optimized for the "M" flash. If your unit is fairly new, it will be set up for the "M" flash (from May 5 and on). There is a new map out that is, of course, better . It was done last week.
olyrx7
Oct 26, 2015 09:23 AM
ShellDude
Oct 1, 2015 09:55 PM
Stubbs
Sep 27, 2015 04:06 PM
Forevermore
Sep 20, 2015 01:04 PM
mattymack
Sep 6, 2015 10:33 PM
