Tigerfootball
07-01-2004, 07:24 PM
I need some help. I got my 8 a few weeks ago and i got two tens and a 600 watt amp. it isn't alot but it will do for now. What i need is some ideas to help me put these in the trunk with a custom style and still keep as much trunk space as possible. I have seen a few on this website and am HIGHLY impressed. Can anyone give me some pics or ideas so i can get some clue about what i want to do? Thanks a lot.
snowrydr01
07-01-2004, 08:37 PM
heres an idea that im using for mine but have not yet built. Mount the amp in the little storage square with an amp cover to hide it. mount the two subs indepentantly of each other forward facing behind the backseat so you can keep your fold down center piece to store larger objects through it
Tigerfootball
07-01-2004, 09:50 PM
That sounds like a good idea. I have about the same idea for the amp, except i am trying to use plexiglass over the storage square. Thanks. I am open to any suggestions.
devoid
07-02-2004, 01:35 PM
I'm looking at doing the same thing, somewhat. I'll be fitting 3 amps in the bottom storage area, with plexiglass and neon's. I'll only have one JL 13" W6v2. I'm gonna have a custom box built on the right side behind the wheel well. You could do the same, one on each side, behind the wheel wells. Just an option....
Bill Ivey
07-02-2004, 05:47 PM
Check ouot 16psibrick
May be what you need.
