RX-8-601
06-30-2004, 07:39 PM
Hello everyone, this is my first post and first question...
Where are my 8th and 9th speakers? I have searched for any messages about this but can't find the answer.
I know there are 2 in each door (x 2 doors), one in the middle of the dash and 2 behind the back seats (at least I cant find more than 2).
According to the info I have read there are supposed to be 9 with the Bose System. Have I been mis-informed?
RaideRX8
06-30-2004, 08:43 PM
I think there are supposed to be two 2-inch mid/high range and two 6x9 woofers on the rear deck. I have not really looked to see if it is discernable though.
insomniak101
07-01-2004, 12:07 AM
i have bose - in the front i center (1)
(2) on the left front door
(2) on the right fornt door
(2) in the back
total 7 can't find 8 and 9
noahprtlnd
07-01-2004, 02:10 AM
This is correct. The tweaters in the back are integrated with the woofers, making 4 speakers total in the back.
RX-8-601
07-01-2004, 03:54 PM
Thanks everyone, that was bothering me for some reason.
rotarygod
07-01-2004, 05:14 PM
There are the obvious 6X9's that you can actually see that are mounted in the rear deck sheet metal. The tweeters are on the outside corners of the rear deck mounted directly to the factory plastic rear deck panel but above the metal decklid. They do not protrude through the sheetmetal into the trunk which is why you can't see them. They are not integrated into the 6X9's. They do fire through the same large grille openings in the plastic panel that the 6X9's do. That is a huge looking grille on each side. There is plenty of room.
