Here is how much heat affects performance in the RX8
Old Jun 23, 2004 | 09:16 AM
Velocity-8's Avatar
Whuumpha!!
In April I ran my 8 at the dragstrip and got a 14.8. The temp was 54 and low humidity. I ran again last night to test the CZ1.
My best run WITH the CZ1 was a 15.2. The temp was 107 and 100% humidity. I did some runs with the CZ1 turned off and got a 15.4.
My 60' were all very similar so I think this shows fairly accurately how the heat affects performance.
Anyway, I thought you guys would find this interesting. Here are the slips...
April run (car 202)
Last night...
Old Jun 23, 2004 | 09:19 AM
RobDickinson's Avatar
Heat will affect performance for sure.
You should be able to counter that some with higher octane fuel but cool/slightly humid air is where its at.
Old Jun 23, 2004 | 09:20 AM
Velocity-8's Avatar
Whuumpha!!
I wanted to keep everything the same in all the runs. Stock tire pressure, gas etc...
Old Jun 23, 2004 | 09:24 AM
brillo's Avatar
Go Texas Longhorns!
so how do you counter act this? better radiator? CAI? the intakes don' seem to do much for the car. what other ways can you cool the engine down?
DreRX8's Avatar
What were the cars that ran against you?
Old Jun 23, 2004 | 09:25 AM
Kain's Avatar
Human Being
hmmmm it does seem like heat was the culprit. have you heard of the https://www.rx8club.com/showthread.p...ight=cryogenic at all>?
Old Jun 23, 2004 | 09:30 AM
IKnowNot'ing's Avatar
Heat affects WOT engine performances in 2 ways :
1) hotter intake air is less dense, hence less O2, therefore burning less fuel
2) hotter intake air = hotter combustion temperature = propension for knock = spark retarded by the ECU
Some of 2 can be recovered by using higher grade fuel.
Old Jun 23, 2004 | 09:32 AM
Velocity-8's Avatar
Whuumpha!!
The car on the one slip was a 2nd gen Talon AWD turbo with some mods. Another run was against a brand new Neon SRT-4 that was stock. The SRT-4 ran 14.5 (I did not scan this run). The April run has a Ford Lightining Pickup truck run on it doing 12.7. He was modified with a licence plate BLWNTRK
Old Jun 23, 2004 | 09:33 AM
A CAI may help some.
But warmer air is (a)warmer and (b)less dense.
(a) causes detonation earlier so timing has to be pinned back more, can be combated by higher octane which has less change of detonating.
(b) Nothing you can do about this. Less dense air has less oxygen in. Same for higher altitude. But does reduce detonation chances.
Its not about the engine being hot - the stock engine cooling will take care of that, its about what parameters the car is dealing with. Effects all cars, F1 whatever.
Old Jun 23, 2004 | 09:36 AM
Velocity-8's Avatar
Whuumpha!!
Right, that's why I made this thread. I thought it was interesting data and the people here love real info.
Old Jun 23, 2004 | 09:53 AM
blizz81's Avatar
Well, there is one thing you can do...
...move?
Old Jun 23, 2004 | 10:00 AM
Vrimmick's Avatar
Well,
Hotter air and a mixture detonates earlier, but less air and a mixture detonates later right? They counteract each other. That is why at higher altitudes you do not need high octane gas. I think that if the incoming air and coolant temp are too close not only timing is being retarded but the mixture is richer. That is why it is impossible to dyno rx8 properly without an incoming air.
Old Jun 23, 2004 | 10:25 AM
megauo's Avatar
I have similar times:
60' 2,43
1/8 9,683 @ 74
1/4 15,063 @ 90
Old Jun 23, 2004 | 10:40 AM
Kain's Avatar
Human Being
https://www.rx8club.com/showthread.p...light=cryogenic
I AM A SHAMELESS BAST*RD- BUT CAN WE PLEASE GET MORE INPUT ON THIS>???????
Old Jun 23, 2004 | 11:05 AM
Originally posted by Vrimmick
Well,
True in theory but the fact is that the reduced charge due to lower density does not compensate at all for the knock prone combustion. The engine still works at WOT and therefore at very high charge.
Old Jun 23, 2004 | 11:15 AM
smrx8's Avatar
THOSE TIMES JUST GIVE ME DEPRESSION!!! a neon low 14 that some crap
Old Jun 23, 2004 | 12:32 PM
Overport's Avatar
Overport
Yeah...heat definitely affects the performance. Im to scared to drive my 8 when the temp outside is more than 100 degrees. For some reason i just dont like driving it hard when the temp is so hot...its like im afraid of it overheating!
Old Jun 23, 2004 | 01:00 PM
Velocity-8's Avatar
Whuumpha!!
Are you saying I'm lying? The SRT-4 has a 240hp turbo engine and can do 13s. Personally I think they are crap but it's fast crap.
Old Jun 23, 2004 | 01:04 PM
Velocity-8's Avatar
Whuumpha!!
Ambient temp was around 90. The track records the temps at track level so that's why it was so high. And yeah, the car got very hot especially the center tunnel. When I turned the CZ off the metal on the ECU was too hot to touch.
Old Jun 23, 2004 | 01:08 PM
Racer X-8's Avatar
Coming thru in waves...
Just don't race anyone who is in a cooler climate than you.
Old Jun 23, 2004 | 02:01 PM
JimW's Avatar
Good stuff, Velocity 8. I knew heat affected performance, but now we know exactly how much, Thank You. Here in south Florida the heat and humidity is very intense and is a performance killer for any car. I do notice a noticeable performance increase at night when it is cooler. As for the SRT-4, they are not crap, if you like to drag, which is what the car was set up to do via Mopar. It is the best performance per dollar car period. They are very easy to get to run into the 12s while keeping some green in your wallet. The fact is high heat and humidity effects and intercooled turbo even more, especially after multiple runs and thus is the reason for the 14.5 1/4 mile time. I guess if anyone is going to figure something out that might overcome this is Jeff (MazdaManiac) Maurice (canzoomer) or Paul Yaw. I'd imagine the temp and airflow sensor would have to be tweeked and some preventive measure against detonation.
Old Jun 23, 2004 | 07:27 PM
Zeltar's Avatar
Senior Member
Say what? Hotter air does not mean less dense air. First, let's say it did for a minute. In that case, you would be burning too rich (more fuel for the amount of air you take in). That's why in the carburetor days of the side draft Weber’s, we had jet kits to change to smaller sizes when we went up the mountains.
Okay now - quite often, when the air gets hot, it's an indication that the barometer (i.e. the amount of weight the air weighs which is indicative of how much air is above you) is higher. This then, means denser air, not “less dense” air.
Most of us know that if you are at sea level, or hey even better, below sea level like in Death Valley, that your car is going to run faster than it will at 10,000 Feet. The average atmospheric pressure at sea level is 29.92. Velocity’s best run with the CZ1 was at 30.83 (which is below sea level).
I suspect one of two things. Either the CZ1 modification slowed the car down (not likely, according to what I read on this board), or it is the humidity! At 100%, were you under water or something? Around my house in California, when it’s 87% humidity, there is a steady mist and the ground is wet. That said, I wonder if your tires had enough grip for a drag speed test.
Old Jun 23, 2004 | 07:40 PM
Velocity-8's Avatar
Whuumpha!!
Actually I did a better 60' yesterday than back in April so tires were not the reason. It was a hot day and it rained shortly after I left the track. The data i posted is right off the timeslips from Atco.
Old Jun 23, 2004 | 08:50 PM
MP3Guy's Avatar
Correctomundo! Cool dense air always makes max HP. Even the butt dyno will tell you that. An engine is still nothing but one big lung.
Old Jun 23, 2004 | 08:59 PM
BLUE PHI RX-8's Avatar
Did anyone other than me notice that the dates on the time slips showed June 23, 2004. Their date stamp must be off by one day. Maybe the effect of the 2004 leap year.
