Oil topping up with different grade ?
Old Jun 17, 2004 | 07:36 AM
kgoh2262's Avatar
Talking Oil topping up with different grade ?
Hello guys,
Wondering anyone who can help me with this. Got my 8 jsut couple days ago. The dealer use Castrol 20W-50 grade mineral oil for the engine. I am located in Singapore. I have a question here (probably sounding like an idiot ): Is it ok if I top up with same grade of oil but synthetic ? Or it is better to stay with the same oil for topping up.
Old Jun 17, 2004 | 08:41 AM
legokcen's Avatar
The Turkish Delight
I don't think that Synthetic and natural oils will mix. You should stick with the mineral oils. I'm not going to open this up to the synthetic or not synthetic debate, but whatever you use, it should be the same. Do not mix synthetic with natural oil.
Old Jun 17, 2004 | 09:02 PM
kgoh2262's Avatar
Thank you for your in-put. Will do just that. Although I love this baby but I had never paid so much for a car that need this much pampering.......
My old 150bhp civic was virtually maintenance free on my part. Just need to send it in faithfully to the dealer for servicing. For 5 years - no problem.
Old Jun 17, 2004 | 09:54 PM
w2aew's Avatar
www.dorkage.com
The dealer used 20w50!!!!!!
In the US, the recommendation is 5w20, and I've read that other parts of the world get a 10w30 recommendation. However 20w50 is probably WAY too heavy of an oil for this engine. The thicker oil will build oil pressure easier, but the oil flow will be much lower than the designers intended for the bearing clearances in the engine. Also, and potentially more of a problem, the 20w50 probably won't result in the same amount of oil injection to lubricate the apex seals.
Of course, if Mazda recommends 20w50 for your area based on climate, etc., then disregard this. However, I'd thoroughly check this out to avoid potentially shortening the life of your engine due to insufficient lubrication.
Old Jun 18, 2004 | 06:37 AM
kgoh2262's Avatar
Hey W2,
Thanks but the weather here has 2 seasons. HOT and HOTTER. Today it was 35C outside. Engine cooling is a problem. Been doing search in this forum and found that 20W-50 is probably more ideal for hot enviroment and if you are into racing...... (well, I like think I am......first one off the traffic junction....ya baby ya baby)
5W 20 is not the best oil for the engine but it has very low viscosity and does reduce fuel consumption a little (according to the article I had read somewhere here) but more importantly, the reason this grade of oil is recommended by Mazda has to the with the US Government regulation that the car has to be energy efficient ......can't remember the exact wording I had read but hey. do a search in this tech garage, you should come across some helpful articles.....
Thanks AGAIN. How is your baby doing?
Old Jun 18, 2004 | 10:29 AM
Gord96BRG's Avatar
Quick, call all the oil manufacturers selling synthetic blend oils, tell them to STOP!!!
Seriously, all the synthetics marketed these days are fully compatible with mineral oils, and can be mixed to your heart's content. It's not a great plan because of different additive packages to the oil, but it won't cause any problems at all.
Regards,
Gordon
Old Jun 18, 2004 | 02:32 PM
legokcen's Avatar
The Turkish Delight
[/B]
I didn't know that. Thanks for the info! I had read (or remember reading) that they were immiscible.
I retract my last statement.
Old Jun 18, 2004 | 04:11 PM
w2aew's Avatar
www.dorkage.com
Originally posted by kgoh2262
Hey W2,
I saw your location, that's why I prefaced my statements with a comment about climate/location. There are at least two factors that have lead to increased recommendations for lighter weight oils in the US: One is certainly due to the manufacturers trying to eek out the last smidgen of mileage.
However, the other is the fact that today's bearing clearances are tighter and better controlled. These tighter clearances require a thinner oil to get the same flow that heavier oils in yesterday's engines would give. Oil flow is as important as pressure, as it carries away debris and heat. If the oil is too heavy, the flow rate at a given pressure will be lower, and it won't be as effective at cooling the bearing surfaces (yes, oil is an important part of heat management).
That being said, I understand your point of view. My only concern would be that maybe 20w50 is a little too much, even for your location. Maybe a 10w30 (as is recommended for tropical areas by Mazda), or maybe 10w40 is a better choice. If it were me in your area, I'd seek the advice of local Mazda rotary expertise...
Happy Rotoring!
Old Jun 18, 2004 | 05:02 PM
NavyDood's Avatar
Who is this Navy guy?
New Ford V-8's are recommending 5w-20 now also.
Yes all synthetics you can buy off the shelf are mixable with dino stuff. Which leaves this question.... Do they add something to it so they can inter-mix, or are the synthetics based off of dino oil itself?
100% true synthetic oil will not inter-mix with dino oil. Take jet engine oil for example. It's a 30w 100% synthetic oil. It is not compatible with dino oil at all. Not even in the slightest bit.
Old Jun 18, 2004 | 09:34 PM
legokcen's Avatar
The Turkish Delight
Does this mean I can retract my previos retraction???
Old Jun 22, 2004 | 12:24 AM
kgoh2262's Avatar
Can someone just go and buy some synthetic and mineral and mix them to see if they separate after a few days? (I am stingy)
Old Jun 22, 2004 | 11:20 AM
Gord96BRG's Avatar
Nope. Jet oil and automotive oil are blended completely differently - there's nothing in common beyond the base stock. Automotive synthetic oils are completely, 100% compatible with automotive mineral oils. No need to do any separation tests!
Regards,
Gordon
Old Jun 22, 2004 | 01:45 PM
MTLbroker's Avatar
The car has 5w-20 as per manual. If car companies use this to lower CAFE, can I top off with 5w-30? I beleive that 5w-30 is used in other markets. Mixing the two can't hurt, can it?
Old Jun 22, 2004 | 02:26 PM
NavyDood's Avatar
Regards,
Gordon
This is why I always bring this point up. Yes, they are made differently. But oil companys boast that their automotive oil is 100% synthetic. How can it be 100% synthetic and not seperate from dino oil?
I am NOT trying to start a heated debate here. So please, don't get that impression.
Old Jun 22, 2004 | 05:49 PM
r0tor's Avatar
there are 2 different types of synthetics... PAO (polyalphanaolefins) and PAG (polyaphaglycol)
all synthetic motor oils out are PAO synthetics which when it comes down to it are just perfect regular old oil molecule strands - the same as dino except without ANY impurities. They mix perfectly well and exhibit all the traits of regular oil except enhaced alot because they are more predictable/consistant because of the lack of impurities. The only area they suffer is in foam tendencies because in this case you actually need impurities to help break the surface tension on a bubble-so syntheitcs have more anti-foam additives (silicon) and people go crazy when they get their oils tested and see a whole bunch of silicon in the oil and think their air filter isn't working.... but thats another issue all together
There are some PAG synthetics out there in the gear oil market and I wouldn't doubt some select high forms of racing. PAG's are glycol based, kick a PAO's ****, exhibit a long list of desirable traits like complete resistance to fuel dilution, but are extremely expensive and if somebody would accidently mix the PAG with a PAO/dino oil that person would be buying a new piece of equipment because the two types of oils do not mix at all and form all kinds of nasty things.
Old Jun 22, 2004 | 06:01 PM
timisw's Avatar
Since the RX8 burns some oil to run... is it good to put a synthetic into the engine? Dealer said make sure you dont do that...
I am not sure... just asking
Old Jun 22, 2004 | 06:07 PM
r0tor's Avatar
the synthetic in a rotary debate has been going on since the beginning of time.... as for my stance, well I just dumped a quart of synthetic in mine.
Old Jun 22, 2004 | 06:10 PM
bowman's Avatar
Isn't semi-synthetic motor oil a blend of synthetic and mineral oil? Wouldn't that mean that the two are compatible?
Azki23
Jun 27, 2018 03:48 PM
Paul_Y
Sep 21, 2015 02:23 PM
TJSiegrist
Sep 10, 2015 09:29 AM
Slack
Sep 5, 2015 06:42 PM
chris424
Sep 2, 2015 10:18 AM
