Need help with "ticking" Sound..
Old Jun 14, 2004 | 10:30 PM
RenesisRotary's Avatar
As Described, when turning at a sharp angle,..imagine how you would have the wheel if you coming off an offramp at about 40..,I hear a clicking noise..as if somthing has broken, or snapped loose, its only when turning the wheel to the right..It has never occured on the left side..I was curious if anyone knows what it might be?
Old Jun 14, 2004 | 10:44 PM
w2aew's Avatar
www.dorkage.com
Sounds like the wheels could use cleaning and re-torquing. See the following:
http://www.finishlineperformance.com...02-002-04.html
Old Jun 14, 2004 | 11:03 PM
poolsidenaz's Avatar
Great link! I have a follow up question. I think I heard a ticking/clicking noise on Saturday when creeping through a parking light and getting feedback from a nearby building. I"ve noticed my left front wheel gets a good 50% more brake dust on it than the right front. Would this also be an indication of the problem described in that link? Thanks much.
Old Jun 15, 2004 | 08:13 AM
w2aew's Avatar
www.dorkage.com
Hmmm - I don't know about the extra brake dust. I guess its conceivable that the ticking results in sharp little vibrations that knocks the brake dust loose from the calipers/pads/etc., but that's probably a stretch.
It would be a good idea if you perform the cleaning and re-torquing described in the above link. While you have the wheels off, carefully measure the brake pad thickness with a calipers. If the left side is worn more than the right, I'd take it to the dealer to get checked out.
Old Jun 15, 2004 | 08:32 AM
bubble's Avatar
If there's a tock then you're alright. If there's only a tick you need to replace the batteries.
Old Jun 15, 2004 | 08:45 AM
Gomez's Avatar
Shifty Bastard.
you are SUCH a bubble......
DOMINION's Avatar
I don't buy Kool-Aid
Re: Need help with "ticking" Sound..
I would guess its you steering pump. If and when under stress it may some times make a ticking sound.
Some questions for ya,
What sise of wheels do you have? and can they be rubbing?
Are you under warranty?
Is this abnormal noise from the engine area? or right side/wheel(s)?
Old Jun 15, 2004 | 09:06 AM
rjacobs's Avatar
Sideways, No not me sir
hmmm, we dont have steering pumps on these cars since it is ALL ELECTRIC with no fluid so that was a horrible guess. Hopefully the car is still under warranty, I dont think anybody on this forum has gone over their warranty period yet(now voided is another story).
Old Jun 15, 2004 | 09:11 AM
DOMINION's Avatar
Oh hell if I knew that LOL!
I'm still trying to learn all I can about this car....
Old Jun 15, 2004 | 11:26 AM
Re: Re: Need help with "ticking" Sound..
First things first, my 8 is stock..So no wheels rubbing, unless it was out of the factory like that..the noise is clearly coming from the wheel portion of the car, having drove past buildings, not hearing on the right side, repeating the process, then hearing the sound on the left..I mean, its on an off its not all the time...Mostly it happens going around corners, or on-off ramps...
As for taking apart my car..I dont have the time, nor the space..thank you very much for the link, but I was just wondering about a diagnosis, I've already scheduled matinence with the dealer..
Old Jun 15, 2004 | 11:31 AM
Winning_BlueRX8's Avatar
Limecat's High Priest
hahahahahha
Old Jun 15, 2004 | 11:56 AM
rotarymagic's Avatar
I had the same thing
Old Sep 27, 2004 | 02:59 PM
Tatsuki's Avatar
My car is going into the shop tomorrow (9/28/04) to have it's annoying ticking noise diagnosed, as well as getting a 3rd glove compartment pistol put in (They could have done better on that one). I'll let you know what they find out.
Best guess was a loose swaybar, but they WERE guessing at that point.
Old Sep 27, 2004 | 05:42 PM
B-Nez's Avatar
Whoo! How many glove compartment pistols do you need?! Haven't you ever heard of "one shot, one kill"? :D
Old Sep 27, 2004 | 06:50 PM
khoney's Avatar
FX8TED on my RX-8
There's a TSB for the ticking sound when turning (see one of the early posts). I had the same problem (only when I turned to the right). Brought the car in and handed them the TSB, they did what it said, and no more ticking. I would hear the ticking sound mostly at low speeds when turning a sharp corner. That's the first thing they should try.
Old Oct 1, 2004 | 08:48 PM
Tatsuki's Avatar
Ticking noise solved
This is an odd answer. I ran the car low on oil (No! NOT OUT OF OIL!, JUST LOW!) When I added oil, ticking noise went away.
And as to how many glove compartment pistons I need, looks like about 1 every 5000 miles. Manufacturing defect I guess.
Mattix91
May 26, 2022 09:13 PM
iSki123
Dec 24, 2012 08:07 AM
Sturmgezhutz
Sep 10, 2012 09:43 AM
camilo123456
Aug 9, 2012 05:37 PM
rotalution
Australia/New Zealand Forum
18
Dec 21, 2007 07:35 AM
