View Full Version : No tire pressure listed on the decal
gusmahler
06-13-2004, 04:51 PM
Just got my 8 this weekend. I found my tire pressure gauge and decided to check the pressure. I open the driver side door to check the recommended pressure. It was blank. The decal is there. But the info regarding the correct tire pressure is not filled in.
EDIT--from elsewhere on this site, I found out that the correct pressure is 32psi. But has anyone else had a blank tire pressure decal?
brothervoodoo
06-13-2004, 04:56 PM
Should be something like 32...
Rx-Appreci-8
06-13-2004, 05:06 PM
Mine's blank too.
JSE RX-8
06-13-2004, 05:48 PM
32 for front and back..just checked
dannobre
06-13-2004, 05:51 PM
was blank too
northern-8
06-13-2004, 07:14 PM
Yup, mine's blank too.
I guess it was too expensive for mazda to use actual ink to fill out the labels.
w2aew
06-13-2004, 08:25 PM
32 psi for the 18" wheels / Potenza tires. 34 psi for the 17" wheels (on the base AT model). Same for the front and rear.
FWIW - my sticker isn't blank... it shows 32 psi ...
TheDosDog
06-13-2004, 08:42 PM
There is another sticker is on the door edge (not jam) that lists tire pressure.
RenoIV
06-13-2004, 08:47 PM
Mine has two stickers one on the door frame and one on the door that has the pressure on it. see page 8-26 in the manual
gusmahler
06-13-2004, 11:15 PM
Originally posted by RenoIV
Mine has two stickers one on the door frame and one on the door that has the pressure on it. see page 8-26 in the manual Ah, found it. The pressure is listed on the door. The one on the jam has a space to put in the pressure, but the space is blank.
Charles R. Hill
06-14-2004, 06:49 AM
After trying different pressures, I have decided that 32 psi works for comfortable daily driving and 40 psi for firmer driving.
Charles
Phlash
06-14-2004, 07:29 AM
It's on the inside edge of the drivers door, not the label on the freestyle door.....
DOMINION
06-14-2004, 07:52 AM
LOL!!! that a good one... Yea me too. its blank:confused:
MTLbroker
06-14-2004, 08:03 AM
Mine's labelled at 32 psi front and back. Altho on tire sidewall, shows a much higher max pressure limit. Would a higher tire pressure be detrimental to other components of the car, especially suspension, electronics? And is there an advantage to overpressurizing above the recommended 32 psi?
The car weighs only 3000 lbs or so, wouldn't overpressurizing cause uneven treadwear?
DOMINION
06-14-2004, 08:05 AM
Oh dam!!! you got to be kiddong me LOL!!!...
DOMINION
06-14-2004, 08:06 AM
MTLbroker, Yes overpressurizing can cause uneven treadwear and not be safe. If you do put to much air the Tire/Air sensor should light up.
northern-8
06-14-2004, 09:53 AM
Yup, it's on the door. Boy do I feel stupid about the Mazda being cheap crack. They actually gave 2 labels, that's why the car costs a much as it does!
Katchoo
06-14-2004, 12:32 PM
LOL....the decal-thing fooled me too. Whe delivered to me it had 45PSI in each tire...what a ride home that was!
N-E-ways, took me 2 days to figure out the right pressures (it was New Year's weekend and everything was closed).
Phlash
06-14-2004, 01:14 PM
Yeah, it got me too.......then i actually rtfm.....TADA!!!! there it was.......just as it stated......
