removin the doors
Old Jun 13, 2004 | 06:31 AM
tmmn22's Avatar
removin the doors
can anyone tell me how to remove the inside door coverin to get to the speakers?? DIY install....thx guys
Old Jun 13, 2004 | 09:00 AM
momo stereo's Avatar
easy as pie!!!!first pull the tweeter console off the is in the corner of the window.....no screws, just pull...#2- then remove the switch panel by pulling out at the bottom of the panel and sliding it out and unplugging it....then remove the gold screw that hold the panel to the door behind the switch panel....after you do this there will be one more screw holding the door on that is located in the pocket near the back side of the door (in a hole almost) sort of hard to see but keep looking.....once you have those things removed the panel just unsnaps from the door....start pulling out at the bottom first , then the sides and then push the panel up to remove from the door....these small steps will allow you to have access to your door speakers which are 5 x 7, or 6 x8 whatever you want to call them ...they are the exact same size.......good luck
Old Jun 13, 2004 | 03:23 PM
tmmn22's Avatar
Thx dude....was wonderin if it was that easy
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
nferguson88
Oct 6, 2015 12:45 PM
archon
Oct 1, 2015 06:08 AM
Learners_Permit
Sep 27, 2015 07:38 PM
