View Full Version : Fuel injector cleaner
DAC17
06-09-2004, 08:22 PM
OK, I've had the 8 for almost a year now, and I'm thinking about using a FI cleaner, like Techron. Any reason I shouldn't do this due to the way the rotary operates? I assume it should be the same as any other engine, but wanted to check with you "experts".
Thanks.
dcfc3s
06-10-2004, 09:59 AM
Works just fine in a rotary. Regane is some pretty darn good stuff, BTW. Read about some guys that ran a tank with it through a Supra with a lot of miles on the motor just before they tore the motor down to rebuild/upgrade it. Said the valve seats and everything were SPOTLESS - really de-carbonized well.
I think it's a good idea every oil change or so. It's easier to keep injectors clean than trying to clean ones that are filthy and clogged.
Dale
Slickvic
06-10-2004, 10:12 AM
Techron should keep your valves nice and clean too.
:D
