Tire Rotation Necessary?
Old Jun 9, 2004 | 11:37 AM
Feras's Avatar
the Doctor
and acceleration is going to wear the back tires differently from the front, don't forget you can't switch sides (L and R) at least with the stock tires, they are directional.
Old Jun 9, 2004 | 12:29 PM
srm858's Avatar
Question Tire Rotation Necessary?
Normally, I rotate my tires on my FWD cars, but the RX8 is rear wheel drive and 50/50 weight distribution. I know with the BMW I had before, they suggested not rotating the tires and it has the same basic specs.
What are people's thoughts on this? My tires seem to be wearing evenly at 10k.
Old Jun 9, 2004 | 12:32 PM
mikeb's Avatar
100% Italian
you still need to rotate
Old Jun 9, 2004 | 12:35 PM
Boozehound's Avatar
Get Hooked
Most definitely. You don't steer with the rear wheels.
Old Jun 9, 2004 | 01:33 PM
legokcen's Avatar
The Turkish Delight
Just rotated mine last night at 8K miles. The tire wear is pretty even, but I wanted to rotate it while I had the chance.
Old Jun 9, 2004 | 03:26 PM
Velocity-8's Avatar
Whuumpha!!
You're not driving hard enough! :D
Old Jun 9, 2004 | 06:28 PM
DrRadar's Avatar
Trussville Mazda Service Rep recommended the tires be rotated at
every oil change(3kMiles).
Makes sense since the tires are so damn expensive.
Old Jun 9, 2004 | 06:32 PM
rx8amber's Avatar
is there a first page to this thread? i tried reading it a few times but it starts weird. what did i miss?
Old Jun 9, 2004 | 06:39 PM
SpearRX8's Avatar
You need to rotate the tires on our 8s. If not you will wear the inside of the tires on the back. The 8 rides with the rear tires slightly opening outward. This only happens when it is moving. At stand still, they look leveled.
Old Jun 9, 2004 | 10:10 PM
timisw's Avatar
Plus, the front tires do all of the cornering... No matter what , they are having to spin faster or slower depending on how you take your curves.
Old Jun 9, 2004 | 10:14 PM
zzum-zum's Avatar
I'm curious about BMWs reasoning for not rotating tires. I have never heard of that before. Did they say why not?
Old Jun 9, 2004 | 10:18 PM
rxeightr's Avatar
M0D Squad -charter member
I did my 1st rotation after 13,000 miles.
The rears were worn MUCH more than what was on the front.
If I had it to do again, I would have rotated at 5,000 or 7,500 mile intervals.
Old Jun 9, 2004 | 11:01 PM
zzum-zum's Avatar
The manual says every 7500 miles - I have mine rotated every other oil change.
Old Jun 9, 2004 | 11:57 PM
Feras's Avatar
the Doctor
clocks were messed up for an hour, i posted at 1:30 (forum thought it was 12:30) to a forum that started at 1 and since i posted at '12:30' my post obviously preceded the other one...wierd
Old Jun 10, 2004 | 07:55 AM
rx8cited's Avatar
Senior Member
I don't think 7500 miles between rotations is a good idea because there will be a bigger difference in wear between the front and rear sets. Also the stock tires have been reported to have a life of only 15k.
Here's TireRack's Tire Rotation article . They suggest 3-5k for high performance tires.
rx8cited
Old Jun 10, 2004 | 08:28 AM
srm858's Avatar
With the 5 series I had, owners suggested not rotating the tires, because they wear evenly and last longer by not rotating. I got the information second hand, so that is all I know. It did seem to work well, the tires looked great when I traded it in and lots of tread still left at 25k.
I think I will rotate the tires when I do an oil change this weekend. Seems like some good reasons to do so.
Old Jun 10, 2004 | 09:10 AM
willhave8's Avatar
Did my first rotation at 3.5K miles at the dealer and plan to continue at that frequency -- along with oil changes. Time well spent IMHO.
Old Jun 10, 2004 | 09:19 AM
Farsyde's Avatar
Maybe a few burnouts? Autocrossing? Street light racing? Or just fun driving :D
Old Jun 10, 2004 | 09:24 AM
Sea Ray's Avatar
I just did mine at 5000, also the 2nd oil change, and had the insultation kit/pad put in under the cup holder. Seems to work but still gets somewhat warm.
Old Jun 10, 2004 | 09:39 AM
Seenitall's Avatar
Had a 1999 BMw 3 series. They reccommended rotating every 5000 km-3000 miles. If you dont- you risk uneven wear and a reduction in tire life..
Old Jun 10, 2004 | 01:19 PM
rxeightr's Avatar
Let's just say nothing that was considered a 'timed' event
Old Jun 10, 2004 | 05:16 PM
beachdog's Avatar
rx8cited
Exactly. I believe that the NHTSA rating for the stock Bridgestones is 20k mile tread life. If you go to 7500+ miles you will only do two rotations before replacing and you'll be drivng on uneven tires most of the time.
Old Jun 10, 2004 | 08:58 PM
LoKnLoD's Avatar
I have mine rotated every 2500 miles when I bring it in to the dealer for my oil change. My dealer always sends me coupons for a special service, oil, all fluids, rotate tires, cv joints, check brakes, lube doors for $50
Old Jun 10, 2004 | 09:32 PM
Mitch Strickler's Avatar
Stock tire mileage
The stock tires are 140 wear rated, which translates to 28,000. Mind you, I'm not saying we can expect that much, and of course the way you drive makes an enormous difference. As experience builds up, we can get a realistic reading through reports on this forum.
Old Jun 10, 2004 | 09:38 PM
Kurt Bob's Avatar
My car has 17,300 miles on it with over half the tread still left. This included a Track weekend and a couple of autocrosses.
I rotate every 7,500 as per the manual. Just get it done every oil change (unless you're on the 5,000 mile "severe" schedule). Mazda won't pay for the rotation before it is time.
