West RX-8 Forum Serving CA, NV, AZ, HI
Oil in the RX-8 and consumption of it?
Old Jun 7, 2004 | 06:53 PM
Equis's Avatar
Speeding Ticket Magnet
So my 8 has a couple of miles on it and the oil light keeps turning on while I drive. I call the dealership and tell them WTF is up with that. They tell me everytime I fuel up I must check my oil to make sure it has some, my reply was like why the hell should I check my oil everytime I fuel up. That seems very bothersome to me he said that the way the rotary engine is made it eats up oil to lubricate it (if that makes anysense) .
Now is this true or is dealership BS'ing to get me off their back?
Old Jun 7, 2004 | 07:00 PM
RX8Bliss's Avatar
donuts are day old bagels
its true - its in the manual, i thought you read it already?
by design oil gets eaten a bit by bit. just check the level of oil every other fill up or so and add as necessary - you should be doing this anyway as part of the maintenance of ANY vehicle.
Old Jun 7, 2004 | 07:06 PM
Equis's Avatar
But so soon at 800 so miles!?
I guess I will look into the manual to see what kinda oil it is using to refill some of it. Arg.....
Old Jun 7, 2004 | 07:16 PM
lafrad's Avatar
Wanna-be RX Owner.
Consumption of oil is one of the shining points of a rotary. You should have known this WELL before purchasing this car.
5w-20 oil, from a name brand company (Penzoil, Castrol, etc) is what you need.
Old Jun 7, 2004 | 08:19 PM
EatMyBanana's Avatar
i purchased mine 3 weeks ago . 1300 miles and no oil use..........
Old Jun 7, 2004 | 09:09 PM
lafrad's Avatar
Wanna-be RX Owner.
that just means they overfilled it a little from the factory....
I use about 1 qt every 3000-4000 miles... M-flash, Castrol 5w-20.... (2.25 qts so far, ~7500 on the odo)
Old Jun 7, 2004 | 09:27 PM
Thanks it seems i am on track..
Old Jun 8, 2004 | 08:23 AM
bureau13's Avatar
There is a pump whose entire purpose is to send a small amount of oil into the combustion chamber. The engine is not just "eating oil." Its being purposefully injected!
jds
Old Jun 8, 2004 | 08:29 AM
blue flash's Avatar
since i got the M flash i have not used any oil .is this still o.k to protect the apex seal?
Old Jun 8, 2004 | 09:05 AM
expo1's Avatar
He's as bad as Can
Re: Oil in the RX-8 and consumption of it?
What is the Build date on your 8? Does this only happen around 4,500-5,000 RPM?
If yes there was an issue with early RX-8's covered in this TSB
http://www.finishlineperformance.com.../01_027_03.htm
Old Jun 9, 2004 | 03:19 AM
Equis's Avatar
How can I find my buil date is it on the VIN #? it usaully happens when I am driving on the freeway so yet around 4,500-5,000 RPM.
It is really starting to **** me off I already bought a quart of oil but so soon makes me kinda mad.
Old Jun 9, 2004 | 04:29 AM
expo1's Avatar
He's as bad as Can
Sounds like the same oil Pan issue I and many other’s had and addressed in this TSB. The build date can be found on a sticker on the Drivers side door jam. Also if the last 6 digits of your vin# are below 111043 you are effected. This is a simple warranty issue, be sure your dealer has the parts in stock before you drop the car off or they will have to keep it an extra day.
Old Jun 11, 2004 | 07:10 PM
pixartist's Avatar
I had a problem with my oil light going on every 400 miles. Came to find out that there was a defect in the oil pan. No problems now.
Old Jun 12, 2004 | 12:08 PM
ALMOST8IT's Avatar
Build date is on the inside of the driver's door.
Old Jun 12, 2004 | 12:19 PM
poolsidenaz's Avatar
3800+ miles on mine, 1 oil change so far. The oil light has never come on; I've never topped it off. No problems so far.
ouimetnick
25
Sep 14, 2023 01:44 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
vssystemluba
Jul 19, 2015 04:16 PM
