New 8 Break-in
Old Jun 2, 2004 | 02:10 PM
JOHNRX8's Avatar
Talking New 8 Break-in
I just bought my new 8 last night and this is my first tread. Question one- I read the manual about breaking in, is there anything else I should Know to properly break in the engine? Question two- how can you tell what flash version you have?
Old Jun 2, 2004 | 02:12 PM
mikeb's Avatar
100% Italian
give it 600 miles for break in
Old Jun 2, 2004 | 02:24 PM
HeelnToe's Avatar
Re: New 8 Break-in
Turn the key to ON, and pump the brake pedal at LEAST 20 times very quickly... if you have at least L, your oil gauge will sweep over and back.
You'll feel like an idiot doing it, but it actually works, lol...
Old Jun 2, 2004 | 02:48 PM
JimJimElf's Avatar
I gave mine 1000 miles for breack which was easy since after a week of owning I drove from VA to FL and back.
Old Jun 2, 2004 | 03:36 PM
AQA101's Avatar
Stainless
Gave it 500 miles below 6000 revs, after that period I shortly drove top speed once (150 mph) because my father was interested in speed and roadhold and drove it normal since then. Added some quality oil after 600 miles and 1200 miles (each time half a litre).
Old Jun 2, 2004 | 06:49 PM
8pex's Avatar
Members Only
Racing Beat website has a recommended break in.
Old Jun 2, 2004 | 08:30 PM
kellybrf's Avatar
honestly, this car does not need a break in b/c much of the break in involves the crankshaft and piston seals to properly seat. that said, for the first 1k mi or so i kept it below 6k rpm and varied my rpms (aka, on the highway vary speeds and use 4th-6th gears)
Old Jun 2, 2004 | 09:20 PM
KC-RX8's Avatar
I just got mine last week and service told me no break-in; but it doesn't hurt to go easy the first 500 and vary the RPMs.
Also, I just got the latest EEPROM today, version "N3..." and it fixed my CEL I got for a false positive on the catalytic converter.
Old Jun 3, 2004 | 01:13 AM
rx8spiritR's Avatar
----Got Rice?----
N3????
Old Jun 4, 2004 | 01:27 PM
KC-RX8's Avatar
Originally posted by rx8spiritR
N3????
Yeah, strange. Here's the full file #N3H6-M-18881
I only assumed that the shorthand notation for the EEPROM revision level was "N" as earlier posts were saying that they had "L" and "M".
Old Jun 4, 2004 | 01:38 PM
Feras's Avatar
the Doctor
N3H6-M -18881 i believe thats an m flash
Old Jun 15, 2004 | 05:13 PM
gusmahler's Avatar
What is the purpose of break-in?
The manual's break-in guidelines were very lax: (1) no *extended* revs past 7000; (2) no wide open throttle acceleration; and (3) no steady speeds.
I'm following 1 and 2, but I really don't know why they want us to do it. And they aren't clear: what is *extended* revs past 7000 rpms. Do they just mean don't do that in every gear?
As for steady speeds, what do they mean. I assume that, if I were to drive from SF to LA, I shouldn't set the cruise. But I have 9.4 highway miles each day (according to the NAV system). I'm not allowed to stay at one speed? So if there is a slow down and everyone is going 45, am I supposed to slow down to 35, than back up to 50 to catch up, then back to 35 again?
Really, what is the engineering reason for avoiding constant speeds? And is 8 minutes at one speed OK?
Old Jun 15, 2004 | 05:18 PM
8pex's Avatar
Members Only
Regarding the steady speed, I think they mean engine speed. I think you can travel the same MPH, just change up your gear selection, if you have the MT (which you should).
Old Jun 15, 2004 | 06:26 PM
kellybrf's Avatar
8pex is right, you want to vary your rpms, not speed (although one way to do this is to very the speed)
Old Jun 15, 2004 | 07:55 PM
w2aew's Avatar
www.dorkage.com
Here are your break-in reasons:
Extended high RPM revs can score the housings until the seals break in.
No WOT due to the excessive pressures in the combustion chamber, on the eccentric bearings, etc. You want these to establish smooth and consistent wearing surfaces.
And finally, avoiding long-durations of constant RPM also prevent uneven break-in (seating) of bearing and seal surfaces that could result from resonances at constant revs.
Old Jun 15, 2004 | 08:44 PM
former_s2k'r's Avatar
I thought we had a rotary engine!
:D
Old Jun 15, 2004 | 09:53 PM
w2aew's Avatar
www.dorkage.com
Yep - rotary engines have seals (apex seals, etc.), bearings (on the eccentric shaft, rotors), combustion chambers (even though it their not cylindrical), and even vibrations and resonances (which are mostly cancelled by the appropriate phasing of the two rotors).
Old Jun 15, 2004 | 10:10 PM
gusmahler's Avatar
Thanks. But that brings up the obvious follow-up question: what is a "long-duration". Can I drive the 8-10 highway minutes to my office with cruise control on?
Old Jun 16, 2004 | 05:37 AM
762gunner's Avatar
gusmahler, you may want to go the highway route to work one day, and then maybe take the back roads another day.
Another thing to think about is that you have 600 miles in which to vary the engine RPM. If you're driving a nonstop road trip from VA to NY and back, and you drive the whole way on cruise, then you're not varying engine RPM and that is bad for a good break in.
But if you're just driving to work and back, well you have to start the car and idle for a little bit ( low rpm ), then accelerate ( mid rpm ), change gears and accelerate, ( mid to low to mid rpm ), cruise ( mid rpm ), maybe you screw up a shift every now and then and you go to 6000 rpm ( high rpm ), then you get off the highway and stop at a red light ( mid to low rpm ), and then stop and go traffic until you get to work ( low to mid to low to mid etc. )
Sounds like normal day to day commuting is fine for breaking it in.
R3Dream
Mar 7, 2019 09:11 AM
R3Dream
48
Mar 12, 2016 01:44 PM
dbarber
Jul 25, 2015 01:34 PM
TJLack
Sep 8, 2004 09:24 AM
