Reving to 3K before shutdown prevents floods?
Old Jun 1, 2004 | 10:41 AM
Jailbreak'74's Avatar
Dealership told me that reving to 3000 then killing it would prevent any kind of stalling issues by clearing the ports. My car has never stalled once from day one. (3000 miles old) If I don't rev before shutdown it takes a second longer to start the following time I noticed, that's about it. I've have 3 versions of flash, (K, M, & N)......neither one changed the way this acted. M took care of the slightly rough idle, and N put the 7000RPM power back that K originally had, which M took away. (N is the best flash, get it) I'm glad I've never had a flooding issue. Good luck to anyone who does have this problem.
Old Jun 1, 2004 | 11:04 AM
NAVILESRX8's Avatar
FWD Hater
I've been doing it on mine since day one.....never flooded.
Old Jun 1, 2004 | 11:14 AM
fietguy's Avatar
Flooding issue? what flooding issue? there isn't one, its all a myth...
Old Jun 1, 2004 | 11:15 AM
rxeightr's Avatar
M0D Squad -charter member
Been doing the same to mine on a cold shutdown.
Never flooded.
Old Jun 1, 2004 | 11:22 AM
MTLbroker's Avatar
So now, my usual car ride scenario is as follows:
1-unlock door
2-get in car
3-turn key to 'acc' position til car stops beeping
4-crank engine (and pray)
5-press and hold DSC button to disable TCS system
6-drive
7-check clock (make sure I drive at least 10 min)
8-park
9-rev to 3k rpm
10-shut off engine
Still love the car tho'
Old Jun 1, 2004 | 11:27 AM
I've read plenty of posts talking about not starting the first time so i'm sure it exists.
Old Jun 1, 2004 | 11:40 AM
Caecil's Avatar
1-unlock door
2-get in car
6-drive
8-park
9-rev to 3k rpm
10-shut off engine
I.m.o. it's 7 or 9 (no need for both) and you forgot
11- get out car
12- lock
Old Jun 1, 2004 | 11:46 AM
Gord96BRG's Avatar
Re: Reving to 3K before shutdown prevents floods?
There is no N flash - M is still the latest and most current version (as discussed in the threads suggesting that there's a new flash).
M included reprogrammed cold start parameters to eliminate 99% of the flooding chance.
Regards,
Gordon
Old Jun 1, 2004 | 12:16 PM
MTLbroker's Avatar
No, no, I've never gotten out of the car ..... lol!
My wife is still looking for me :-)
Old Jun 1, 2004 | 12:37 PM
Caecil's Avatar
Just be sure to lock it anyway!!!!!
Old Jun 1, 2004 | 12:41 PM
Re: Re: Reving to 3K before shutdown prevents floods?
Regards,
Gordon
Actually yes there is. I had M on there, the latest update was released 12 days ago on 5/22. (as previously discussed) Before the 22nd there was only M.
Old Jun 1, 2004 | 02:06 PM
MTLbroker's Avatar
n e idea what changes for n-flash? I have m-flash and seems to be OK. But I wouldn't know - still in engine break-in mode.
Old Jun 1, 2004 | 02:21 PM
N put the 7000RPM power back that K originally had. That's all I noticed. Oh yeah, idles smoother it seems. Might be a plecibo though.
Old Jun 1, 2004 | 02:44 PM
Gord96BRG's Avatar
Re: Re: Re: Reving to 3K before shutdown prevents floods?
There is a WDS update, but the RX-8 flash was NOT updated as part of it. Re-read those other threads about this - there is still only M.
Regards,
Gordon
Old Jun 1, 2004 | 02:52 PM
I really don't care about threads....1/2 the stuff here is bull anyway. I've spoken to 3 people who have gotten the may 22nd flash done to their cars and have all noticed the 7K push is back. That wouldn't have to do with WDS.
Old Jun 1, 2004 | 03:07 PM
Gord96BRG's Avatar
You should care about those threads - a couple of the people in there actually know what they're talking about, like Snap-On - he's a Mazda mechanic. He has posted valuable info about the exact process that Mazda dealers go through to get the updates and advice on the flashes.
WDS is Mazda's Worldwide Diagnostic System - that's HOW Mazda distributes new flashes to the dealers. They get a WDS update, which contains new diagnostic code and for those new models with re-flashable ECUs, the WDS updates contain the PCM flash updates. Read what Snap-On wrote again - there are no RX-8 PCM updates beyond M in the recent WDS updates.
There is NO such thing as a May 22 flash update - there might be a WDS update, which will have a version number such as 35.3, which could contain an RX-8 flash update like N (for example purposes only - again, as Snap-On wrote, there is NO N flash yet). Mazda does not associate flash updates with calendar dates.
Regards,
Gordon
Old Jun 1, 2004 | 03:13 PM
Please tell me what update came out on the 22nd then...because a few people on here were told they had the PCM flashed. What does the update we were given do then? I'm interested to know. I hate dealerships, whatever you say they say yes to.
Old Jun 1, 2004 | 03:34 PM
Gord96BRG's Avatar
From this thread New flash today , forum member adrian-1 posted:
WDS Release Level B31_5, 5/21/2004 9:43:36 AM.
As far as "restore lost power in the high rev band" he didn't see that. He did find the info below......
P2107/P2108/P2402/P0420 LACK OF POWER / PINGING
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 40100001 40135537
Some vehicles may experience a check engine light and / or a lack of power / engine pinging. The cause may be due to incorrect logic in the PCM. Customers with lack of power / pinging, or the following DTCs stored in PCM memory should have their vehicles repaired using the repair procedure. P2107-Throttle actuator control module processor error. P2108-Throttle actuator control module performance error. P2402-EVAP system leak detection pump control circuit high. P0420-Catalyst system efficiency below threshold. 1) Verify concern. 2) Check current PCM calibration by accessing mode 9 using WDS. WDS menu- POWERTRAIN - OBD TEST MODES - MODE 9 VEHICLE INFORMATION. 3) If calibration level is not at or above "M" proceed to next step. If calibration is at or above "M", consult WSM for diagnosis. NOTE: mode 9 calibration is displayed as N3H*EL000********. The digit following the "E" is the current calibration level of the PCM. 4) Reprogram PCM using WDS. Update WDS to version B28.0.11 or later if necessary. 5) Clear all DTCs. 6) Verify repairs. VEHICLE TRANS TYPE Filename New PCM Cal. P/N Manual transmission SW-N3H6EM000 N3H6-18-881M Auto transmission SW-N3H4EM000 N3H4-18-881M NOTE: * WDS shows the calibration part number after programming the PCM. * Please be aware that PCM calibration part numbers and file names listed in any service message may change due to future releases of WDS software and additional revisions made to those calibrations for service related concerns. WDS PCM reprogramming will always display the "latest" calibration P/N available for that vehicle. If any calibration has been revised/updated to contain new information for a new service concern/issue, it will also contain all previously released calibrations. Install PCM calibration label with revised PCM calibration part # in the appropriate location. After performing the PCM reprogramming it is necessary to road test the vehicle to relearn KAM strategy and verify no MIL illumination or DTC's are present.
WDS update 31.5 was released on May 21 - adrian-1 quoted the relevant RX-8 information above - deciphering the PCM versions, shows PCM version SW-N3H6EM000 N3H6-18-881M for the manual trans RX-8. I highlighted the digit that indicates the flash version - it is still M.
Regards,
Gordon
Old Jun 1, 2004 | 11:08 PM
RenoIV's Avatar
Rotary powered since 1988
Question
What's the reasoning behind the 3k before shutdown? burn fuel quicker at the high rpm? spin it out after then injectors shut down? didn't the M-flash reduce the amount of fuel metered at idle?
I just make sure the engine is warmed up before shutdown. Only 4k miles on mine have the M-flash. never flooded it or my FC that has 148K on it.
Old Jun 2, 2004 | 06:35 AM
thanks gordy!
todayrx8
Feb 28, 2011 06:58 PM
Big_Mike_4488
Dec 29, 2005 03:59 PM
