Manual Transmission Adjustment
Old Jun 1, 2004 | 01:26 AM
Mace Howling's Avatar
I hear that the manual transmission of the 8 takes a little time to get used too.
Is that true?
Old Jun 1, 2004 | 01:43 AM
cfusionpm's Avatar
im used to my old notchy, low-grabbing clutch in my talon, and had absolutely no problems with the 8 on my viggorous test drive. the clutch grabbed a bit higher and was smoother, the gearbox had shorter throws, and it took a little getting used to to comfortably shift to 5th. (my 5th is like waaaaay off to the right). but after maybe a minute of driving i was totally comfortable with it.
Old Jun 1, 2004 | 01:45 AM
Thats what I want to hear.
Old Jun 1, 2004 | 09:37 AM
Green Thunder18's Avatar
It's a bit of an adjustment. A little rough in the lower gears, but the current M flash is supposed to reduce that quite a bit. Also, my 3rd and 5th gears are much further over than any other car I have ever driven. Not a big deal, but a slight adjustment - I was used to pretty much going straight up in to 3rd and 5th and now I have to think of pushing the shifter to the right to slide into gear. Not a big deal - should take about 5 minutes to get comfortable. :D
Old Jun 1, 2004 | 10:50 AM
Yanje's Avatar
had trouble with 2nd gear at first, but got used to it after a day or 2.
i can't adjust in 1 min. need at least an hour or two to adjust fully
Old Jun 1, 2004 | 10:55 AM
AQA101's Avatar
Stainless
I tend to confuse 4th and 6th and sometimes shift third too diagonal yet, also third and fourth feel different (more "clicky") than the others.
Yeah, and backwards is sometimes a pain (but that counts for nearly every car).
But I guess I 'll get used to it in the near future.
Old Jun 1, 2004 | 11:04 AM
Seenitall's Avatar
The box is higher effort than the BMW I came from, But overall I'm pleased. It seems to respond better if you are driving hard rather than loafing.
Took maybe 3 drives before I adjusted-it was MY problem not the box.
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
JCTaylor
Sep 30, 2015 07:31 PM
