Shock Sensor Turned Off??
Old May 31, 2004 | 05:39 PM
Loaded8's Avatar
I've read the threads on the shock sensor and thanks to the information provided I was able to adjust the sensitivity. My question is.... I turned it all the way counter-clockwise so hopefully it wouldn't go off every time the neighborhood AH drives by, so far it is working .....
but now I'm wondering if I turned it all the way off, is that possible? or will it just take a jet airplane landing on top of the car to set it off now?
Thanks for any information you have!!!! :D
Old May 31, 2004 | 05:46 PM
cgrx's Avatar
DRIVEN
it is probably so "un-senstive" (can't be a word) that it might as well be off...
Old May 31, 2004 | 08:28 PM
sferrett's Avatar
Whaaaa?
You should just give it a try - set the alarm then see if you can get it to go off by kicking the tires or knocking on the glass - or try swaying the car a bit. You should easily be able to determine at what threshold it's now set to.
Old Jun 1, 2004 | 06:07 AM
rx8cited's Avatar
Senior Member
If you want to test at home and are concerned about disturbing the neighbors, do as I did and pull the horn fuse (#23 in engine compartment fuse box) during testing. You still be able to tell from the flashing hazards when you've tripped the alarm. I had better luck and less hand pain tripping the alarm by hitting a tire compared to hitting glass.
rx8cited
Old Jun 1, 2004 | 11:44 AM
TwoZooms's Avatar
There is a small, red LED on the sensor unit (there is on mine, anyway) that will illuminate when the unit senses a shock. When you turn the white dial, you can see how sensitive the setting is by tapping on the side of the unit. I have mine turned all the way down (i.e., the least sensitive setting) -- I can still make the red light go on, but I have to tap the unit pretty hard.
Note that the alarm itself will not go off when the door is open.
Hope this is helpful.
Old Jun 1, 2004 | 02:46 PM
rx8cited's Avatar
Senior Member
Originally posted by TwoZooms
..... I have mine turned all the way down (i.e., the least sensitive setting) -- I can still make the red light go on, but I have to tap the unit pretty hard.......
So what has to happen outside the car to trip the sensor? Land a 747 on top of it? :D
Old Jun 1, 2004 | 04:20 PM
Loaded8's Avatar
yeah !!!! experts to the rescue.... all great ideas and I feel full of knowledge now!!!! Thanks!!! :D
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Paul_Y
Sep 21, 2015 02:23 PM
yankeepicker
Sep 11, 2015 05:42 PM
Anthony Kevin
Sep 7, 2015 07:36 PM
