Does RX-8 Have Passenger Sensors?
Old May 27, 2004 | 01:04 PM
Hard 8's Avatar
Senior "Member"
I'm reposting to make the subject heading better (my edit didn't take).
Does the RX-8 have anything like
this?
Mazda Advanced Restraint System (MARS)
The MAZDA3 and 2005 Tribute have one of the most advanced front airbag systems in the industry. Designed to maximize driver and front passenger protection while minimizing the risk of air bag related injuries, each front airbag has a dual inflator system that matches the level of deployment to impact and passenger conditions. In general, a low impact will ignite one inflator and a high level of impact will ignite both inflators, which deploys the bags with a greater level of force. But before this happens, several sensors are involved to determine if the bags should be deployed at all.
There is a pair of weight sensors under the front passenger seat above each seat rail. Load placed upon the seat is converted into an electric signal by a strain gauge within the sensors, and this signal is sent to the seat weight sensor control module located below the seat cushion center, which calculates the weight based on the signals from each sensor. This information is then sent on to the SAS control module. If the weight upon the seat is less than 66 pounds, the passenger airbag simply will not deploy. Nor will the seat pretensioners or side airbags if the vehicle is so equipped. When the passenger seat sensors detect weight on the passenger seat that is greater than zero or less than 66 pounds, a Passenger Air Bag Off warning light will activate in the center console for six seconds after the ignition is engaged to inform you that the passenger side air bag is deactivated.
It doesn’t stop there. A sensor under the driver’s seat monitors its fore and aft position to determine if the driver is a safe distance from the steering wheel air bag. The sensor consists of a metal plate on the slide seat track that will slide through a groove in a fixed sensor if the seat is moved up to a position for the airbag to be deployed safely. When the metal plate is within the fixed sensor’s U-section, a circuit is complete and the SAS sensor knows that the driver’s side air bag should not be deployed.
In addition, the SAS control module monitors if the driver and front passenger seat belts are buckled. If not, (and the passenger seat is occupied) the threshold by which the air bag will deploy with greater force is lowered to attempt to compensate for the unrestrained body. If this sounds like a reason not to have to use your seat belt, it is not, as using your seat belts allows the air bags to operate in a more nuanced and balanced fashion.
And then there are two crash zone sensors: one in the very front of the car and another in front of the cabin. The system works like this: In the event of a frontal impact the two sensors use their relative positions to determine the impact’s angle and severity. This information goes to the SAS control module which already knows the driver position and the weight of the front passenger. The module processes all the information based on a set of mapped-in logic and then determines if the airbags should activate at all, and if so, how forcefully each bag should deploy.
When an air bag inflator is given the signal to deploy, the igniter builds up heat and ignites a combustion agent. This, in turn causes the combustion of a gas-generating agent which releases nitrogen gas. The nitrogen is cooled through a filter and then injected into the bag. The fabric of the bag is ventilated so that the bags quickly deflate after cushioning impact of the driver or passenger.
Or this (for the Acura RL):
Sensors in the front passenger's seat determine the occupant's height and seating position. If the occupant is of small stature and leaning into the side air bag deployment path, these sensors will prevent the side air bag from deploying. Automatic seat-belt pretensioners are also standard on both front belts for added occupant protection.
_____________________________________
Also, does anyone know, what is the lowest height/weight recommended for the RX-8 front passenger seat? The standard "twelve years old" cut-off seems very imprecise to me.
Thanks.
Old May 27, 2004 | 01:22 PM
ptiemann's Avatar
I pondered a similar question yesterday.
Picked up a Chevy Silverado, rented for a week and noticed how a display the mirror said "passenger airbag: OFF".
Then my girl got in the truck and the display said ".. ON".
I guess she's big/ heavy enough to be detected by the sensors, LOL
Another cool gadget in the truck was a digital compass, also displayed in the mirror.
I too would like to see your q? answered.
-Peter
Old May 27, 2004 | 01:37 PM
zoom44's Avatar
well if it did then i think the little circle next to the glove compartment would light up like in this photo from rotarynews.com. it was taken during their pre-prod drive at Laguna Seca. i believe it does this in other countries but have no proof.
Old May 27, 2004 | 02:44 PM
Gord96BRG's Avatar
My understanding is that in other countries Mazda provides a passenger airbag on/off switch - that picture is either the switch itself or the warning light for the switch.
As far as I know, the RX-8 does have sensing for the seat position and dual-stage airbags. There are technical papers and highlights around here somewhere that may cover this in detail.
Regards,
Gordon
Old Jun 2, 2004 | 03:56 PM
Hard 8's Avatar
Senior "Member"
* bump *
Thanks, Gordon.
I did a search but came up dry. I'm still wondering if anyone has any specific information on this issue:
(1) Sensors on the front passenger seat; and
(2) Correct height/weight for children sitting there.
TIA.
Old Oct 24, 2005 | 12:06 PM
Hard 8's Avatar
Senior "Member"
Bump.
Old Oct 24, 2005 | 01:07 PM
StewC625's Avatar
Insanely Yellow
I for one am glad for the sensors - there's so many times I've wondered if I had a passenger in the car ...
Old Oct 24, 2005 | 04:21 PM
Hard 8's Avatar
Senior "Member"
Haw. I think you're missing the point, Stew. The idea is it adjusts the airbag force based upon the passenger size, and doesn't deploy if no one's there. Good idea, IMHO.
Old Oct 24, 2005 | 04:23 PM
NomisR's Avatar
Wouldn't it be better to not have them at all? Seat belts, roll cages and helmets are better IMO... running into an airbag is like doing this ...
Old Oct 24, 2005 | 04:43 PM
KYLiquid's Avatar
Oil Injection
the manual airbag on/off switch is required by law in all 2 seat cars.
i personaly am not so sure about the sensors, if I have a crash I want the airbag to go off, I dont want the computer to decied the airbag might hurt me (law suit against mazda) and not go off.
Also, I dont think cars should start or run at all with out the all the people in the car wearing their seat belt....and I mean have it on, not just buckled in.
Old Oct 26, 2005 | 01:17 PM
guy321's Avatar
Humpin legs and takin nam
I don't know what info you are looking for but I do know that the seatbelts in the RX8 have a sensor that sends information to the ABS system. So it knows when the passenger/driver uses thier seatbelt.
Old Oct 26, 2005 | 01:18 PM
Hard 8's Avatar
Senior "Member"
Thanks for a very informative and thoughtful post, Cool Blue. I think it was all directly on thread, for my purposes. (Too bad the RX-8's airbag system is not as avdanced the the Mazda3, in terms of sensors. )
BTW, my kids are 11, 8 and 6, and your research helps confirm that the younger two are too small for the front seat of my RX-8, if I'm to err on the side of caution as I should.
My 11-year-old daughter is 5' 2" tall with long legs, so she's as large as many adult women and I have no problem with her in the front seat.
Old Aug 10, 2009 | 10:36 AM
silencer_tk's Avatar
S2K ---> RX-8 = still 9K
So I installed Power Seats and have been getting Error Code C1981 Driver Side Seat track positon sensor circuit open. We messed around with the wires in order to get power to the seats and operate it. I'm thinking maybe we reconnected some wires wrong, back into the connector?
What the heck is goin on? Does that mean I missconected some of the wires? Where's the Sensor located, and where are the wires for it?
My Airbag light is driving me nutz....!
Old Aug 10, 2009 | 10:58 AM
rodjonathan's Avatar
silent assasin
as for the sensors i think the newer models have em but the 04 and 05 model years didnt but im not 100% sure im usually the only one im my car and my gf so i dont really care coz the airbad deploying in case of an accident wouldnt hurt either of us ...
Old Aug 10, 2009 | 11:27 AM
jsjjr's Avatar
His 8
The '06's have them. When my sons ride shot-gun, the light comes on. Otherwise, it's off..
Old Aug 10, 2009 | 12:35 PM
I'm not sure what year the seats are out of, mine's an O5. I got the error once the seats are installed. If the 05's didnt have the Seat Track Pos sensor, how would the car be expecting a Value?
I'm trying to figure out if one of the wires is connected wrong, where the sensor is, if i can trick it or bypass it somehow...
I won't pass inspection here, with the airbag light on...
Old Aug 10, 2009 | 01:12 PM
04RX8man's Avatar
Rotary Powered Countryboy
Holy Thread Revival BATMAN!@!!
Old Aug 10, 2009 | 01:55 PM
better then openin a new one right...?
Any ideas where the little sensor might be? What it looks like, or where the wires for it are?
Old Aug 10, 2009 | 01:59 PM
deadphoenix52's Avatar
meh.
at least he searched
Old Aug 10, 2009 | 02:39 PM
ken-x8's Avatar
Yeah, but it was useful to see Cool Blue's post. Explains why he reacted badly in a different thread when I said that the '06s do have a passenger sensor and "air bag off" light. Never knew the ordeal he went through researching it for his earlier model. Really good guy... I miss his posts. Hope he's having a good time deer hunting.
Ken
Old Aug 10, 2009 | 03:06 PM
tmak26b's Avatar
My 06 has a light next to the dash to indicate if the airbag is on or off. Today I had a 19" tire sitting on the passenger seat with no seat belt, the airbag light up
Old Aug 10, 2009 | 03:26 PM
Kaiser bun's Avatar
Yeah Sioux Sioux!!!
awhile ago i had a fairly small petite woman in my car and she had the seat wayy up for my friend in the back, and the light came on. Then again i don't recall wheather she was wearing a seat belt or not so maybe it was a combination of the two things... too close and no seat belt, or maybe just no seat belt turns it off... not really sure.
Old Aug 10, 2009 | 03:50 PM
CyberPitz's Avatar
Huge hole is huge
Whenever I put my computer in my passenger seat for LAN parties, the light comes off that the Airbag is off.
