speedometer
Old May 26, 2004 | 04:50 PM
LiL BenNy's Avatar
Bubblicious? DEF.
speedometer
does anyone not liek the speedometer? i dont have a problem with it but i was just curious could it be changed to a reg one? istead of the digital one?
Old May 26, 2004 | 05:09 PM
robertdot's Avatar
Shortly after the first '8s got off the truck at Trussville Mazda, I stopped by. I had a discussion with some old guy there. He was pissing and moaning about how distracting digital speedometers were. He said he'd rather read angles. He said he didn't mind if it were digital as long as it was a needle instead of numbers.
Having driven an '85 New Yorker (just 4 years younger than I am) when I was 16, I'd delt with digital speedometers. I'm sure at some point in history, they could be annoying as they probably had no "change buffer", so they constantly updated. Now-a-days, they buffer before changing to the next reading, so that they aren't so distracting.
As far as an analog replacement, I'm sure there are some "generic" gauges that you could use. I don't reckon they'd fit in the same spot as the digital spot. You'd have to mount them externally. I've also seen digital analog ones like on the "mazdaspeed" nav unit that was on one of the threads here. I guess it depends on what you want.
In short, I'm sure you can replace it. I'm sure you can hack it into something elegant if you wanted to spend the time. To me, it's not worth the effort, but to each his own. But I'm one of those people that have to think about what they are reading when they look at an analog clock.
drebbrnator
Dec 27, 2018 07:02 PM
stickmantijuana
10
Oct 27, 2015 04:11 PM
dafiltafish
Aug 21, 2015 06:56 PM
SIllver
Aug 1, 2015 07:34 PM
PlayInMyWoods
Jul 27, 2015 08:33 PM
