View Full Version : The Smoother Solution?
P00Man
03-01-2003, 05:40 PM
Which do you think is smoother, the smoothest of the smooth piston engines, or a rotary like the renisis?
________
Marijuana Sativa (http://strainindex.com)
wakeech
03-01-2003, 06:08 PM
this has to do only with the amount of imbalance you find in the reciprocation. because it's so much easier to balance so many fewer parts, and the reciprocation is slower at all rpm, i'd wager you could make a wankel much smoother than a boinger. but of course, that's a pretty tough thing to say, eh?
P00Man
03-01-2003, 06:19 PM
i mean as of right now
________
IOLITE VAPORIZER REVIEW (http://iolitevaporizer.net/)
wakeech
03-01-2003, 07:15 PM
hard to say... the wankel design, as i said before, would probably be easier to make smoother, but there are tons of engines at a far higher level of refinement in design and manufacture.
probably, the smoothest engine would be some rediculously expensive ultra-luxo V12 or something... like the one in the big new Merc or something.
P00Man
03-02-2003, 10:22 AM
word, or the BMW 760's or like rolls and bently's and maybachs and such, the lex's, those things are crazy smooth.
________
Toyota Fj Cruiser (http://www.toyota-wiki.com/wiki/Toyota_FJ_Cruiser)
cueball
03-02-2003, 10:59 AM
You also have to understand that the rotary is meant as a sports car engine. If you compare it to other sports car engines, it is probably the smoothest around. The only thing that might come close in the sports car world it the BMW inline 6.
wakeech
03-02-2003, 02:02 PM
touche!! :D
RX - 8
03-02-2003, 04:20 PM
-agrees
cueball
03-02-2003, 04:41 PM
Originally posted by wakeech
touche!! :D
How so? I didn't mean to make it offensive to you.:)
ProtoConVert
03-02-2003, 05:55 PM
I think it depends on how heavy you make the flywheel... if you make it heavy enough then any engine should be pretty smooth.
Do rotaries have flywheels?
wakeech
03-02-2003, 06:02 PM
yes definitely... everything from the outputshaft back is exactly the same...
...but i'm unsure about the dampening effect of the flywheel... it seems, at first glace, like it would influence it, but, i'm unsure...:confused:
CraziFuzzy
03-02-2003, 06:52 PM
Any extra inertia to change (like a heavier Flywheel) will result in a dampening effect to Rotational Speed variations. The heavier the flywheel, the more forces it would take to make the engine vary speed. However, this would not necessarily affect the level of vibration in the engine, as this is caused by off-balance components being forced to spin on an axis that isn't exactly their center of gravity. The more balanced, the less lateral vibration. However, even a perfectly balanced engine will experience some vibration based on the shifting torques caused by uneven forces (each cylynder firing at different times)... Well, with the exception of a turbine... it has a constant force... These are the vibrations that a heavier flywheel can smooth out...
SA22C
03-02-2003, 10:18 PM
I read in one article or another that the Renesis's rotors are manufactured with the highest precision yet, so I would think that it will be even smoother than the current rotaries. I look at it this way: I can rev my 1979 12A powered RX-7 up to 7 grand and not notice if I'm not looking at the tach. This coming from a twenty-five year old motor! So if the Renesis is smoother than that, then it'd probably give a V-12 a run for its money.
R.Cade
03-03-2003, 06:09 AM
To demonstrate to a group of reporters the reduced vibrations of the new engine, testers placed a glass of wine atop an engine, then revved it to 5,000 rpm, which they said would be the typical speed on a Japanese highway.
The wine barely rippled.
http://autoweek.com/cat_content.mv?port_code=autoweek&cat_code=carnews&loc_code=index&content_code=06497471
m477
03-03-2003, 09:04 AM
The only inherently balanced piston engine is the inline 6 (and also V-12 as it is basically two I-6s joined together). All other piston engines require the added complexity of parts like balancer shafts to try to reduce their inherent vibration.
Although I wonder how an M3 engine at 8000rpm would compare to the RENESIS at 8000rpm. I'd bet the rotary will be a little smoother at high rpms, but we'll have to wait a few months to find out...
evel333
03-03-2003, 09:38 AM
touche!!
I think he was saying "too-shei" not "tuh-chee." It's a respectful gesture to another when they make a great counterpoint. Correct me if I am wrong, wakeech.
P00Man
03-03-2003, 07:58 PM
you are indeed correct. it derives from fencing, where the french, "touche" accent on the "e", means that your opponent has scored a touch - it actually means "touched" directly translated.
________
Vermont medical marijuana dispensary (http://vermont.dispensaries.org/)
