View Full Version : Thrust Bearing noise
Wozza 05-23-2004, 01:48 AM Hey guys had the car two weeks and Ive noticed quite a loud thrust bearing noise its very noticeable from outside and in the cabin
whats the norm?
any noise at all or do they moan ?
Im going back to the dealer and I just want some advice if I should push the issue to change it or not ?
w2aew 05-23-2004, 10:49 AM Probably normal. By the way, it isn't the throwout bearing, it is the transmission input shaft that you are hearing. You'd hear the throwout bearing only when the clutch is depressed, because that's the only time that the bearing is in use. When the clutch is released, the throwout bearing shouldn't be touching the clutch diaphram, and thus not making any noise.
The input shaft does make a little noise. - all of the Mazda's I've had were similar.
Wozza 05-23-2004, 11:01 AM thanks:)
Maximus 05-23-2004, 12:02 PM why is this noice considered "normal". I haven't heard this noise in some other manual transmissions i been driving in past. Why cant it be FIXED?
epitrochoid 05-23-2004, 05:49 PM would you consider the absence of cylinders normal?
no, it's just different, it's the way it is. i dont understand why everyone is up in arms about the noise.
Kel Rx8 05-24-2004, 12:23 AM been use to it for the past 7-8 yrs
Maximus 05-24-2004, 12:24 AM because it is irritating.
epitrochoid 05-24-2004, 12:47 AM really, how often are you sitting in your car at idle? mine isn't hardly loud enough to be heard over the motor while cruising. i cant even hear it over the AC fan
Wozza 05-24-2004, 04:19 AM Well probably right but I can hear it while I drive only the radio
kills it . The loan car I had had more K's on it and it wasnt on that one and I test drove a car with 10k and it wasnt noticeable there
either.
But It could be me as you get used to a car you start to hear all the little noises so I'll ask the newbie question from the dealer and see what I get
:D
Atacdad 05-24-2004, 10:08 AM Originally posted by epitrochoid
I have to turn the stereo on, or put the windows down in 5th an 6th because the transmission whine is irritating when cruising...particularly 5th. None of my previous manuals have had this level of noise.
But, as someone posted...I'll get used to it eventually, or I'll get rid of the car.
epitrochoid 05-24-2004, 10:31 AM mine's not nearly that loud, so mayube you should get it checked out.
but also, have you owned other rotary manuals? you might be mistaking sounds from the motor as coming from the tranny. since our motor are halfway in the tranny tunnel anyway!
RotorMotor04 05-30-2004, 09:06 AM Mine only makes the noise when i am coasting in first gear, then when i depress the clutch it goes way
BasenjiGuy 05-30-2004, 09:48 AM If you have to open the windows on the highway in order not to hear the noise, you have a problem. I'm an ex-rocker and have very sensitive hearing. I can't handle loud cars (or other loud things) any more. I find the RX-8 to be a pretty quiet car. Not as quiet as an IS300, but definitely quiet for a sports car. No drone, highway road noise quiet good considering the 18" tires. I can do 10 hours driving per day in it and I am not hearing- or other wise fatigued at the end of the day.
What I do hear a little of is the transmission turning in neutral while the car is idling. It's barely audible if the windows are up. And, even with the windows down, it's not intrusive.
rotary-convert 06-01-2004, 12:55 AM Same here, the only noise that I come across is the input shaft when I release the clutch at idle.
I showed this to my dealer, he told me that every 8 he has worked on has that noise.
I do get a little bit of gear whine around 2-4 but I reckon that is normal, (it was on my old nissan stanza)
RNS11Z 06-02-2004, 02:34 AM Had the same problem. Took it back and they fixed it. Although we did have to wait for an engineer from Mazda Japan to come down to Aus first.
Maz-Dawg 06-22-2004, 11:07 AM You should not hear any noise when it is in neutral and then goes away when you put in the clutch, My RX8 does that when I first drove it, I made sure I informed the sales manager. I had a 2000 Celica GTS that did the same thing and it was FIXED!. THe Celica was new and had problems too that were also fixed,
From what I gather......the Mazdawg has some problems that may or may not go away or be fixed. I have heard nothing about an 05 RX8 so I am guessing maybe they will drop the car after one year.
I mention RX8 and the sales people cringe and cannot hide it......I am thinking of trading it for a WRX and I only have 300 miles on my RX8.
And to think I traded my 1995 Toyota Supra NA for this.....that Supra was Bullet Proof! but I had 120k miles on it and thought it was time .......it was an automaic and it wasn't a Turbo anyway.
Now I think I should have got the WRX instead, we have a STI WRX but I thought maybe get a standard 5 speed WRX.
I have owned two Mazdawgs before, a protege' and a MX6-GT (Turbo) which both were incredibly awesome and reliable cars! more reliable than the three Toyota Camrys I owned.
If I come upon the Lemon Law threshold, then this time I will enforce it and make them Buy it Back from me and then I will go and pay cash for the WRX since my RX8 is paid in full!
Boozehound 06-22-2004, 11:52 AM Sure... they'll drop the 8... <rolls eyes> and just scuttle all that cash that went into engineering and producing a new platform.
Pilot bearing noise is irritating, but it's VERY widespread, and when you have to replace the clutch someday, make sure you replace all the bearings and you'll be fine. PB noise does not make a lemon.
Gord96BRG 06-22-2004, 12:17 PM Originally posted by Maz-Dawg
Maybe you should pay attention.
There's plenty of threads here on this forum that have discussed the very minor changes due for the 2005 model year. For your information, the RX-8 is meeting Mazda's (aggressive) sales targets to date - in other words, it's selling very well. It's not going to be dropped, that's an incredibly stupid thing to suggest.
I don't know what your problems are with your car, but you don't need to be ignorant about it!
Regards,
Gordon
Maz-Dawg 06-22-2004, 05:43 PM gee I disctinctly remember posting a reply, and Voila! it's gone!
this Noise is not good, it is not acceptable nor do we lower our standards to tolerate it. this board is most likely moderated or supported by Mazda hence the deletion of my previous posting, they made a defective product they need to fix it! I am guessing even with 300 miles on my RX8 I am trading it for a better car a WRX
snap-on 06-22-2004, 06:32 PM http://www.rx8club.com/showthread.php?s=&threadid=7404&perpage=15&pagenumber=3
Gord96BRG 06-22-2004, 08:30 PM Originally posted by Maz-Dawg
No, Mazda has absolutely zero involvement with this forum. We do have our own rules, though, so if one of your posts disappeared it's because you violated them in that post. Official Forum Rules (http://www.rx8club.com/showthread.php?s=&threadid=31680) .
Did you read the thread linked by Snap-On? It's transmission gear roll-over noise, and it's common in many RWD transmissions in an assortment of different vehicles. It's not a defect, it's not a problem. If you can't stand it, then you are most welcome to take a huge loss on your car and buy something more to your liking.
Regards,
Gordon
Maz-Dawg 06-22-2004, 08:55 PM No I did not violate any rules with my post that disappeared.
However I am a former Automotive Engineer and that is total BS about gear noise whizzing in neatrual???
WTF?? the only mechanical connection between the engine and transmission is the clutch and pressure plate and of course you have a pilot bearing and trhow out bearing either or......they make noise when there is a problem, stop trying to fool yourself or kid yourself, this is a major vehicle issue because it is so widespread...
meaning there is so much of it we are resigned into being manipulated into believing that it is something that we have to live with and accept!
BS!! It is not,
I had a toyota celica that did that and it was FIXED! Mazda is going to have to NUT IT UP and take responsibility for a cheap defective part and replace it at no cost,
like I said you have a problem car, and it gets to the LEMON LAW threshold, they buy it back, I get a WRX!
Gord96BRG 06-22-2004, 09:11 PM Originally posted by Maz-Dawg
I guess this situation is a good example of why you're a former automotive engineer.
OK, back to class for you - please study this manual transmission simplified (http://auto.howstuffworks.com/transmission3.htm) page from www.howstuffworks.com .
Yes, the mechanical connection between the engine and transmission is the clutch, pressure plate, throwout bearing. Is the throwout bearing doing anything when the clutch is not depressed? NO. Can the throwout bearing be the source of the noise, then, when the engine is idling, clutch engaged, transmission in neutral? NO. So what is happening when the engine is running, transmission in neutral? The transmission input shaft and layshaft are turning, and there are gears engaged between these two shafts. Note - gears are turning, shafts are spinning - so much for your statement about the mechanical connection between the engine and transmission - that's completely irrelevant, since the transmission is the source of the noise, NOT the connection from the transmission to the engine.
Back to gears engaged, shafts turning. Since the transmission is not under load, the gears can cycle rapidly between having the front faces of the gear teeth in contact and the back faces of the gear teeth in contact. That cycling of contact/pressure points on the gears is what makes the noise while the transmission shafts are turning over in neutral.
Thems the facts, whether you understand them or not.
Regards,
Gordon
rx8cited 06-22-2004, 09:26 PM People, please obey the "Don't feed the trolls" signs :D
rx8cited
Maz-Dawg 06-22-2004, 09:52 PM Well Kiss my *ss!!!
I am a former because it paid shit!, what I do now pays more than twice as much!
how things work, hahahaha yeah my kids use that site when they were in elementary school.
Have you ever changed a clutch??? what? you know a clutch??
BTW it's not a good sign to hear any noise however you want to rationalize it or however you want to minimize it, that's it keep telling yourself it's OK.....
the boogey man transmission noise monster really isn't hiding under your bed!!
Maz-Dawg 06-22-2004, 09:54 PM MEMO To self... block/ignore Gordon and rx8cited.......
Gord96BRG 06-22-2004, 10:16 PM Originally posted by Maz-Dawg
MEMO To self... block/ignore Gordon .......
Yeah, there's a great plan - sign up to a forum, bitch and whine like a baby, refuse to consider any alternatives even when a Mazda certified mechanic (that would be Snap-On) tells you the real solution, refuse to consider logical explanations that make far more sense than the fantasy you hold, swear at the moderators, then block the moderators. You're making friends fast. Shall we just ban you now, or later? ;) :p Please sell your RX-8 quick, so you can "help" your new friends at the WRX forums. :cool:
Regards,
Gordon
Maz-Dawg 06-22-2004, 10:20 PM [/b]mod edit: You have had your warning. This type of abuse of other forum members and moderators is unacceptable. This is your last warning. Next time you will be banned.[/b]
Gord96BRG 06-22-2004, 11:44 PM Originally posted by Maz-Dawg
CENSURESHIP at its finest,
OK MORONS
Maybe you better read those forum rules again, as it's clear you didn't understand them the first time through. Nobody censored your post - certainly not me, as this forum section is not one that I moderate, so I have no authorization to edit posts in this section. I'm not convinced that you successfully posted the message you think was deleted.
Let's be clear - I don't know your car or what noise you experience, so it's entirely possible that your car does have a problem. However, you are making an ass of yourself by first suggesting that Mazda will drop the RX-8 after one year, and even more so by dismissing the very real existence of gear roll-over noise. Gear rollover noise is real, exists to some extent on most or all of our cars, and is not something that the world is making up in some conspiracy against you. Just because you've never heard of it or aren't familiar with it does not mean that it doesn't exist - why don't you consider learning something, instead of being so closed-minded???
Do your own Google search for "rollover gear noise", "neutral rollover noise", or "neutral gear rattle" - you'll find plenty of hits that describe this for various vehicles, including Miatas, S2000s (that both use a similar Aisin 6 speed trans to the RX-8), Mustangs, Vipers (link - see? (http://www.viperclub.org/faq/tsbfaq.html#ngr) , BMWS (another link for your education (http://www.uucmotorwerks.com/flywheel/gear_rattle.htm), and many more . See how you like those, since the howstuffworks link seemed to be too complicated for you to figure this out.
Still think it's a conspiracy, or can you possibly admit that you might have been wrong about the existance of gear rattle?
Regards,
Gordon
Maz-Dawg 06-23-2004, 12:09 AM Canadiens.....
Boozehound 06-23-2004, 10:18 AM Dude, Gord's right - and if he's not right, he's at least attempting to *discuss* it.
Whatever, it's like rx8cited said, "Don't feed the trolls."
rx8cited 06-29-2004, 10:16 PM Originally posted by Gord96BRG
[B.....It's transmission gear roll-over noise, and it's common in many RWD transmissions in an assortment of different vehicles. It's not a defect, it's not a problem. ........[/B]
Just confirming what Gord96BRG said about the noise:
I spoke with a friend today who owns a 2003 Corvette. It has transmission gear roll-over noise similar to what we're experiencing with our RX-8s. He was told by the dealer that it's normal for his car. Apparently it's a lot louder in the Corvette as he can hear it even when his windows are rolled up - so we're lucky.
Two friends who own a BWM 325 and a 330 do not have the gear roll-over noise however.
rx8cited
Purple Helmet 06-29-2004, 11:26 PM Wow, what a thread, the spin doctors came down hard doing damage control, what a rebel!
1984..............
that's funny, hes banned for that, and yet I have read some pretty obscene post about what people would do if they had a vagina post and I found that totally offensive, what this guy said was nothing compared to what else has been said,
SLECTIVE ENFORCEMENT OF CLUB RULES, sad really sad you can be a total pig and wish you had a vagina and joke about it and that itself is totally inappropriate, in psychology its called OBJECTIFYING, or dehumanizing, but make one complaint about a car noise and BOOM your are gone. Makes sense to me.,..... on that note, IF I HAD A VAGINA I WOULD GET A FIST and,...........
Gord96BRG 06-30-2004, 02:01 AM Originally posted by Purple Helmet
1984..............
Wrong - he wasn't banned for anything in this thread. You can't see the other couple of threads he started that were definite violations of forum rules (because those threads were deleted) - but believe me, the forum rules were enforced entirely consistently and appropriately in this case. If you have concerns about how the forum is moderated or rules are enforced, please contact the forum administration.
Thanks,
Gordon
Purple Helmet 06-30-2004, 11:14 AM Ok, so its ok for certain individuals to put the comments that they did in that If I had a Vagina Thread???? that totally destroys your credibility, as those people should be banned as well, that really sends out a message that it's ok to objectify women, and their bodies, we are not ignorant savages and it's not OK to objectify womens body parts......I think the people at Mazda will be very interested in reading that thread.....
Gord96BRG 06-30-2004, 04:32 PM Originally posted by Purple Helmet
Ok, so its ok for certain individuals (blah blah blah)
I believe I suggested If you have concerns about how the forum is moderated or rules are enforced, please contact the forum administration.. THIS particular thread has absolutely NOTHING to do with that Lounge thread you are referring to. If you have a concern about posts in THAT thread, please use the "Report this post" button from THAT thread to alert THAT forum's moderators about your concern.
If you believe that posts in THAT thread are violating the forum rules, then by all means alert the moderators about THAT thread. Whining over here in this thread has absolutely no impact. I would like to remind you yourself to review the forum rules regarding criticism of the moderators and reporting posts - we willingly discuss your concerns in private.
Regards,
Gordon
