louis1128
05-20-2004, 10:15 PM
when I turn on A/C on my 8 , RPM goes low. and cause a little virbrate, and then the RPM goes back up again anyone has this problem?
any advise?
any advise?
View Full Version : when A/C on, RPM goes low? anyone has this problem? louis1128 05-20-2004, 10:15 PM when I turn on A/C on my 8 , RPM goes low. and cause a little virbrate, and then the RPM goes back up again anyone has this problem? any advise? RotorMotor04 05-20-2004, 10:19 PM I dont know if i have ever experienced this in my 8, but my Celica did the exact same thing w2aew 05-20-2004, 10:33 PM Perfectly normal. The A/C compressor puts a load on the engine when it kicks on, and that causing the change in the idle RPM. MrH 05-21-2004, 10:46 PM When the AC is turned on, you are basically connecting the engine to the AC compressor, putting a load on the engine. The engine then has to compensate, but opening up the throttle a little, so it won't stall and go back to normal idle RPM. |
