pinhole leak - how to fix?
Old May 18, 2004 | 08:55 AM
pmacwill's Avatar
Sponge Bob RotorPants
plug or patch? is one better than the other? I filled my tire up (it was at 28psi) a week ago, then went on travel for work. Its outside at 24 psi. I'm figuring its probably a pinhole puncture and was wondering if it made a difference where and by what means I got it fixed.
Old May 18, 2004 | 07:25 PM
mikeb's Avatar
100% Italian
i say plug
Old May 18, 2004 | 08:19 PM
rx8miami's Avatar
Originally posted by mikeb
i say plug
i concur, for whatever reason there is a huge plug bashing thing thing goin gon and le tme tell you over the last say 14 years I have probably plugged a couple dozen tires/times and never had a problem. plug it!
Old May 18, 2004 | 11:00 PM
mlino01's Avatar
Check your valve stems with soapy water sprayed on em. Might be a loose stem or valve.
Old May 19, 2004 | 10:35 AM
pmacwill's Avatar
it was a screw in the tire. I took it to shell and they said they wouldn't go near performance tires. Then off to NTB. They charged me $40 for a patch. I think patching is the only way to go from what they said at NTB on these tires. Either way, I'm happy again. Except for my squeeking brakes but don't get me started on that again...
Old May 19, 2004 | 12:02 PM
rx8miami's Avatar
just like i said! over did it
Old May 19, 2004 | 12:05 PM
pmacwill's Avatar
maybe that wasn't clear. the squeeky brakes are not a result of getting the tire fixed. its our beautiful brake pads made out of iron.
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
DG07
Sep 28, 2015 10:58 AM
drlubell
Sep 26, 2015 11:58 PM
