My new rims with invisible valves
Old May 16, 2004 | 07:48 AM
cosmos's Avatar
Cool My new rims with invisible valves
There're the Superfast from Barracuda in Hyper-Black-Silver.
Old May 16, 2004 | 07:49 AM
cosmos's Avatar
and a detail of those 'invisible' valves
Old May 16, 2004 | 07:55 AM
cosmos's Avatar
for the rear, 9.5x18 with Potenza S-03 245/45/18
Old May 16, 2004 | 07:56 AM
cosmos's Avatar
and for the front, 8.5x18 with Potenza S-03 225/45/18 (as stock)
Old May 16, 2004 | 08:22 AM
mysql101's Avatar
very nice... what did those rims set you back?
Old May 16, 2004 | 08:55 AM
Razpewton's Avatar
FREE ADVICE!
Yes...I'd be interested to know how much those were...
Old May 16, 2004 | 09:55 AM
6speed8's Avatar
do you still have the tire pressure sensors?
Old May 16, 2004 | 10:31 AM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
..........and how do you fill them up? I take it there is a special adapter or something.
Old May 16, 2004 | 11:55 AM
cosmos's Avatar
hi JasonHamilton,
Sorry for my english, but what do you mean by "set you back" ?
Old May 16, 2004 | 11:57 AM
cosmos's Avatar
We don't have this option in Europe :o
Old May 16, 2004 | 12:01 PM
rudy8's Avatar
Originally posted by cosmos
hi JasonHamilton,
how many rubles...marks...euros...denaros...dollars? :D
Old May 16, 2004 | 12:18 PM
cosmos's Avatar
Ok, I try to translate the french text for you :
"The hidden valve improves obviously the general impression and the design of the beautiful light metal rims. Thanks to its special construction, the valve is protected from the theft, the rim is easier to clean and a loss of pressure by sabotage is avoided. The hidden valve is placed in the hole of the normal valve and does not exceed the surface of the rim. The top of the valve in design "screw" is hardly noticed and it is taken for a component of the rim. To modify the pressure of air, you just release the screw of cover and then screws the provided adapter. Then, you can add or remove air as with a normal valve."
Hopping this explanation is clear enough
Old May 16, 2004 | 12:34 PM
cosmos's Avatar
Ok, I get it
That costed me, all together (rims + tyres + valves + azote + mounting - discount ) CHF 2'900.- corresponding to USD 2'240.00
More precisely,
the 2 front rims : ~ USD 540.00
the 2 rear rims : ~ USD 572.00
Old May 16, 2004 | 02:02 PM
lourx8's Avatar
Early RX8 Adopter
Sweet rims man! Could you not have fitted 245/45/18s in front as well? Or did you just want it to be 225 front and 245 rear?
Old May 16, 2004 | 02:41 PM
Sanguine_Dark's Avatar
Vivid Racing Test Monkey
Cosmos,
Could you take a few pictures from more of an angle so we can get a better look at the awesome lip on those wheels?
Thanx
Old May 16, 2004 | 04:05 PM
cosmos's Avatar
It is possible to have 245/45/18 (with the 9.5x18 rim) in front as well, but I prefered to keep the stock size.
Old May 16, 2004 | 04:11 PM
cosmos's Avatar
Originally posted by Sanguine_Dark
Cosmos,
Thanx
I'll try to take more shoots tomorow (if I found some time left )
Old May 16, 2004 | 08:21 PM
Kel Rx8's Avatar
if your not 1st your last
are you using coilovers
the front is low
nice looking 8
Old May 17, 2004 | 12:03 AM
cosmos's Avatar
No, I just used lower springs from H&R and the car is lowered 45 mm (front and rear)
Old May 17, 2004 | 01:34 PM
cosmos's Avatar
Cosmos,
Thanx
Sanguine_Dark,
As asking, I took some more pictures. Enjoy!
Old May 17, 2004 | 01:35 PM
cosmos's Avatar
Old May 17, 2004 | 06:34 PM
\\Konig\\'s Avatar
turrrbo!
pretty nice rims. At first i didnt really find them attractive, but the more i look at them the better they look...
Old May 17, 2004 | 07:31 PM
mikeb's Avatar
100% Italian
congrats
they look so nice
Old May 17, 2004 | 11:32 PM
SDFLY's Avatar
Ditto
Old May 18, 2004 | 01:45 AM
cosmos's Avatar
I did add this 2 pictures as well, but it seems they disappeared
