Entire system question?
Old May 12, 2004 | 11:17 AM
th1rd3y3's Avatar
05 STi/05 Titan
Well first off I plan or ripping out EVERYTHING bose related except the stock HU. Since I don't want to ruin the look of my dash and lose my steering wheel controls, I want to put an entire new system in my car.
My question is whether or not I could use a line converter to input into an EQ and use the outputs on the EQ to run the amps? I'm personally not a big fan of line converters but would it work for what I want to do, and if so how noticeable would the loss of quality be as compared to a good HU with 4V+ pre-outs?
Old May 13, 2004 | 08:13 AM
th1rd3y3's Avatar
05 STi/05 Titan
no one had ANY opinions on this matter?
Old May 13, 2004 | 08:30 AM
Japan8's Avatar
Int'l Man of Mystery
There are several threads on lin converters and the system... do a search. :D
Old May 13, 2004 | 10:25 AM
th1rd3y3's Avatar
05 STi/05 Titan
That's not what I'm asking. Everyone else uses the converter for an amp, I want to know if it will work with an EQ.
Unless my search function is broken, there are no topics involving this issue. Thanks.
Old May 13, 2004 | 12:01 PM
CraziFuzzy's Avatar
You are sleeepppyyyy.....
A line converter will produce the standard 1Vp-p signal that would go to the RCA inputs on an Amp or a Equalizer, from a speaker level signal (the output of the stock amps). This will work fine either way. If you are looking to remove the stock amps and replace them, you will have to be tapping into the balanced input of the stock amps, and changing that to an unbalanced signal for YOUR amp. I'm not sure if there are any devices that do this easily, but i'm sure there are plenty of people on the forum that have done just that.
CraziFuzzy
gwailo
May 14, 2024 06:57 AM
projectr13b
Mar 1, 2019 09:00 AM
TotalAutoPerformance
Group Buy Center
Sep 2, 2015 01:40 PM
Nisaja
51
Sep 1, 2015 04:29 AM
AussieGray
Jul 16, 2015 03:58 AM
