K&N CAI dress up
Old May 11, 2004 | 11:03 PM
D MENAC 7's Avatar
Moderator with a mycocardium
K&N CAI dress up
I finally got time today to do a project that I posted as a Photo Shop preview in an earlier thread about what I was planning on doing under the hood. This is the next to last project that I previewed. Here is the result of some time off from work:
D MENAC 7's Avatar
Another view:
Old May 11, 2004 | 11:04 PM
D MENAC 7's Avatar
another...
Old May 11, 2004 | 11:05 PM
D MENAC 7's Avatar
One last one
Old May 11, 2004 | 11:10 PM
D MENAC 7's Avatar
Yes, that is a one piece two bends lid. The brown rubber on the sides is a weather stripping that I used to cushion the lid from the sides that are also clear acrylic.
This forces the Intake to take up more air from the original air tube in the front of the stock airbox mount. This tube goes out across the front behind the grilled and then down to the left front lower side of the front grille.
I feel it will get less air from the engine bay and more fresh cooler air from where is it supposed to receive air from. After test driving the sound decreased by very little. That is the only thing I have noticed so far.
Old May 11, 2004 | 11:11 PM
D MENAC 7's Avatar
Originally posted by pidge1114
doesn't that prevent air from getting to the filter? It seems that it would cancel out any gains from adding the intake by restricting airflow with that clear cover?
Besides getting air from the original air passage, there are a lot of other passages to get air from as this is not air tight by any means.
Old May 11, 2004 | 11:13 PM
D MENAC 7's Avatar
There will be a DIY on this soon. :D
Old May 12, 2004 | 12:04 AM
RX-GR8's Avatar
nice job Den. looking forward to the DIY.
Old May 12, 2004 | 02:50 PM
RX8FanMan's Avatar
JRizzle
so where do you purchase this cover? or did you make it? if you did, where do i get the materials
Old May 12, 2004 | 04:40 PM
mikeb's Avatar
100% Italian
looks very nice
I want one
Old May 12, 2004 | 07:34 PM
rx8_250f's Avatar
what did you attach it to?
Old May 12, 2004 | 07:43 PM
Formula 420's Avatar
SomebodyMust'veDruggedMe.
Dennis, i see small dollar signs in your near future......
you should make a package with all your mods and sell it. when you get some more.
also, are you going to incorperate this into your avatar?
Old May 12, 2004 | 08:34 PM
D MENAC 7's Avatar
I fabricated it myself. The materials can be obtained from just about anyplace that sells glass. The process isn't easy unless you have worked with acrylics. I learned this in 7th & 8th grade shop class (mandatory). You have to know how to heat it up and bend it, most of the cuts were on a table saw, a band saw or scroll saw would work too. There was considerable measurment and fitting involved, what I have there isn't perfect but it looks good. The materials cost about $50 total but the butane torch I bought cost $25, the rest of the tools I already owned.
I attached the sides to the existing K&N heat shield sides. I used 3M trim tape to adhere it. I will be posting this information in the DIY, I just want to get the measurements down and some details before posting it first. The top stays put due to the rubber door gasket material and the prop bar for the hood keeps it from moving forward.
Hadn't planned on it, if I start selling too much, I may have to purchase a vendor's permit on here. :D If that were the case, I could probably afford it then because this wouldn't be exactly too cheap because it is labor intensive.
Right now, I have no plans except to post a DIY on it. And after I do if I find someone selling them on ebay...grrrrr LOL I'll just cut the price so low they will stop like what happened to the other guy who did that on there.
Old May 13, 2004 | 08:11 AM
do you have a strip heater for bending plastic?
Old May 13, 2004 | 10:16 AM
D MENAC 7's Avatar
No, I actually bent it by heating it up with a small butane torch as it set on the metal edge of my saw table. A strip heater, huh? Well, if I ever get somthing going, I would have to look into that. Thanks.
Old May 13, 2004 | 04:34 PM
it's mad easy, you put your plastic across it and line the heat strip up with what you want to bend. it will kinda go up at the edge, and when it goes down agqain, take it off and bend and hold it until it cools. works gresat.
Old May 13, 2004 | 06:22 PM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
More importantly didthat CAI give you any gains
Old May 13, 2004 | 07:04 PM
D MENAC 7's Avatar
Just about any CAI will produce very little gain in HP on the RX-8. They did such an excellent job on the stock one, there isn't much to be gained, other than looks and sound. That is about all it makes a difference in. I've never seen a dyno with the intake of any brand in comparison with the stock.
Old Sep 19, 2004 | 12:11 AM
Liquid Rhino's Avatar
Keepin' It Real Since '79
Red face I know I'm a little late, but....
D, that is one SICK piece of work!!! Mad props, very clever and original.
Old Sep 19, 2004 | 06:09 AM
blksf8's Avatar
Dennis, PM me if you can make anymore. I am interested in one, but probably aluminum if you can make it. I need to muffle some of the sound as the intake hit 100db at the track. thanks
Zube6115
Sep 30, 2015 12:57 PM
Forevermore
Sep 20, 2015 01:04 PM
