NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
Anyone from VA beach w/ clear sidemarkers?
Old May 8, 2004 | 09:40 PM
umpuck's Avatar
Just curious if it's legal or not
Old May 8, 2004 | 10:37 PM
Rotary Nut's Avatar
"...I'm a Dapper Dan man"
They're legal as long as they flash with an amber color.
Old May 14, 2004 | 08:55 PM
RaceBannon's Avatar
Yep- as long as they're yellow.
Old May 16, 2004 | 12:46 PM
P-Rock's Avatar
no
I am sorry but I looked in to this and they are not legal. the way it was explaid to me by a cop (cop in the family), they look like they are broken so it is an inproper eqeptment ticket. it dosen't even mater if you have the amber bulbs. Sorry guys.
Old May 23, 2004 | 07:03 AM
Josh's Avatar
I pull out the BS flag on that! If I get my scanner working Ill scan in the actual regulation on it. It states that as long as the turn signal puts out a amber color that has a reflective amount of --% (sorry ill pull out the regulation later for that number)... I know this because i went to the local precient (sp?) on Kempsville Road and asked them about my clear corners on my Z3. They said they were legal and I asked them to print me out a copy of the regulation.
Besides, some AMERICAN SPEC cars came with them from the factory. ie. the old Nissan Stanza.. (Mid-late 80s car)
Old May 23, 2004 | 10:44 AM
Rotary Nut's Avatar
Cool Code of Virgina!
Here is the Virginia code that refers to the lights and the link to all virgina laws.
Virgina Codes
§ 46.2-1017. Dimension or marker lights and reflectors, generally.
All motor vehicles, trailers, or semitrailers exceeding seven feet in width or the widest portion of which extends four inches beyond the front fender extremes shall be equipped with amber lights mounted at the extreme right and left front top corners of such vehicle. Each such light shall be visible in clear weather for a distance of at least 500 feet to the front of such vehicle. Such vehicles shall also be equipped with red lights mounted at the extreme right and left rear top corners of such vehicle. Each such light shall be visible in clear weather for at least 500 feet to the rear of such vehicle. Any tractor truck, however, need not be equipped with rear red dimension or marker lights. If the front or the rear of such vehicle is not the widest portion of the vehicle, the dimension or marker lights required in this section shall be mounted on the widest portions of the vehicle with the amber lights herein required visible from the front as herein required and the red lights herein required visible from the rear as herein required. The lights herein required shall be of a type approved by the Superintendent.
In addition to the lights required in this section, each such vehicle shall be equipped with amber reflectors located on each side thereof, at or near the front. Red reflectors shall be used on the rear of each such vehicle. Such reflectors shall be securely fastened to the vehicle not less than fifteen inches and not more than sixty inches from the ground. For a vehicle that is less than fifteen inches tall, however, such reflectors shall be securely fastened thereto at the highest point the structure of a vehicle will permit. The reflectors shall be of a type approved by the Superintendent.
If any vehicle is so constructed as to make compliance with the requirements of this section impractical, the lights and reflectors shall be placed on the vehicle in accordance with the Superintendent's regulations.
If any vehicle required by this section to be equipped with dimension or marker lights has installed on its rear, as close as practicable to the top of the vehicle and as close as practicable to the vertical centerline of the vehicle, three red identification lights of a type approved by the Superintendent, with the light centers spaced not less than six inches or more than twelve inches apart, the rear dimension or marker lights may be mounted at any height but must indicate as nearly as practicable the extreme width of the vehicle.
(Code 1950, § 46-271; 1952, c. 652; 1958, c. 541, § 46.1-265; 1960, c. 156; 1974, c. 218; 1977, c. 383; 1989, c. 727; 1997, c. 23.)
Old May 23, 2004 | 11:16 AM
Josh's Avatar
Good call but only one problem.... Read the very first sentence!!!
All motor vehicles, trailers, or semitrailers exceeding seven feet in width or the widest portion of which extends four inches beyond the front fender extremes :D :D
Old May 23, 2004 | 11:22 AM
Josh's Avatar
hey great find though... if you run through a couple more you find more applicable info.. Its not exactly what I had read but its closer.
§ 46.2-1039. Requirements of turn signals; regulations.
Every turn signal used to give a signal of intention to turn a vehicle shall be so constructed and so installed as to give a signal plainly visible in clear weather and under normal traffic conditions from a distance of at least 100 feet to the rear and 100 feet to the front of the vehicle. No front turn signal, however, shall be required on vehicles manufactured before January 1, 1943.
The Superintendent may promulgate regulations not inconsistent with this section and § 46.2-1038 governing the construction, location, and operation of turn signals and the color of lights which may be used in any such signal device. Nothing contained herein, however, shall prohibit the requiring of turn signals on any vehicle whose driver is prevented by any reason from giving the hand and arm signal required in § 46.2-849.
(Code 1950, § 46-303; 1958, c. 541, § 46.1-299; 1962, c. 89; 1968, c. 99; 1972, c. 445; 1974, c. 347; 1979, c. 44; 1989, c. 727.)
And one about parking lights
§ 46.2-1037. Lights on parked vehicles.
Any vehicle parked or stopped on a highway, whether attended or unattended, between sunset and sunrise shall display at least one light projecting a white or amber light visible in clear weather from a distance of 500 feet to the front of such vehicle and projecting a red light visible under like conditions from a distance of 500 feet to the rear. No lights, however, need be displayed upon any such vehicle when legally parked.
(Code 1950, § 46-282; 1958, c. 541, § 46.1-276; 1959, Ex. Sess., c. 86; 1989, c. 727.)
Old May 23, 2004 | 11:31 AM
Rotary Nut's Avatar
No, it refers to All motor vehicles, trailers and semitrailers that exceed. The last part is refering to the size minimums for the trailer itself.. The excedding part is specificly refering to the trailers not the all motor vehicles part.
rx8gator
Jun 16, 2007 03:35 PM
