Stock airdam...what is this made of?
Old May 7, 2004 | 11:17 AM
D MENAC 7's Avatar
Moderator with a mycocardium
Couldn't figure out where else to post this, so if it gets moved, np. I am repairing a stock Appearance package air dam. I'm nearing the end but want to get smething that will finish the surface better than the method I have been using.
However, I would really like to know what this material actually is. Is it Polyethylene, Thermoset Polyurethane, Thermoplastic Polyurethane, Thrmoplastic Elastomer, Thermoplastic Ether Ester Elastomer, Polypropylene or somthing else? Any clues?
Old May 7, 2004 | 05:19 PM
Ned M's Avatar
Am pretty sure Mazda are users of Metton LMR (Liquid Molding Resin), which is a plastic. Here's a link to the Metton website:
Painting Metton LMR
Old May 7, 2004 | 09:25 PM
D MENAC 7's Avatar
Not sure if that material is correct. However, I have no proof it isn't either but I do not think that this material will do the chalking that is decribed in the Bonding and Painting section.
Old May 8, 2004 | 01:21 PM
D MENAC 7's Avatar
Old May 9, 2004 | 08:01 AM
Ned M's Avatar
I quoted Metton LMR because of a post under the Trussville Mazda section re: material the Mazdaspeed RX-8 body parts are mfr'd from. No reason to believe they're dissimilar to the OE pieces, but you might try contacting the guy who moderate's Trussville's section on this forum. Good luck.
Old May 9, 2004 | 05:43 PM
D MENAC 7's Avatar
Thanks, I'll get hold of them and see if there is a definate answer on that. It would be nice to know for any repairing of the sort I am doing.
Old May 10, 2004 | 10:02 PM
Japan8's Avatar
Int'l Man of Mystery
Look at what they have posted under japanparts.com. I think it's polypropylene.
Old May 10, 2004 | 10:45 PM
D MENAC 7's Avatar
Thanks, that helps a lot as to what materials that are needed to bond with it. It still needs to be heated together with some filler material in it that is able to bond with this material.
Brettus
Series I Engine Tuning Forum
46
Apr 19, 2024 06:28 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
