Subs + Amps = Weight Distribution Offset
Old May 6, 2004 | 10:29 PM
TPNova1's Avatar
I'm planning on starting my sound system project any day now. It will be two custom enclosures behind the taillights for JL 12W3s'; and a amp rack in the back of the trunk against the seats holding a 700 2Ch, and a 400w 4Ch, and a 1Farod Cap.......Hmmmm, what would be the thoughts on how this equipment will affect the handling performance of the machine? Seemingly- with this gear, I still want to be able to take turns as stable as we are taking them now. Any ideas.....the measurements are set, work will be started soon.
Maybe if anything, it would even the 51/49 ratio out a little bit being that the front is very slightly heavier when stock.....
Old May 6, 2004 | 10:46 PM
jonnyb's Avatar
you wont notice a difference.
why are you getting a cap?
Old May 7, 2004 | 05:41 PM
TPNova1's Avatar
Why a Capacitator? Simply so there is no major drain on the
battery or stock 100amp alternator.
Old May 7, 2004 | 06:08 PM
mikeb's Avatar
100% Italian
yes^^
Old May 12, 2004 | 08:26 PM
Bob The Eskimo's Avatar
I have noticed an easier rear wheel squeal when turning from a stop and flooring it. Only at the end of the turn however. Immediately after touching the wheel and the gass it grips better. I think the + and the - off set one another.
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
hufflepuff
May 30, 2016 10:45 AM
Learners_Permit
Sep 27, 2015 07:38 PM
