Mazdaspeed Front Bumper Oil Cooler/Brake Ducts?
Old May 5, 2004 | 01:31 PM
djmano's Avatar
RX-8 Pilot
i have been looking around the mazdaspeed japan website and found a nifty piece that goes into the gaps left for the oil coolers. it is two plastic pieces that direct airflow into the oil coolers more efficiently. however.....there list price is very expensive, around $500.
if anybody could make a plastic/carbon trim piece to possibly fit inside the oil cooler gaps id be most interested in purchasing one. or maybe somebody can develop a similar product but with a design that can cool the brakes down as well?
Old May 5, 2004 | 01:54 PM
ranger4277's Avatar
Cones need lovin' too!
I thought the MS kit came with those attached to the front fascia.
Old May 6, 2004 | 12:26 PM
djmano's Avatar
RX-8 Pilot
the real one might........i have a replica from rotary extreme.
Old May 6, 2004 | 12:39 PM
gr8rx's Avatar
the mazdaspeed bumper does come with the oil cooler ducts if you get the oem one
Old May 6, 2004 | 02:50 PM
mikeb's Avatar
100% Italian
when did you get the replica
how do you like it?
Old May 7, 2004 | 12:08 PM
djmano's Avatar
RX-8 Pilot
hey mikeb i just installed it yesterday at my work.
im very satisfied with the way it came out. hopefully i can get some pics after i get the b*tch dropppppped on some tein's or espelirs.
Old May 8, 2004 | 03:23 AM
gr8rx's Avatar
I got my bumper a couple of days ago , great quality, fit and finish, easy to install with directions, only thing thats a little tricky is foglights and brackets cause you have to cut some of the oil cooler ducts to get the light brackets in there and the istructions for doing that are a little confusing
Old May 8, 2004 | 04:18 PM
P-Rock's Avatar
ducts
I have made break ducts and an air box duct using drier flex vent tub. only cost 10 bucks and took about 3 hours to cut the plastic with a razor. you have to take the bumper of to go trought three layers of plastic ( oil cooler sepperating wall then the inside finder) the best way to make it go were you want it is by using zip ties.
I feel a little more power from the cold air and i feel less break fad in long runs on the back roads of Va. I am tring to get some pics of that and my battery transfer to the trunk. I will get it done soon.
MsKingRotary
Jan 28, 2016 12:12 PM
Danmn858
Sep 10, 2015 07:42 PM
TheRedRotor
Aug 9, 2015 11:23 PM
ripigs
Aug 2, 2015 10:44 PM
ktec
Jul 29, 2015 01:17 PM
