results of using Renesis rotors in older motors
Old May 2, 2004 | 01:31 AM
rotarygod's Avatar
Here is an e-mail that Dave Lemon from Mazdatrix sent an RX-7 forum member on the subject. Just thought you guys would find it interesting:
We are using RX-8 rotors in one of our SCCA E/Production "street port" 86-91 13B non-turbo engines.
We do no mods to the rotors (except installing the racing rotor bearing).
We are using RX-8 racing ceramic apex seals (the OEM RX-8 steel seals warped too much having to cross the exhaust port).
(There IS enough metal to cut the apex seal groove for either 86-91 2mm seals or earlier 3mm seals -- we are looking into making that service available, but are not ready yet)
The rotors are run "backwards" (front in rear, rear in front) so the angle cut on the side of the rotor gives more intake opening timing (RX-8 uses the cuts for the side exhaust ports).
Do not use the "oil scraper ring" outside the second oil control ring.
DO NOT use RX-8 corner seals -- they DESTROY 86-91 side housings !!!! (use 86-91 corner seals, TRUST ME).
They ARE lighter than 89-91 non-turbo rotors, have higher compression, and are less expensive.
With all of the above said: We have YET to attain even the SAME horsepower on the dyno as we are getting from our race engine(s) using the 89-91 non-turbo rotors !!!
Potentials:
With the RX-8 rotor having the side seal further outboard, we were able to increase the (ported) intake opening timing versus the earlier rotors -- it may be too much ??? (does not seem likely)
Running the rotors with the angle cut for intake opening may also be in the above category.
We always set pre-92 side seal clearance at about .0015 (1 1/2 thou). The SMALLEST clearance we could get, using the LONGEST of the available "pre-sized" RX-8 side seals was about .010 (10 thou), with the worst on this set of rotors of about .016 (16 thou). This gives a much lower "sealing" than we like.
Other than the above, at this time we are not at all sure why the power is less than when using the earlier rotors.
No, we have not done the REAL test -- run the SAME engine on the dyno, and only swap the rotors (backwards, then normal). That equals three builds, and three full dyno on-and-offs + dyno sessions.
Dave Lemon,
Owner of Mazdatrix,
The dyno operator and driver of the E/P car
Very interesting info indeed.
Old May 2, 2004 | 01:35 AM
Omicron's Avatar
Very interesting... thanks!
Old May 2, 2004 | 01:52 AM
wakeech's Avatar
mostly harmless
yeah, i'd figured one of the biggest advantage in using the shorter beam height 13BMSP rotors is that you can have really big ports without the bridge. weird how they're not making more power with it though.
Old May 2, 2004 | 02:01 AM
Japan8's Avatar
Int'l Man of Mystery
Intriguing indeed. Keep us posted on how this goes rotarygod...
Old May 2, 2004 | 02:46 AM
neit_jnf's Avatar
Didn't someone posted recently about using RX-8 rotors, stationary gears and e-shaft on older rotaries in Australia? They said with no other changes they got a big boost in power... hmm
I think they used modified side seals with less clearance though.
Old May 2, 2004 | 03:06 AM
rotarygod's Avatar
I saw that same thread.
Japan8: This isn't my project. It is Mazdatrix's.
Old May 2, 2004 | 10:37 AM
RX-8 friend's Avatar
We may see a lot more of this in the near future. Lots of builders (and especially customers!) are up in arms because Mazda's casting foundery is fully booked making renesis housings. The older housings are all used up and backordered! Lots of people waiting for their engines to be built.
It's a good thing because it shows sales of the RX-8 are going well. It's a bad thing if you own an older model, and toast an engine!
Old May 2, 2004 | 08:02 PM
neit_jnf's Avatar
found it!
https://www.rx8club.com/showthread.p...n+older+motors
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
jackslao
Sep 8, 2015 01:50 PM
Octomus
Sep 3, 2015 11:40 AM
rxwilly8
Sep 2, 2015 02:42 PM
