runs better when cool? how can I keep it cool?
Old May 1, 2004 | 01:04 PM
csuttman's Avatar
From: Jupiter, Florida (sure beats Wisconsin winters!)
I've noticed my rx8 seems to run better & the rotory has better responsiveness when the weather is cool. I live in south Florida... so cool weather is a luxury I rarely see. I've also read thet these rotary's are pretty temperature sensitive. Does anyone have any ideas on how to keep this thing running cooler than it does (that won't degrade the life of the thing, or my wallet)?
I've noticed the grill is mostly solid in the front. Does anyone know of an aftermarket grill that lets more air flow through and has less wind resistance? Or... any other thoughts for me?
Old May 1, 2004 | 01:16 PM
thew's Avatar
Thews8
has it been tuend ? I have owned roterys here in Ca for a while now. MY old RX7 had no problamb with the 105 deg temps in my home town. All summer long ! as for the 8 it should be even less critacal because it has a much better cooling system.
as for in flow of air !! look again. the air intake is really below the grill it's giant! i can stick my whole leg in ther ! and its low to the ground where the air is forced into the rad. you wont get much better cooling than that. Take it in to the dealer. have them reflash it and tune it up ! it should run fine in FLa.
Old May 1, 2004 | 01:26 PM
csuttman's Avatar
Question
I've had it just over a month and have near 2k miles on it. It hasn't been tuned yet. Not sure if I should have to worry about it, being so new. What does the flash do? I've seen it mentioned in other threads that I should get the latest 'M' flash. Is there documentation somewhere or can someone tell me in a nutshell what the flashing may fix/change? And... if I take it to the dealer to have it re-flashed... should this be a freebie because I bought the car there or will they have it in the shop for hours and charge me?
Old May 1, 2004 | 03:17 PM
Rotarian_SC's Avatar
Free Autographed Pictures
Well I have noticed that removing the engine cover keeps it cooler :p
Old May 1, 2004 | 09:53 PM
Mikelikes2drive's Avatar
CAI?
Old May 2, 2004 | 06:50 AM
PhineasFellOff's Avatar
Turn the AC on.
Old May 2, 2004 | 09:04 AM
himitsu's Avatar
I thought its the opposite?... Im sure you know about that cold stop engine flooding problem?
Old May 2, 2004 | 03:55 PM
kellybrf's Avatar
water wetter will help as well. youll have to get it from a performance store such as jegs. any place that sells redline oil should also sell this
Old May 2, 2004 | 07:00 PM
rjacobs's Avatar
Sideways, No not me sir
I think he is talking about the cooler weather not the engine temp. The air your engine pulls in can only be as cool as the outside air unless you use NOS, which is what NOS does it cool the incoming air allowing alot more fuel to be used. When air temp changes your ECU compensates for it and changes the fuel ratio to make it run at its peak. When cooler temps are present air is usually less dense and has less moisture in it. This happens even on forced induction cars and not only on naturally aspirated. My friend had a Toyota Supra TT and when it go cool at night it would run around 15 or 16 pounds of boost, but during the hot 100 degree days we were lucky to get 12 pounds. Engines make more power at cooler ambient temps and there is really nothing that can be done about that.
Old May 2, 2004 | 09:01 PM
csuttman's Avatar
Yes, I did mean the weather. It's very responsive in early morning when temperature is 70 or below and humidity is less than 50%. By mid day when temps are mid to upper 80s and humidity is 90%+, it feels kind of sluggish in comparison. I imagine it is the humidity more that temperature that's the problem. Not sure if the computer knows how to compenate for humidity though or if there's anything that can be done aside from tuning it to run better in higher humidy... which would probable degrade performance when humidity is low. I do only notice it at lower speeds/rpm's though. On the highway at high speeds... it's responsive as ever though.
Old May 2, 2004 | 09:14 PM
csuttman's Avatar
By the way. Water wetter sounds ineresting. Thanks.
Old May 2, 2004 | 11:36 PM
Atacdad's Avatar
Originally posted by rjacobs
I think he is talking about the cooler weather not the engine temp. The air your engine pulls in can only be as cool as the outside air unless you use NOS, which is what NOS does it cool the incoming air allowing alot more fuel to be used. When air temp changes your ECU compensates for it and changes the fuel ratio to make it run at its peak. When cooler temps are present air is usually less dense and has less moisture in it.[snipped]
Actually cold air is more dense, thus you can burn more fuel per charge...but you've got the right idea.
Old May 2, 2004 | 11:56 PM
shawnio's Avatar
actually it's not just that NOS is cooler and more dense, it's that it has more oxygen than the atmosphere does. I think it's N2O vs the atmosphere which is like 80% nitrogen and like 18% oxygen and 2% other gasses. Don't quote me on the numbers, look them up if you really want to know. The fact that NOS comes out of the can much cooler than air is just icing on the cake.
Old May 3, 2004 | 06:02 AM
Charles R. Hill's Avatar
Owner of BHR
You might find that, for performance applications, a 180 degree thermostat and fan switch will give you the performance you are describing. The RX currently has (I think) a 195 degree setup.
Charles
Old May 4, 2004 | 08:30 PM
JimW's Avatar
Re: runs better when cool? how can I keep it cool?
I noticed the same thing as well. Yesterday rained like crazy and the temp dropped. The cool dense air definitely made a difference, I guess our air mass sensor is working good! Now if we can learn how to trick it into thinking it's always cool and dense without detonating!
Old May 5, 2004 | 01:47 AM
VividRacing.com's Avatar
I'm testing out a new PWR racing radiator for just that reason. Just in case no one has heard of them they are imported from Austrailia and have been making rads, intercoolers, and othe cooling parts for a while now. They got thier start fromt the huge racing scene down under and they have since then made there way to the states.
Here in the valley of the sun it gets smokin hot. Temps were at 100 today. We've used PWR radiators in all of our project cars with good success. We let them know we had the car and they sent out a test peice to us. Very nice construction as usual with them. Twice as thick as the stock radiator, fully polished and nice fitment. Also it reuses the stock cooling fans and hose fittings. Installation is a little lteadious but not hard. I'd like to get a better thermostat as well, some thing that opens a few degrees sooner to help out the cooling as well.
So far so good. It's been in the car now for 2 weeks and the temp gauge still sits in the same spot it did in Jan. when the weather was cooler. I will have more to report later as well as when they will be available. If anyone is interested give me a call.
Old May 5, 2004 | 03:09 PM
JimW's Avatar
vividracing, is it possible to make a mod for the Airmass sensor, as this would increase air+fuel+timing= power. This along with the radiator would provide some interesting results.
Old May 5, 2004 | 03:20 PM
Anything is possible though honestly I'm not the one for such a mod. That would be best left to someone who better understood the direct effects of the sensor and how to change it. Good idea though.
Old May 5, 2004 | 08:07 PM
AlexCisneros's Avatar
Empty all the radiator fluid and add either Redline "watter wetter" or Royal Purple "Purple Ice", then top off with Deionized water. No anti freeze (remember guys in in SoFla).
If you really want to improve cooling via stock components, then drain radiator and fill it with NPG+
www.evenscooling.com
Old May 6, 2004 | 12:29 AM
Atacdad's Avatar
I think he meant:
www.evanscooling.com
Old May 6, 2004 | 12:36 AM
MazdaManiac's Avatar
Its an airflow sensor and such a mod already exists.
Its called the Greddy E-Manage.
E-MANAGE INSTALLATION
Old May 6, 2004 | 01:59 AM
rjacobs's Avatar
An airflow sensor mod would maybe kill the engine. If the MAF sensor or what ever it is had a signal saying that the temp was ???? than it would give the engine that signal and give it the wrong amount of fuel, giving negative results to the engine. Wait until a proper cold air unit comes out or wait for a super/turbo charger and your engine will make all the power it needs.
Old May 6, 2004 | 09:06 PM
JimW's Avatar
Thats why you have a mod that mazdamaniac just introduced to us that will control air, fuel and timing for a safe tune. I would guess the that the E-manage is similar to the Canzoomer mod.
Old May 6, 2004 | 09:09 PM
Exactly.
Old May 6, 2004 | 09:10 PM
JimW's Avatar
So the airflow sensor has the capability to measure air density as well as air volume?
