Installed Intake, midpipe; I notice an enormous loss in torque!
Old Apr 30, 2004 | 10:53 PM
IZoomZoomI's Avatar
Boost needed
that makes sense wouldn't the midpipe increase back pressure therefor the loss in torque?
Old Apr 30, 2004 | 11:01 PM
BoxerGT2.5's Avatar
I believe the midpipe would decrease back pressure......less restrictive. Anyone correct me if I'm wrong please.
Old May 1, 2004 | 01:13 AM
RenesisX-8's Avatar
Non-average GearHead MoFo
It would cuase a loss in lower range like you are saying...but midrange should be awesome as well as top end.
Be easy on the throttle during low rpm's and you won't bog it so much...then roll-in quickly as your mid range kicks in....then shift.
Hope I've helped
Old May 1, 2004 | 02:58 AM
rotarygod's Avatar
Instead of putting everything back to stock, remember that you changed 2 things at once. It is hard to tell which one is really the culprit. I would replace one thing at a time to see what the effect will be.
Old May 1, 2004 | 03:41 AM
T-von's Avatar
The game changer!
Hmmmmm this bring back memories of past discussions. Sound familiar Rotorygod?
Old May 1, 2004 | 08:27 AM
MazdaManiac's Avatar
Listen to Rotarygod.
Pull the intake and try again.
Intakes on the RX-8 are worse than useless.
Old May 1, 2004 | 09:16 AM
Japan8's Avatar
Int'l Man of Mystery
I agree with MazdaManiac and rotarygod ...
Dropping backpressure from a full aftermarket exhaust is known to sometimes cause a drop in low-end torque in exchange for hp on the top-end. The mid-pipe frees things up more than a cat-back will on the 8. The same can be said of intakes on the RX-8...
Pull the intake and see how it rides.
Old May 1, 2004 | 10:51 AM
Japan8's Avatar
I actually suspected as much, but you get some pretty decent gains from the mid-pipe, so I hesitated to mention it directly.
Be sure to include a light-weight flywheel in your upgrades... recent reviews say that this has a lot of bang for the buck.
What are you doing driving at 1k-3k anyway...
Old May 3, 2004 | 01:49 AM
Xavier296's Avatar
Always tinkering
Also lost huge amounts of torque with a high flow cat and midpipe. Watched a stock RX8 fly away from me at 20 MPH in 2nd gear. And I thought my Borla and midpipe would make me king...
Old May 3, 2004 | 06:34 AM
Charles R. Hill's Avatar
Owner of BHR
What I tend to wonder is what we expect when upgrading the performance with aftermarket accesories. As was stated, there are several discussions around here re: the drivability aspects of certain mods. I have stated in almost every related post that there is a power loss below 4K but a major boost in all areas above that. In addition, with the full-length exhaust and intake setup, Jeup will see full gains above 7K. I will offer this much: my 8 accelerates from 70 to 145 mph MUCH quicker than before my mods were done and the low end loss helps it to hook up when drag racing. Power is of no use when it is wasted by heating the tires instead of moving the car. I picked up 1.3 seconds in the quarter mile with another car I once had by swapping the trans/converter combo. It felt slower off the line but that was deceptive.
Charles
Old May 3, 2004 | 08:23 AM
Lawerence's Avatar
Originally posted by JeupRX-8
Would adding a cat-back increase the torque, or make it even worse?
Troy J.
It shouldnt effect it much at all.
uZu
Dec 30, 2015 12:35 PM
PTQLam
Aug 16, 2015 05:40 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
yapakanichi
16
Jul 28, 2015 03:44 PM
