Why is radiator fan running?
Old Apr 26, 2004 | 09:58 PM
stardoag's Avatar
I just got my RX8 last week, is it normal for the cooling fan for the radiator to run for 15 minutes after you shut the car off? Anyone ever have the battery run down due to radiator fam running or getting stuck on?
--StarDoag
Old Apr 26, 2004 | 10:15 PM
snap-on's Avatar
https://www.rx8club.com/showthread.p...threadid=26671
Old Apr 30, 2004 | 11:59 AM
Charles R. Hill's Avatar
Owner of BHR
To turn the fan off turn the key to the "On" position and then to the "Off" position. This resets the fan cycle on the cooling circuit.
Charles
Old Apr 30, 2004 | 01:06 PM
snap-on's Avatar
Charles
Why would you do that?
Old Apr 30, 2004 | 09:40 PM
Killerking1964's Avatar
mine did that till I got the M reflash.
Old May 1, 2004 | 10:17 AM
snap-on's Avatar
The "M" flash does not address the "after cooling" circuit on the car.
Old May 3, 2004 | 06:17 AM
Owner of BHR
If one is concerned about their battery, they might wish to not have the fan running. Or, maybe, neighbors don't want to hear the noise at 4:00 a.m. when my car is parked right next to their bedroom window. The operating fan doesn't provide any additional cooling because the water pump is stationary while the engine is off. Heat soak is not as big a deal as some people think.
Charles
Old May 3, 2004 | 06:57 AM
snap-on's Avatar
I'm sure the after-cooling circuit was engineered into the car for a reason..
The air from the fans blowing across the block and PCM must surely prolong the life of the electronics.
Old May 3, 2004 | 07:09 AM
takahashi's Avatar
I will rather have a better COOLED engine than a run down battery. IT WILL NOT run if the engine is cool... get it
Old May 3, 2004 | 07:35 AM
Sea Ray's Avatar
Well, I guess they told you Snap on, you must think you are some kind of master tech or something ?
Old May 3, 2004 | 07:54 AM
snap-on's Avatar
I was actually trying to be polite..
I posted the parameters for the after cooling circuit in the tech forum.
Old May 9, 2004 | 12:09 AM
DiRX-8's Avatar
I've had my never-ending fan run when it's cold, hot, run for five min or 2 hrs. No rhyme or reason.
Old May 9, 2004 | 12:35 AM
greene76's Avatar
Mine also, I just turn key on/off, pain but simple.
Old Jul 22, 2004 | 07:31 PM
sazebac's Avatar
I'm also having this issue. I mentioned to the service guy when I brought my 8 in for the 7500 mile maint and he acted like he had never heard of that issue. I brought the car home and it is still doing the same thing. Fan stays on after I turn off the car. Once I waited about 6 minutes and still it was running. There is no way the small batt in that car can keep a fan blowing that fast for very long so I don't think this is normal.
My family used to have a volkswagon van that did this, and it was supposed to, but not sure if this is normal for the 8. Going to call my service guy again.
I know I can cut the fan off my turning on the batt with the key and the cutting the batt off again, but I don't want to have to do this all the time as it is annoying.
Old Jul 22, 2004 | 11:18 PM
epitrochoid's Avatar
Riot Controller
this car is self aware. the next generation will eventually overrun the human race and harness our bodies as a power source.
it's no accident that the fan is on. alot of older german cars do it too. mine only does it when its hot as ***** out and I run with the a/c on. never had a sluggish start or anything.
Old Jul 22, 2004 | 11:50 PM
shelleys_man_06's Avatar
Not anymore
Where's Keanu Reeves when you need him, dude?
Old Jul 23, 2004 | 12:04 AM
wakeech's Avatar
mostly harmless
woah!!
RX-Tuner
RX8Performance
196
Apr 16, 2023 02:19 AM
drebbrnator
Dec 27, 2018 07:02 PM
IamFodi
Series II Interior, Audio, and Electronics
28
Oct 31, 2018 06:37 AM
MANIACman
Nov 11, 2015 10:58 PM
Aston177
Sep 3, 2015 11:07 PM
