Rotor/caliper swap for AT car?
Old Apr 21, 2004 | 06:55 PM
pgtr's Avatar
Let's sayf or example a wrecked/totaled 6 spd Rx8...
Has anybody considered bolting on a 6spd front brake set to an AT car?
Are the spindles the same? Can you simply mount new rotors and calipers off a 6 spd on to an AT car?
What about caliper mounts? ABS calibrations?
Same bolt pattern?
thanks,
Old Apr 21, 2004 | 07:22 PM
zoom44's Avatar
on the base model they may be different but if you have at least a sport model low-power with the larger wheels than you have the same brakes as the hi-power folk.
Old Apr 23, 2004 | 02:32 PM
pgtr's Avatar
I'm talking about a base AT car.
If the bolt pattern is the same (I think it is) that least makes the hub/offsets 'potentially' same. If different bolt patter - it's a hub or spindle swap for sure.
IF hubs et al are same either way then the upgrade could in theory be a bolt on swap of rotors/calipers and caliper mounts.
Anybody know?
Also what about bias or ABS calibrations and speed sensors?
9krpmrx8
Nov 5, 2015 11:45 PM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
RX7.9
Jul 20, 2015 12:01 PM
shambo
Jul 18, 2015 02:07 PM
