<RX8> Oil Check, Engine IDLE, etc....
Old Apr 17, 2004 | 08:37 PM
R888's Avatar
WedsSport Member
Please kindly help!
I recently order a RX8 (titanium) with AT. Then I was so excited to be patient for 6 weeks for this baby to come. But since I heard this car has too many problems and some help is appreciated.
1. What is engine idle (means engine suddenly stopped? How to prevent it?)
2. Like some ppl said need to check engine oil after 2/3 times after gas station? (if its true, should I buy a couple of engine oil n put it in my trunk?)
3. Any other major problems?
Sorry I m newbies like a rookie in sports car buz previously I had a celica and it was prefect without any major poblems. Your help is greatly appreciated!
Old Apr 17, 2004 | 08:54 PM
fxdsconv2000's Avatar
You can't be serious. Just in case you are:
1. idle is when the engine is not doing anything except running, like when you are sitting at a stop light. I don't know what you've read but I don't know of any idle problems, just rough idle with an aftermarket intake system.
2. Yes the rotary motor burns oil, this is by design. It does not burn enough to warrant carrying a couple in the trunk. Just check it when you fill up with gas and fill it as needed.
3. NO
Old Apr 17, 2004 | 09:19 PM
SiMplyBluE's Avatar
Atlas shrugged......
Well, we know issues with flooding if its especially a manual transmission. Don't think thats an issue with automatics and the recent 'M' flash for the ECU should've fixed this issue but either ways its a good thing to run the engine for a while. Might want to think about protecting the oil cooler and radiator from debris on the roads. And enjoy the car!! I should have mine next week!! Woohoo!
Old Nov 7, 2009 | 01:47 AM
casanojoe's Avatar
i just found out the same thing the hard way. i was on the autobahn last night and my oil light comes on.... my 09 just has 1000 miles on it. wtf.... im going to do the first oil change to RP today
Old Nov 7, 2009 | 09:18 AM
deadphoenix52's Avatar
meh.
epic bumb.
Old Nov 7, 2009 | 09:22 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
^.....well the only way it could've been found was via a search right? At least he did that but......... "yes", that's an epic bump!
Old Nov 7, 2009 | 10:15 AM
iwc3707's Avatar
Didn't you read your owners manual or didn't the dealer tell you that the rotary has the oil injected to lube the rotors??
Old Nov 7, 2009 | 12:27 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
Seems way too early for the oil light to come on unless the oil wasn't full when you first got it.
Thread bumped.
Old Nov 7, 2009 | 09:47 PM
what does not add up.. autobahn, miles, royal purple..
just saying..
btw, would not the tech section not be a better place for this?
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
netrovers
Jul 20, 2015 03:32 AM
