19 X 8 with a 35mm offset
Old Apr 15, 2004 | 07:54 AM
dankgummy's Avatar
will these fit? The tires are 225 - 35 - 19.
Old Apr 15, 2004 | 08:30 AM
mdw33333's Avatar
Yes, they will fit, however, it wouldn't my choice of size.
Old Apr 15, 2004 | 08:51 AM
dankgummy's Avatar
mdw33333, what would you recommend?
Old Apr 15, 2004 | 09:37 AM
mdw33333's Avatar
Unless you're staggering, you should probably go with something that is at least +40. The 225/35/19 is too small IMO. Use a 245/35/19, because it is a very close match to the stock tire's height.
Old Apr 17, 2004 | 06:54 AM
Japan8's Avatar
Int'l Man of Mystery
225/40 19 is what Mazdaspeed uses on the A-spec MS RX-8. The stock (225/45 18) gives a diameter of 25.97in, and thesse tires would give you 26.08in. The only thing that your choices for tires may be slightly limited (as it is with the stock tire). BUT doing this... your speedometer changes less than 1mph.
Old Apr 17, 2004 | 06:58 AM
Japan8's Avatar
Diameter-wise 255/35 19's are even closer in size to stock, but I dunno about the width fitting on the 8...
hufflepuff
May 30, 2016 10:45 AM
Richard Paul
Aug 17, 2015 01:49 PM
R2D2X8
Aug 17, 2015 08:47 AM
