Replacing speaker wires?
Old Apr 14, 2004 | 06:02 PM
Tamas's Avatar
Registered Lunatic
Question Replacing speaker wires?
Has anyone replaced the stock speaker wires in the RX-8?
Along with adding an amp (to my base stereo), I want to replace the factory wiring since they will likely not be sufficient with an aftermarket amp and my new speakers.
I was wondering how big task this is. Obviously, running the new wires to the rear speakers is not an issue, but how about the ones that go to the door speakers? They have to go through those grommets etc...
If anyone did this and could tell about their experience (even better, provide photos), that'd be great.
Old May 18, 2004 | 10:42 PM
Napboy's Avatar
Sho'Nuff
bumpity bump... i'm starting my install tomorrow. anybody have info on wiring for the front door speakers and tweeters?
Old May 19, 2004 | 10:07 PM
colin204's Avatar
see here https://www.rx8club.com/showthread.p...threadid=25740
Old May 20, 2004 | 12:44 AM
Tamas's Avatar
Registered Lunatic
Well, I don't know about anybody else, but that did not make me any better off regarding what was asked...
Old May 20, 2004 | 03:32 AM
Napboy's Avatar
Sho'Nuff
i think he's hinting that you can take the doors off to get the wire through the harness.
i can't even figure out how to unclip the harness. i saw that someone got the passenger side done, but it wasn't too clear.
Old May 20, 2004 | 10:57 AM
Tamas's Avatar
Registered Lunatic
Take the doors off... yeah right.
If that's the way to do it, then I think my stock wires will stay in place. No way would I take the doors off and then suffer with getting them reattached and aligned properly.
There HAS to be another (and a lot easier) way...
Old May 20, 2004 | 11:24 PM
colin204's Avatar
Let me try to explain this better, the doors do not need to be removed. When Mazda did the wiring running into the door it was done with a plug so that in case of door damage the harness can be unplugged and the entire door removed. The installer that ran the wires into my door for me pulled back the loom, found some empty spots on the plug not being used, drilled out the hole just enough to fit a wire through the plug and into the door.
Hope this helps, does it make sense now?
rotarywanker
Dec 8, 2022 05:56 PM
MolecularConcept
Aug 1, 2015 03:15 PM
CMRine04
Jul 27, 2015 09:46 PM
Majictoast
Jul 18, 2015 06:45 PM
