Well smack my butt and call me Shirly
Old Apr 14, 2004 | 12:47 PM
flatso's Avatar
I'm Tantalizing
but I can not for the life of me understand why you need two trip odometers? Can anyone let me know if you use both and what for?
Old Apr 14, 2004 | 12:48 PM
guy321's Avatar
Humpin legs and takin nam
Re: Well smack my butt and call me Shirly
Umm...
Two trips?
Old Apr 14, 2004 | 12:51 PM
lilbigman's Avatar
Shirly
Meowloud's Avatar
Short Bus Allstar!
SMACK!! -"Shirly"
Old Apr 14, 2004 | 12:52 PM
StealthTL's Avatar
Metatron
Cool Tripster....
One for trips, like normal people,
and one to get actual numbers on "how crappy my gas mieage is" for this forum.:D :D
S
Old Apr 14, 2004 | 12:59 PM
zoom44's Avatar
When i took a road trip i reset a and b before we started. i left b run up until we got back home for total miles and i used a for the miles between fillups. less math i had to do myself that way
Old Apr 14, 2004 | 01:11 PM
poolsidenaz's Avatar
<WHAP> Shirly
Fillups on one (weekly for me)
Mileage tracking for road trips on another
Old Apr 14, 2004 | 01:16 PM
RX8-U-UP's Avatar
Total trip/Daily distance
Old Apr 14, 2004 | 01:18 PM
guy321's Avatar
Why do you always use the name Shirly, who's Shirly, this isnt the first time you referred to shirly, is shirly your wife, mother, sister, fantasy name or something, i reallly cant figure out why you keep using the name shirly, i was wondering if you could tell us why you like shirly so much, thanks!
Old Apr 14, 2004 | 01:27 PM
blue flash's Avatar
hey shirley zoom44 is correct .if you want to freak someone out turn your odometer to km instead of mph
Old Apr 14, 2004 | 01:32 PM
flatso's Avatar
I'm Tantalizing
Which trip are you on now?:D
Old Apr 14, 2004 | 01:44 PM
guy321's Avatar
Don't avoid the question!!
where were you next tuesday!
Old Apr 14, 2004 | 02:36 PM
Jercs02's Avatar
trips
For the ability to have more the one option silliy
Old Apr 14, 2004 | 03:02 PM
fxdsconv2000's Avatar
Same here.
Old Apr 14, 2004 | 03:32 PM
WinningBlue's Avatar
Shirley, you can't be serious!
I am. And don't call me Shirley!
Old Apr 14, 2004 | 03:43 PM
WHealy's Avatar
Mr. Blue Man
Isn't it obvious. Just so we can have this thread! :D
Old Apr 14, 2004 | 04:19 PM
Velocity-8's Avatar
Whuumpha!!
For me I use the "B" to track miles when I'm out on the road for work. Then I know exactly how many miles to expense.
As far as your smack goes, you'll get that on Sunday!!
Old Apr 14, 2004 | 04:58 PM
Razpewton's Avatar
FREE ADVICE!
I can't believe there are still those people who aren't versed in the intricate application of dual-odometric science. When properly administered, the dual-odometric configuration provides common-logic calculations, matched only by those of a slide rule.
Some simple applications are:
1) Tire pressure. Set "A" to zero with the wheel turned to the left, and "B" to zero with the wheel turned to the right. Make a trip to anywhere...work...grocery store, parole officer....anywhere. At the completion of your trip, inspect your dual-odometric readout. If "A" is greater than "B", you have low air pressure in a right-side tire. Adversely, if "B" is greater than "A", there is a left-side tire low. To determine front or back, reset both to zero and back up for 32 yards.
2) Weight distribution. Set both to zero, pick up your mother, and travel great distances. In Houston, if a variation exists beyond acceptable tolerances (±5 miles between the two for every 100 miles driven), then a) your weight ratios have exceeded 60-40% distribution, or b) you left your mother in Buloxi.
3) Romantical Encounter Enhancer. Set either to to zero...tell your date it's the gas gauge and turn the engine off.
Old Apr 14, 2004 | 05:05 PM
#3 LMAO
Old Apr 14, 2004 | 07:57 PM
SERIOUS REPY
i hit b and reset it as soon as the low fuel light goes on. helps me keep track.
Old Apr 14, 2004 | 08:57 PM
maxwell72764's Avatar
Go 'way kid. Ya botha me.
Shirley you jest!
Old Apr 14, 2004 | 09:06 PM
rboerio's Avatar
Question
:p Just dont worry about it....buy a YUGO.....you're made for each other! :p
Old Apr 14, 2004 | 11:01 PM
livitup's Avatar
Twisties for 1000, Alex
I leave A totally alone so that I can fulfil my ****-retentive requirement for the trip odometer to match the real odo exactly.
I use B to do the miles per tank math.
Seriously.
I do it on my bike too.
I need help.
Old Apr 15, 2004 | 01:14 AM
Sunni's Avatar
One to determine the gas mileage. The other to determine the oil mileage.
Old Apr 15, 2004 | 09:06 PM
adrien's Avatar
when I used to run my own business I could have used that.
One for the "regular" trips. One for trips that I could deduct -- like trips to client sites, etc.
Now I work for somebody else.
Oh well.
