View Full Version : help me ID broken damper parts? )pic attached
emailists
04-13-2004, 02:59 AM
My service writer will not just order the glovebox damper they broke without me leaving the car first.
Based on these pics, is it just the damper part FE01-64-08XB
I need?
thanks
http://www.edit-video.com/damp1.jpg
http://www.edit-video.com/damp2.jpg
emailists
04-14-2004, 02:22 AM
can anybody give me a clue?
thanks
tpryor
04-14-2004, 05:48 AM
Based on your picture, it looks like thats all you need. The attachment point appears to still be in good shape.
I took a GOOD look at this part in the airbag recall update, and the damper is VERY flimsy.
My technician says that no matter how careful you are, some of them break when removing, and they keep a stash of them around because it's so common.
emailists
04-14-2004, 07:17 AM
tpryor
thanks
bigcynic
02-28-2005, 06:28 PM
Does anyone know where you can order this part online?
Napboy
02-28-2005, 06:46 PM
this happened to me too when they did the airbag recall. there is a section in the tsb that mentions the damage done to the stay damper (page 8 of 12). the instructions are on there.
http://www.finishlineperformance.com/rx8/docs/airbag_recall.htm
Mr M
03-01-2005, 02:34 PM
The dampers are not easy to break, you are supposed to disconnect them first and not just rip the glove box out.
I learned that after breaking one, and only one. After that I have had no problems, monkey learns....If a garage is stupid enough to keep making the same mistake over and over again then they won't be receiving my service!!!
boothguy
03-01-2005, 02:56 PM
Can't see your pics, but the damper attaches to the side of the glovebox and appears to be just fine when it's loaded in the intended up-and-down direction, but breaks easily if not carefully disconnected from the side of the box when servicing.
