View Full Version : 2004 Mazda Rx-8 Bulb Code List
Preacher 04-11-2004, 03:35 PM This'll make it easier to upgrade bulbs!
2004 MAZDA RX-8 BULB CODE LIST
Headlights-Halogen High Beam-(2)-H9 OR #9005
Headlights-Halogen Low Beam (Non-Xenon-Equipped Cars)-(2) H7
Headlights-Xenon Low Beam-(2) D2S 35W
Halogen Foglights-(2)-H11
F/R Blinkers-(4)-7440
Brake/Tail-(2)-7443
Reverse bulbs-(2)-7440
Running Lights,Rear(two on each red corner)(4,total)-LEDs
Corner Markers,front-(2)-194
Map Lights,interior-(2)-194
Lower Door Lights-(2)-194
Parking Lights(small lights on front nearest Mazda logo)(2)-194
Lisc plate light-(1)-194
Best deals I found on bulbs is here:
http://autolumination.com
UPDATE, 05.17.2004----- NEW LISTINGS
SYLVANIA'S BULB CODE LIST FOR 2004 MAZDA RX-8 with HID LIGHTING (Non-HID is available at the link provided-)
(All are 100% road-legal bulbs in the USA)
Link:
http://www.sylvania.com/bin/carApp/carApp_ver2.pl?flag=model_quals&make=&make=MAZDA&year=&year=2004&model=RX-8+w%2FHID+H%2FL&x=18&y=10#2
**Yes,"2825" and "194" are the same bulbs.....some of these codes are sylvania spec'd,I believe,so mesh both lists....
Low beam headlamp
Part number = HID-D2S
High beam headlamp
Part number = H9-65W
Parking light
Part number = 2825
Tail light
Part number = 7443
Stop light
Part number = 7443
High mount stop light
Part number = 7440
Fog/Driving light
Part number = H11-55W
License plate
Part number = 2825
Back up light
Part number = 7440
Front sidemarker
Part number = 194
Upgrade Part Number = 194LL
Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
Part number = LED
Map light
Part number = 2825
Dome light
Part number = DE3175
Step/Courtesy light
Part number = 2825
Trunk/Cargo area
Part number = 2825
Preacher 04-11-2004, 08:22 PM That's alla' them.
Preacher 04-11-2004, 11:27 PM I just ordered 194 6-LEDs for the parking lights,single LEDs for the doors,and a pair of 9-LEDs for the reverse lights,all in superWhite.....
Next,when I get back from Europe,I'll do the fogs and halogen highs.....
mdw33333 04-12-2004, 12:00 PM Originally posted by Preacher
What brand of 194 LED bulbs did you order, and from whom?
Thanks for any info.
Preacher 04-12-2004, 12:45 PM The link above is where I get my bulbs.
They are bought in bulk,am not sure what brand they all
are,but they're most def 1st quality lighting with quick shipping.
autoillumination.com
Thanks for the sticky,Omi,imo it's good info to have,I wish I'd had this BEFORE I started my re-lighting project!
AcuraEL 04-15-2004, 12:49 AM You mention the highbeams can use either H9 OR 9005.
Are they the same, or some modifications are necessary to use one or the other.
I see much more availability of 9005 compared to H9.
Which 9005 version will fit the socket, I see on Sylvania's website, there are 9005, 9005 CB, LL, ST, XS, XSCB and XSLL!!!
If H9 and 9005 are the same, why the different codes?
Thanks for any help.
Preacher 04-15-2004, 01:04 AM H9's a code you'll find on JDM hyperwhites and import "super-bulbs",9005's a number you'll see domestically.
As to "9005 XXXX" I don't know,it's likely application codes.
Check with your dealership to ascertain,and post what you find,here,please.
hottrx8chic 04-30-2004, 10:26 PM great site..........thanks alot.....saved lots of searching!
Preacher 05-03-2004, 10:37 PM :)
Chief 05-05-2004, 03:19 PM Great Thanks!!!!!
Any idea why this info is not in the Owner's Manual correctly? (i.e. it says WY21W for the blinker bulbs in the manual)
Omicron 05-09-2004, 02:54 AM Cause the car is made in Japan, and marketed worldwide, and we're just looking for US sizes.
HiTMaNN 05-11-2004, 03:53 AM ok in confused i just bought the 194s and i want the blinkers too what is the difference between the chrome and the xenon version at the bottom of http://autolumination.com/7443_7440.htm
SiMplyBluE 05-11-2004, 07:55 AM Originally posted by HiTMaNN
Well from what I can see you can get the Chrome (stealth) blink either amber or super white. The Xenon (blue) will obviously be super white when it blinks. If you want the stealth look you should go for the Chrome. What color it should blink is you're choice. Of course by law I think you should get the Chrome Amber.
Spin9k 05-11-2004, 08:15 AM From the multiple threads I've read, and the problems some have had it (also the 8's manual), it seems the orange turn signal bulbs are NOT 7440 but WY21W. AND they ARE NOT IDENTICAL :( !
Apparently the 7440 sort of fit, or not, maybe with shaving some bit off the bottom if plastic, or extra force if glass. Some say the 7440s don't fit correctly, or don't work reliably. :confused: Still some seem to be using them (perhaps all 7440 are not created equal or identical??). What's up with this??
Maybe the list should reflect this for the unweary DIYer?
Preacher 05-11-2004, 10:31 AM 7440 stealth bulbs fit perfectly in my 2004 RX-8's blinkers.
Doctorr 05-11-2004, 12:53 PM Preacher, you have the rear running lights down as '194's, aren't they the built-in LED markers?
I've also been looking all over town for those H9 hi beams, now I hear they are also known as 9005s.....DOH!
doc
Preacher 05-11-2004, 01:14 PM Rear runners ARE LEDs.....oops! :D
Yeah,9005's are easy to find....H9's (the code) is usually associated w Pia-type bulbs and the other overpriced "off-road only" too-high-wattage replacements that'll fry your harness.
Imo Sylvania 'true-blues' in the appropriate wattage,w a bluer spectrum,is a fine replacement for the yellowed stock bulbs....
whosyourbaba 05-11-2004, 03:11 PM 7440 from autolumination fits in mine. Just have to push harder, but they fit.
RX-Hawk 05-25-2004, 12:22 PM Originally posted by Spin9k
They are 7440s. I bought some stealth bulbs, probably from the same place as you, they were pretty cheap but I needed to shave them a bit to fit. If we had gotten 7440s from a different maker then they would had fit perfectly. Another site that sells the stealth 7440s boasted that the chrome was better and you wouldn't have to shave the bulbs, but it cost 5x as much.
I also bought some 4 LED hyper whites for the parking lights, however I wasn't able to get to the right parking light near the ECU. The ECU box just blocks my hand too much I couldnt get my fingers in there deep enough. I tried getting in from the wheel well when I did my clear sidemarkers, but it was too far away. The left side was easy I changed the bulb to the hyper white and really liked the look, but I put the old bulb back in since I couldnt change out the right one. :( I suppose I could of removed the ECU cover but it has wires tied down on it and if I cut those loose I need to get some tie wraps to fasten them back down after I am done. I think I am going to get either 6 or 9 LED hyper whites anyway the 4 LED just didn't seem bright enough.
GSXRSTAR 06-03-2004, 04:44 PM I have the non HID headlight. Can you replace the belb behind the cristal ball looking light? (that run when you have your parking lights on) They are an aweful off white and compaired to the low beams look like crap. Thanks for your help in advance...Matt
Preacher 06-03-2004, 04:51 PM GSXRS,
Yes,you can replace those lights,they're a bitch,I had the dealer install a set of 6-LED SuperBlues,and now they're the same color as the HIDs when they're lit.
(A VAST improvement!)
I need to do the H9/9005 Fogs and my hi-beams shortly,then I'm
on a break,I've dropped about $5K on 'mods....time to think/Jamaica,instead.... :D
Just a word of warning on the 9005s for highbeams... I ordered a whole bunch of bulbs from autolumination.com (fantastic service and prices btw) but the 9005s were the right size for the socket/plug type thingie, but the pins were not the same inside, they were wider apart than the H9s it ships with, so they just wouldn't go.
Also, the reverse lights, very very dim, I actually ended up putting the stockers back in, figured I could get away with dim indicators, but can just see myself explaining to my insurance company why someone ran into me while I was reversing...
rx8spiritR 06-12-2004, 11:07 PM i just waste $70 on a pair of fucking 9005 that doesn't fit my fucking high beam. it's from RAZO and it's 110W it said it's a 9005 but it's also a HB3?????????i'm fucked now! anyone here want it? i'll go 50 free shipping.
rx8spiritR 06-12-2004, 11:08 PM the reason y it don't fit is the socket, it's totally 2 different socket. but i think the bulb are the same.
Boozehound 07-26-2004, 02:40 PM Any idea on what the bulb size is for the ashtray light?
takahashi 07-26-2004, 07:43 PM Someone said ashtray light is a 194... I wonder how are you going to take it out ;). You have to take the whole face out I suppose.
Hey talking about the blinkers... does anyone have 7440 LED blinker and make it work or need a converter or somesort from autolumination.com? Or is it a good look at all? You can get an amber LED which is white/clear when it is unlead
Taka
Boozehound 07-26-2004, 10:19 PM I'm already way too familiar with removing the ashtray light. You have to pull the console trim panel (around the gear shift), unplug the electronics attached to it, unscrew the two screws holding the ashtray module in, pull forward, and to remove the socket reach in around the bulb (nice and tight), squeeze the tabs and pull it out from the back side. Then all you have to do is yank the bulb from the socket.
Thanks for the info, Taka!
Mr. Ed's rx-8 08-21-2004, 04:07 PM hey preacher where did you find your 6-LED super blues for the parking lights??? autoillumination.com doesn't give that color as an option.
thanks for any help!
markris77 08-22-2004, 06:59 PM Checking the site I didn't see H11's to replace my Fog Lites. I got everything else I want loaded in my shopping cart, but REALLY want to replace the fogs. ???
Mr. Ed's rx-8 08-31-2004, 01:51 AM whats the easiest way you all have found to replace the parking lights closest to the Mazda symbol in the front??? its looking like quite the challenge.
Mr. Ed's rx-8 08-31-2004, 03:35 AM ok...almost 3 hours later i have finally changed out all my bulbs with the LEDs. about 2 1/2 hours was spent on the running lights next to the Mazda symbol. but they all look really clean and i am glad to have them.
now my only problem is that my turn signals blink twice as fast...does anyone know how to fix this???
takahashi 08-31-2004, 08:16 AM whats the easiest way you all have found to replace the parking lights closest to the Mazda symbol in the front??? its looking like quite the challenge.
The easiest way for the parking light is to approach from under the bonnet.
The ECU cover has to be taken out on the left hand side - this is done by taking the 3 10mm bolts up (don't drop them), you need to take the battery cover in the process;
the right hand side is relatively striaght forward;
spot the white tube sticking to the tunnel, it is in the shape as the rocket ;)
replace the W5W/194
When you put it back, it is handy to light them up and see the lights lighting up in the tunnel - use that to guide you in rather than doing it blind (or dim in this case ;))
takahashi 08-31-2004, 08:22 AM ok...almost 3 hours later i have finally changed out all my bulbs with the LEDs. about 2 1/2 hours was spent on the running lights next to the Mazda symbol. but they all look really clean and i am glad to have them.
May need a resistor for it. I 've never done it and don't know how to do, only heard of it is the solution and it is available in autolumination.com
markris77 08-31-2004, 05:48 PM anybody still awake on this thread? answers?
([EDIT] sorry...the other posts hadn't come up yet. weird! glad to see everybody a live and kicking!!!
:D
BlueAngel 09-05-2004, 02:06 AM is the 194 side marker bulbs comes in amber???
it will save me alot of time,
thanx
robertdot 09-05-2004, 02:57 AM The stock sidemarker bulb is WHITE. You can get an aftermarket amber 194 from autolumination.com.
Just to clarify the #9005 = H9 bulb issue... according to this page http://faq.auto.light.tripod.com/hl-filament-bulbs.htm they are not the same thing, a #9005 is actually the same as a HB3...
What are the lumens of all the halogen and HID bulbs?
According to the Bosch/SAE Automotive Handbook (4th Ed.) the following is a list of bulbs, wattage and output at 12V:
Bulb_typ, Wattage(W), Luminous_flux(lm):
H1 55 1550
H2 55 1800
H3 55 1450
H4* 60/55 1650/1000
H7** 55 1500
H8*** 35 700
H9*** 65 1870
H11*** 55 1200
HB1(=9004) 65/45 1200/700
HB4(=9006) 55 1100
HB3(=9005) 60 1900
HB5*(=9007) 65/55 1350/1000
markris77 09-07-2004, 05:28 AM I found a store that sells the H11, Fog Lite bulb. It's the cheapest I could find that PIAA bulb online. Haven't ordered it yet, but when I do I'll let you know how it looks/works.
https://www.optionsauto.com/index.htm?stocknumber=PIA-H318
takahashi 09-07-2004, 08:51 AM eBay sells $70US too but shipping from Hong Kong will be a touch more expensive.
Landon_Starr 09-10-2004, 03:44 PM H11 bulbs. $16.99....?
Bulbs (http://cgi.ebay.com/ebaymotors/ws/ebayisapi.dll?viewitem&category=36476&item=7920630706&rd=1)
markris77 09-10-2004, 06:03 PM page cannot be found?
takahashi 09-10-2004, 08:14 PM He meant this one... http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7920630706
They are called XD5 and can be purchased in globalpremier.com
I have ordered from them and currently have them on in the headlight and the fog light. They are as bright as the stock one (I am not claiming it is brighter) but it is the exact (at least with my eyes) same colour with the xenon. So for this look I am very happy with it. Cheap too.
Durability? I burnt one after 3 months. BUt I guess I touched the glass on the process of installation so I guess the oil caused increase heat the blew the bulb. If it blows again, I will let you know. I am sure they are not as durable as the PIAAs.
Cheap mod for the colour that I want.
Landon_Starr 09-13-2004, 11:58 AM Thanks for reposting link, Taka.
--Landon
takahashi 09-13-2004, 07:07 PM You are welcome. I think they are good product. They have no label saying where it is made from but I bet my bottom dollar that it is from Taiwan.
markris77 09-18-2004, 02:03 AM So I got all my lites in today and installed...
I didn't realize the bulbs for the side markers and the blinkers were differet...rereading i see the info was right in front of me...so now i have some spares. If you have the clear corner lenses, the stealth bulb/amber is the way to go.
The 9005's are wrong...as stated earlier they're the wrong pin pattern.
I put in superwhite LEDs for my parking lights, instead of ugly dirt brown, they now compliment my HIDS, it looks nice.
Inside, I replaced my dome and door lights with Red LEDs. I was going to go yellow to match the car, but with the whole radio and instrument cluster being red I figured I'd match. And it gives a nice 'camera backroom' glow...bright to see, but not bright?
And finally I replaced my map lights with Inverted Lens LED...not as bright as stock, but it looks nice.
http://autolumination.com/equalizers.htm - i just saw this, may be a fix to the blinker problem somebody said they had.
Overall, very happy with the site and more importantly, the bulbs. Install was a snap, 30min max, and it looks a lot better than stock.
I ordered two sets of those H11's talked about earlier, but not installed yet...my fog lites don't come on, so i need to let Mazda fix it, then they'll go on.
takahashi 09-18-2004, 02:24 AM I ordered two sets of those H11's talked about earlier, but not installed yet...my fog lites don't come on, so i need to let Mazda fix it, then they'll go on.
All you need is a long hand. Very easy to do if you know how to do it. Take ALL the clippers of the front mud guard in front of the wheel. Oh yeah, turn the wheel outside to have easier access. It is located next to your oil cooler. Reach it and unclip the connector and they can be taken out antin clockwise. To install, easier to get someone to see if it is aiming right *(or you can look yourself if you have a very long neck ;)). I have to admit putting it in is much harder. If you can take the wheel off it is much easier. Make sure you don't touch the bulb - otherwise it will blow in 2 weeks.
Therefore, I rather do it myself rather than a junior garage boy at the dealer who will stuff up the bulb by getting his oily hand on it.
markris77 09-18-2004, 11:36 AM I didn't think about doing it from the wheel well. Thanks, because since I installed my RB Oil Cooler screens, I figured I'd have to pull the bumper again. Hopefully I have long enough arms. But I still need to wait for Mazda to fix whatever is wrong with my fog lites, neither of them turn on. Thanks again! --Mark
markris77 09-18-2004, 12:36 PM Ok, so looking around on the internet nobody offers a H9 bulb. I'm begining to think there isn't even a H9 bulb in existence. All the sites have H1, 3, 4, 7 and 11...but there's no H9's to be found. Can anybody clear this up for me?
Its not too big of a concern because its not like you drive with High Beams on regular, and I wanted to replace some of the bulbs (parking, and fog) because the they looked like shit, not because they weren't bright enough. But I'm sure some of you want to change it out because...well to just change it out. Just trying to get this nice list more accurate. --Mark
Preacher 09-25-2004, 08:39 AM Pia sells H9 bulbs.
Search 'H9' bulbs on EBay or Google,or go to a sppedshop near you.
H9's are definately available.
markris77 09-25-2004, 10:19 AM Found it...i dunno why I didn't think about doing that...i'm dumb, heh. Now, can we find a place that sells ALL of our bulbs LEDs. Kinda dumb having to order in from two or three different places. I guess it won't be a big deal after getting the first set in the car since hopefully we won't have to replace bulbs for awhile. But would still be nice to go to one site...anybody found one?
Tamas 10-18-2004, 02:51 PM Hey folks, for the rear brake/tail lights (7443) and high-mount stop light, do we need RED bulbs?
I want to replace those with 15-led wedge type bulbs, and wonder if they should be red or white... I suppose red, just wanted to confirm (I don't have the car here to check).
devoid 10-18-2004, 02:58 PM ^ white (no need for red, b/c all have red plastic covers)
Tamas 10-18-2004, 03:01 PM So the hyper-white LED's would be the way to go? I mean, they won't be too bright white for the plastic covers? I definitely don't want some pink light :eek:
takahashi 10-18-2004, 08:19 PM I use red not white.... red is much brighter than stock and it is only about 30% less bright than white - according to autolumination's spec chart
Devoid have you actually have white ones in your car :D
I just scare if it is white and turn out funny then it is waste of money.
BTW: devoid, my bro, I use your money to buy more goodies for the site. :)
KYRX8 11-04-2004, 05:10 PM ive searched for the answer to this...to no avail.... how do you get to the turn signals in the front. I havent spent that much time looking at it but it looks like a pain in the butt
markris77 11-04-2004, 07:49 PM Its pretty easy. Just go through the wheel wells. Cut the wheel, take off the cover with a phillips screw driver, pop out the retainers, peel back and dig in. If you have big hands or arms, get a scrawny little kid to dig in there...not that i did that or anything. its most of a feel thing since u can't see well in there. but when putting in the new bulb u can reach around the front and peep thru the empty hole for alignment. i have a yellow 8 and the stealth bulbs look sweet!
KYRX8 11-05-2004, 08:04 AM cool, ill get my little brother to help me with it them, thanks for the advice. BTW, what do the stealth bulbs look like, im replacing mine with PIAA
truemagellen 11-05-2004, 08:29 AM cool, ill get my little brother to help me with it them, thanks for the advice. BTW, what do the stealth bulbs look like, im replacing mine with PIAA
stealth bulbs are crummy, not bright enough...get some LEDs :)
KYRX8 11-05-2004, 08:32 AM any pics of the led's around here? I got the piaas for free so ill throw those in but im not opposed to buying the leds if they are that much better
truemagellen 11-05-2004, 09:06 AM look at my avatar, but I have more pics I can post later
markris77 11-05-2004, 12:09 PM what are you talking about not bright enough? the stealth bulbs i got are just as bright as my stock...besides, they're turning lights, how bright do they need to be? and if u'r going to get clear corner lenses, its pointless to still have an amber bulb that u can kinda see.
answer the above question...stealth bulbs are chrome covered bulbs, but they blink amber. they come in other colors to, but most applications are for the turning lights and the clear corner parking lights. i got the ones from the site at the begining of this thread. u really have to push them to get them in though, at first i didn't think they fit. but then i stopped being a p#ssy and pushed harder, like think u'r gonna break it hard, but they fit great and are plenty bright. if i get a chance this weekend i'll take a pic of it, day and nite. --Mark
army_rx8 11-30-2004, 09:42 PM well just ordered my fog lights (h11 55w) and parking lights (194) so i hope they fit...but if not is was a good price.
baeckebd 04-26-2005, 10:07 PM thanks for the bulb chart, i've been looking all over for one.
baeckebd 04-26-2005, 10:09 PM i just ordered $60 worth of bulbs, i hope you are getting some referal credits.
ToguePirate787 05-26-2005, 04:18 AM I need help with Vanity Mirror lights, i cant seem to find any replacment for them. I mean, aftermarket led replacements. I want white led to replace them. PLEASE HELP me!! lol
Preacher 05-29-2005, 07:45 PM This'll make it easier to upgrade bulbs!
Brake/Tail-(2)-7443
Link:
Low beam headlamp
High beam headlamp
Parking light
Part number = 2825
Tail light
Part number = 7443
Stop light
Part number = 7443
Part number = 7440
Fog/Driving light
License plate
Part number = 2825
Back up light
Part number = 7440
Front sidemarker
Part number = 194
Rear sidemarker
Part number = LED
Map light
Part number = 2825
Dome light
Step/Courtesy light
Part number = 2825
Trunk/Cargo area
Part number = 2825
There ya go,links are right handy.
Autoillumination is KICKASS,they back everything they sell and I reccy' them highly.
(I do not have ANY interest,financial or otherwise,in autoillumination,they've just been very good to me,is all!)
El Kabong 05-30-2005, 10:59 PM Anyone have the 12- or 15-LED 7440's as backup lights? Are they a lot brighter than the stock ones? I want backup lights that are as bright as possible, but I'm afraid that halogen ones might be too hot.
takahashi 05-30-2005, 11:36 PM I need help with Vanity Mirror lights, i cant seem to find any replacment for them. I mean, aftermarket led replacements. I want white led to replace them. PLEASE HELP me!! lol
That makes 2 of us :)
I have the brake/tail lights in 15 LED red and they are VERY VERY bright already. The white one are 30% brighter! So it will be good enough for you... it will certainly light up the pathway when you are reversing in the dark :D
GO for the 15LED. The side LEDs will make the light more confluent around the reflectors :cool: I will do that sometimes too!
Argento Otto 05-30-2005, 11:49 PM Autolumination (http://autolumination.com/equalizers.htm) lists three types of load equalizers.
They are all classified as addressing turn signal problems, but I don't know what resistance (ohm) rating is required for each type of light (backup vs. brake vs. signal, etc)
Anyone using these equalizers and can clue me in?
Thanks for the help!
takahashi 05-30-2005, 11:55 PM I emailed them earlier...
They said, you choose different equalizer depends on if you are installing 2 or 4 LEDS.
If my memory serves me correctly (*hang on the page says it), 6 ohms if you do front 2 or rear 2 turning signals. 3 ohms if all four together.
Backup and brake DOES not need equalizers as they are not blinking type.
If you don't have the equalizer the blinks will go crazy on you. That is all. It will still work.
Argento Otto 06-07-2005, 12:45 AM Installed all turn signal (with two 3-ohm equalizers), brake and reverse LEDs.
All in all, the car looks pretty sharp. No annoying colored bulbs, plus the rapid on-off of LED looks nice, too.
I must say, though, that more LEDs are needed to make the turn signals visible, especially during daylight hours. The entire enclosure should be LEDs to provide safe indication of a lane change, etc. (like how newer BMWs have, for example).
Hopefully someone will develop an OEM-style taillight LED cluster... until then, these will suffice.
RX-8 Sake Sipper 08-16-2005, 11:08 AM I built my rear rotary brake light but the bulb is just not as bright as I want(dimmer than the stock rear brake lights). Any suggestions as to making this brake light brighter?
truemagellen 08-16-2005, 12:11 PM show us pics of your rotary light setup and so we can get a better idea
SecrtSqurl 10-05-2005, 12:31 AM Cool site!.. I got my bulbs from Mazdatrix.com.. 36.00 a pair. You can find them cheaper, but the service of these guys is really good.
echoj8 10-17-2005, 12:41 PM Anyone tell me what size the bulbs are located on the door above the switches?
anthonyrx82005 02-12-2006, 11:01 AM im looking for clear front side markers can anyone help me
Argento Otto 02-13-2006, 06:24 PM im looking for clear front side markers can anyone help me
Search for "clear corners".
greasy8 04-14-2006, 12:33 AM Dunno if anyone is still reading this thread, but here goes...
I replaced my running lights (the rocket-shaped ones in the front headlights) with super white, 5-LED, "Matrix" bulbs from autolumination. I did this because the stock looks really yellow next to my HIDs.
I realize now that the matrix was the wrong choice (i don't need a wide light spread for this use), but the other problem is that the color is off! The bulbs actually look sorta greenish compared to the xenon headlights. Anyone else run into this? Are some super-white LEDs closer to the xenon color than others? Would an incandescant super white bulb look better?
RX4life 04-14-2006, 01:28 AM i git the refractor LEDs..they are white with a hint of blue.. i just cant seem to find super white lights.
crisis 05-05-2006, 04:25 PM I got the xenon 194 regular bulbs, not LEDs and put them in the entire interior. This weekend I'm going to try them in the parking lights. I'll let you know how they look.
For some reason my front turn signal bulb will not come loose. I spent at least 30 minutes with my arm up the wheel well, but i can't get the bulb to budge. And suggestions?
SecrtSqurl 06-09-2006, 12:29 AM I repalced my fog lights with the H11 xenon bulbs from the autolumination web site. They were the priciest bulbs that were supposed to be "white" . They were more for show than illumination, and I was hoping they would be the color of the Xenon headlamps, or a "bluer" look like on BMW's.
The lights put out really awesome white light, but from the front still look yellow. I also have had to replace two of them since I got them. Is there a better quality bulb out there in the H11 style. PIAA, etc..... Or is the only coures of action replacing the whole unit?
I doubt that anybody would read this, but I've used 6 LED 194 in the stealth bulb spot, and the damn things won't stop burning out!! LED's? I thought these things would last for longer than 1 month! Other than the heat being and issue, I'm stumped...
SecrtSqurl 06-20-2006, 01:27 AM Out of curiosity, which bulbs are you replacing with the LED's? I am a bit confused by "stealth bulbs".
Argento Otto 06-20-2006, 01:45 AM I doubt that anybody would read this, but I've used 6 LED 194 in the stealth bulb spot, and the damn things won't stop burning out!! LED's? I thought these things would last for longer than 1 month! Other than the heat being and issue, I'm stumped...
Hmmm... dunno. I've got all blubs replaced with LEDs and haven't had one fail yet. I don't drive all that often so maybe I'm different.
I was wondering though, do you have a stereo or amp hooked up? Maybe it's causing fluctuations in the electrical current or something (?)
Fearsomefatman 09-01-2006, 02:16 AM the lights closer to the middle at the front, they are fugly compared to the beautiful HIDS, what kind are those I only saw one post on those and all it says is that they were a bitch to replace, the bulb code list did not tell me, I know the high beams are just 9005's but this yellowish crap lights that come on when you turn on parking lights? wish I could change those.... oops, 194 eh? I wonder if sylvania makes a bright set of this... hmmm
Chamberlin 09-01-2006, 12:21 PM I've been looking for the definitive solution to that problem too... Gosh I hate those nite-light globes!!!! Useless *and* ugly!!!!
In the words of Archie Bell and the Drells, its time to "whiten-up" and get something closer to those HIDs!!!
-C
TopTrainer 09-09-2006, 06:55 PM How do the sylvania silver star bulbs compare to the bulbs from autolumination? Checker has the sylvania parking light bulbs 2825 for less than $3 each but I want to make sure they match the HIDs.??
RaceBannon 09-27-2006, 11:24 AM I found that the easiest way to change out the map lights is to use a spatula instead of a screw driver to pry the clips. This way you don't screw anything up. Even with a screwdriver wrapped in cloth, it can mess up the plastic and cloth with all the digging you have to do to hit the clips.
TitaniumRenesis 11-03-2006, 03:54 PM I dont know if this has been said yet in this thread but the reason people's LED's are burning out in the parking light position is because of the heat created inside the headlight housing. Do not use LED's in the headlight housing, all the heat drastically decreases the life of the LED.
4 years to Supercharge 11-09-2006, 06:08 AM I dont know if this has been said yet in this thread but the reason people's LED's are burning out in the parking light position is because of the heat created inside the headlight housing. Do not use LED's in the headlight housing, all the heat drastically decreases the life of the LED.
The turn signals should be fine then right since they are not on an extended period of time and a person uses the load equalizers to prevent over power to them?
Are you referring to the little 194 (168) bulb next to the high beams?
bikes2cars 11-10-2006, 07:31 PM If you guys go to autolumination's website and click FAQ's, there are alot of folks out there replacing their bulbs left & right. Something about the quality & the heat inside the housings. I went with LED brake lights, and incandecent Xenon Superwhites from MTEC everywhere else. Inside the clear corners, they match the low beams perfectly. I was hoping for a bit more blue, but am glad since blue is illegal in CA. and don't want to practice my "Oh, Really! I didn't know blue was illegal Officer?!" routine everytime I drive past a Krispy Kreme's or Starbucks.
The parking lights (missle loooking lights) heat up quick! Its right near the radiator and it's in a small space. LEDs tend to fail in that type of millieu. So, I put an MTEC in there and its good.
I want to do my interiors too, but am afraid to blind myself in the night time with a crazy bright light. So, I'm thinking a red or blue light that won't dialate my eyes everytime the come on.
I changed my reverse lights to the MTEC superwhites too, but in reality, the stocks are much brighter. I've 30% tint in the rear and wanted a bright reverse light. Do any of you guys have LED reverse lights? Are the brighter? I know LEDs are brighter than incandescent, but only in one direction, no>?
4 years to Supercharge 11-10-2006, 11:06 PM The white LEDs are definitely brighter, not sure how much less focus they have compared to the stock though I was just happy they had more output than the stock bulbs.
Critzman 11-23-2006, 12:56 PM What's the equivilant to the halogen fog & parking lights in a Xenon lamp? I don't like the look of 2 lamps being Xenon and the other 4 being halogen...
4 years to Supercharge 11-23-2006, 11:15 PM What's the equivilant to the halogen fog & parking lights in a Xenon lamp? I don't like the look of 2 lamps being Xenon and the other 4 being halogen...
I found the PIAA Xtreme Hyper White incandescent bulbs give a good match for the 194s and are brighter than most 194 in terms of Lumens output.
Color temp is good also.
swoope 12-03-2006, 12:36 AM very confused now.. just ordered 4 superwhite 194 4 led bulbs.
2 for puddlelamps and 2 for the parking lights. am i doomed???
wtf. 14 bucks down the drain... the horror..
beers :beer:
Critzman 12-08-2006, 09:00 AM I found the PIAA Xtreme Hyper White incandescent bulbs give a good match for the 194s and are brighter than most 194 in terms of Lumens output.
What websites have them?
-Brian
4 years to Supercharge 12-08-2006, 09:36 AM What websites have them?
-Brian
I picked mine off of eBay. Couldn't beat the price.
Search for Xtreme white 194.
The set I have are conventional bulbs non-LED. ;)
I'll take a few pictures tonight after it gets dark out and post them. :)
chr1s 01-02-2007, 07:28 PM is there a difference between 3175 and DE3175?
chr1s 01-03-2007, 11:16 AM well I just got an email back from velocity LED and there's no difference between 3175 and DE3175.
Mafia 02-20-2007, 01:50 PM i was just curious as to which bulb most of you perfer for a close to xenon look for the park lights. Of course fom http://autolumination.com.. i was interested in the 6 LED super white or UV but unsure as to how it would look. Also ive heard their bulbs are not very reliable is this true?
SecrtSqurl 02-20-2007, 05:53 PM I had bad luck replacing the fog lights with bubs from autoillumination. i had 3 fog lights burn out last year alone. Since switching to the Piaas, I havent had aproblem. it may be a coincidence, but it also may be a case of you get what you pay for
4 years to Supercharge 02-20-2007, 08:05 PM i was just curious as to which bulb most of you perfer for a close to xenon look for the park lights. Of course fom http://autolumination.com.. i was interested in the 6 LED super white or UV but unsure as to how it would look. Also ive heard their bulbs are not very reliable is this true?
Do a search for Velocity LED on eBay they hold up better than the autolumination bulbs. ;)
Mafia 02-21-2007, 11:34 PM thanks for the info guys, currently i use nokya super whites for my fogs with no problems as of yet. i was just curious on autolum cause i saw alot of member using their products
N rider89 02-22-2007, 01:00 AM autolum sucks kinda. ive been through way too many sets
salituro64 02-23-2007, 09:00 AM So where do you get good Hyper White bulbs?
boanjangnararmine 03-11-2007, 12:59 AM for the vanity mirror lights i found dome light bulbs that are 8mm wide and 28 mm long... i was wondering if this would fit.. apparently the stock bulb is 6mm x 30 mm... can the somewhat fatter and and shorter bulb be shoved in and work?
altspace 03-17-2007, 04:50 PM Would someone please remove 9005 high beam bulb from the first post since it does not fit.
Krasnog 03-19-2007, 06:36 PM I picked mine off of eBay. Couldn't beat the price.
Pics? =)
white311 10-20-2007, 05:25 PM I installed LED's on all of my rear bulbs including the high brake light.....NOW I am getting a ABS and Slippery Warning light only when I turn my lights on...Anybody know what the deal is???????????
Spinning Sushi 10-20-2007, 05:54 PM I installed LED's on all of my rear bulbs including the high brake light.....NOW I am getting a ABS and Slippery Warning light only when I turn my lights on...Anybody know what the deal is???????????
You probably need resistors on the bulbs.
white311 10-20-2007, 06:49 PM On all of them or just the turn signals?
white311 10-20-2007, 06:50 PM Do I need resistors on all of them or just the turn signals? Thanks in advance for the info!
white311 10-20-2007, 07:44 PM Problem solved....Returned the 3rd brake light bake to a standard bulb.....No more warnings.
Chamberlin 10-20-2007, 07:53 PM You need at least one resistor (or bulb) on at least one of the 3 rear lights.
You can put the LED back in the third brakelite, just go to Autozone and buy a ceramic resistor thing for LED lights and stick it on one of em.
Do a search on this, you will find other posts from me about this.
-C
p.s. and yes, you will need 4 resistors, one for each turn signal to make those work right.
Beeotch 11-14-2007, 08:12 PM i just bought sylvania h7 su (SilverStar ULTRA High Performance Halogen) they are for the larger lights in the headlight correct? the main lights. will they fit? if i had xenon headlights would these lights be brighter then the xenon? on autolumination.com which 194 bulbs and h11 bulbs shine the brightest in a superwhite/blue effect for my inner headlight lights an side markers and fog lights?
Beeotch 11-14-2007, 08:13 PM when i mean brightest i mean bright but not bright enough that i get pulled over.
nycgps 01-15-2008, 08:50 AM got 2 of the 194 HID White to try it out in my front parking light.
After about 2 months of use, 1 of them are about to die (keeps on flashing)
I got them from v-leds.com
hmm .... thinking to get PIAA. Cost 10 times the amount. but I guess you get what you paid for
moete87 01-27-2008, 03:17 PM What kind of LED's do you guys use in your clear corners? I have gone through 3 sets of LED's from RX8Strakes.com! I opened up my box to put in a new LED that was flickering in my right clear corner and the 1st bulb that I put in didnt even work, then the second bulb I used the color seems alittle off on the tiny LEDS that make up the bulb. :rant: :banghead:
So I need some help..
Where can I get the best quality LED bulbs for my clear corners? Price isnt an issue because I just spent $60 on LEDs that I have to change every month or two. :rant:
Please help, this shouldnt be happening! :icon_no2:
Can you guys post up some links to where I can quickly purchase the LED's..that would be great!
Jeff
BigRed 01-27-2008, 03:32 PM Vleds^ u can use 194s, or a bunch of different ones. i like the 194s though
BigRed 01-27-2008, 03:32 PM btw its vleds.com
takahashi 01-27-2008, 06:24 PM You need somesort of resistor for some LED bulbs. You just cannot put a 194 into the signalling bulbs straight on. Some LED has in built resistors and they are specific for the signal bulb and they will be fine then.
4 years to Supercharge 01-28-2008, 12:50 AM I really like the high power flank LED bulbs.
It makes the side marker signal mod work better for those folks that can't see you signalling from the side. ;)
Adding a resistor to each side should lengthen the life of your bulbs considerably.
Another thing that can make a difference is if you are not totally switched over to LED.
Rote8 03-02-2008, 08:16 PM Would someone please remove 9005 high beam bulb from the first post since it does not fit.
Is this correct?
I thought the 9005 and H9 bulbs worked in the high beams????????:uhh:
Update:
According to Daniel Sterns lighting page H9 does not equal 9005
Danielsternlighting.com (http://www.danielsternlighting.com/products/products.html)
4 years to Supercharge 03-02-2008, 09:12 PM H9 is the correct bulb for high beams.
CnnmnSchnpps 03-12-2008, 09:48 AM Shameless plug cos I think my lights look hot :lol2:
Aftermarket HIDs in H7, clear corners with:
1) Stock bulbs
2) Polarg Super-whites
3) Hoen LEDs
http://www.rx8club.com/attachment.php?attachmentid=116917&stc=1&d=1205297403
Sweet :)
YeahYeahYouWere 04-09-2008, 09:58 AM So I don't want to step on the toes of anyone who loves autolumination - especially being that this is my first post - but I found www.superbrightleds.com to be a good site too. Now if only I could find some cheap clear corner covers...
Also, I feel compelled to put my nerdiness to use here and point out that it is usually in your best interest to buy a light that matches the color of the cover - i.e. put red lights in your high brake, because the red cover will filter out certain wavelengths of light and yada yada yada sciency junk. Just know it will typically be brighter if you match color of bulb and cover. Obviously clear is an exception.
Thanks to everyone on the site for the great info so far!
4 years to Supercharge 04-09-2008, 01:33 PM Not a fan of all the extra mouse clicks I have to do in order to see the bulbs or the pricing though.
YeahYeahYouWere 04-10-2008, 08:39 AM Well, I ordered 6 bulbs from www.superbrightleds.com last night - I think I saved about $1 to $2.50 each as compared to autolumination. Of course, people here speak of great experiences with autolum, so I'll be sure to let everyone know how smoothly things go with sbl.
4 years to Supercharge 04-10-2008, 09:11 AM It seems like a long time ago that people thought autoluminations was a great place. I have heard otherwise since. :(
remixlp 04-27-2008, 03:52 AM I am confused as to what bulbs to get for the parking lights closest to the mazda logo. Can i use piaa xtreme white 194 bulbs?
anothercarguy09 05-05-2008, 01:52 AM is hte parking light the tiny small circular lights on the innermost part of our headlamps?
robel82 05-05-2008, 09:27 PM yes those are it. Anyone tried any type of UV on any of their cars?
kainis2k 08-13-2008, 11:54 PM you don't even realize how long I've been searching for this... thanks alot!!! :D
Series II (2009~) RX-8's use the same Globes as Series I.
ZumnRx8 06-13-2009, 07:55 AM subscribed
champi0n 06-19-2009, 06:49 PM So is it confirmed that 9005 does NOT work? I bought a 9005 because they didn't have H9's... whats the dilly?
tbonespeed12 06-24-2009, 09:14 PM how would you know if your car has HID's. from what i can see there are bulbs in all the lights. I wanna upgrade all the Headlights to HID's and LED's in the tails.
xun4gvn4everx 06-25-2009, 12:36 AM ^What model do you have? If you have fog lights, then you have HIDS.
tbonespeed12 06-26-2009, 01:36 PM i have a 04 8 with the 6-speed.
xun4gvn4everx 06-26-2009, 01:47 PM ^That is not your model. I mean GT, Touring, Sport. Check out this website, it may help:
http://www.gerhardstein.net/rx8/rx-8.html
Go to Corrected 2004 rx8 Brochure
tbonespeed12 06-28-2009, 07:40 PM ok i have the grand touring. so It does come with HID's.
but im confussed... is the low-beams the only ones with HID's or can i replace the high-beams, fog lights, and running lights with HID's also?
xun4gvn4everx 06-29-2009, 11:12 AM You can replace all of them with LED's or HID's. I would leave the high beams alone though, cause you don't use them all that much so it would be a waste of money and there are laws against what you can have for high beams
Darkpoison187 08-06-2009, 12:59 PM Ok I need a lil help I'm gettin ready to install OEM fog lights my question is since they make led bulbs for the fog light couldn't I use a pair for the low beams to? if I need to mod it I will ur help is appreciated
jessedrifter 08-31-2009, 01:26 AM i was looking at leds and they say the size is t10??
is that just another name for 194?
km1346 09-14-2009, 10:31 AM I have halogen capsules in my 04 rx8 I want a white look... And on autoliminations there is super white and diamond blue.. Which one would look better on silver with white parking lights and is 55 watt too low or should I go for 100 watts? Thanks guys
cheapman 11-09-2009, 08:41 PM Edit: never mind, found the answer to my question in a different thread
RaceBannon 11-13-2009, 05:28 AM I replaced all my lights with red. It was killer cool! My garage is red light also.
Nobody ever really answered the question earlier about the bulb code for the ashtray light. I've just pulled mine and it's definitely not a 194. The wedge is much smaller than a 194. I'm guessing that it might be a 24/74/NEO type, but at this point I'm unsure. I'll probably attempt to order one and verify... If anyone can confirm or deny this prior to me placing an order, I'd appreciate it. Thanks
OL!z RX8 03-17-2010, 09:03 PM got a question thats probably been answered but icant find the answer in here...can i use fog lights bulbs H11 55 watts or 100w? iknow that it says 55w on here but ucould choose on the autolumination site, i wanna go with 100w diamond blue because i suppose they're brighter...
Mr_delincuente 04-14-2010, 05:21 PM Is this for 2007 also?? I want some parkin LED for the back, and low beams.
akira_onboost 07-22-2010, 08:39 AM hey guys...
has anyone tried the 25 Led SMT Tower III in the 194 from www.autolumination.com for the park lights closest to the Mazda logo.
these should be quite bright i assume if they fit.
nickraft14 07-31-2010, 08:22 PM So h7's won't work?
takahashi 07-31-2010, 11:03 PM H7 is for non xenon low beam, H9 for high beam and h11 for fog lights
nickraft14 08-01-2010, 11:12 AM How do I know if I have xenon or whatever? I bought 2 h7's and there is no where to put them in the back of the headlight
Mazurfer 08-01-2010, 11:34 AM How do I know if I have xenon or whatever? I bought 2 h7's and there is no where to put them in the back of the headlight
Keep it to one thread Nick, go see your other one.
CarAndDriver 08-02-2010, 05:35 PM 20% off V-LEDs sale and code
Came across on a Chevy SSR forum:
V-LEDs 20% Sale & Discount Code
Hey VFAN!
It's Back!
We're bringing back our most popular sale ever!
It's the BFD Sale!
That's right, you spoke, we listened. Our "Big Frickin Deal" sale is back!
Starting this Monday, August 2nd until Wednesday August 4th you can use Coupon Code BFD and get 20% off our entire inventory!
Tell your friends, they won't want to miss this! This may be the last BFD sale you see!
*Sale starts Midnight Sunday 8/1/10 and runs until 11:59 PST Wednesday 8/4/10
http://www.ssrfanatic.com/forum/f22/...-20-off-47207/
Mazurfer 08-02-2010, 10:28 PM ^.......yeah, they E-mailed that to me!
Too bad I just spent about $140.00 about two weeks ago!
They always seem to do that to me! :cussing:
Guess I will have to buy some back-ups perhaps. :dunno:
JHanna555 11-27-2010, 02:09 PM Anyone who could help would be greatly appreciated. I have HIDS for my foglights but im also trying to get them for my headlights. Which one is better to get the low beam Headlights-Xenon Low Beam-(2) D2S 35W cuz i have xenon headlights or the high beam Headlights-Halogen High Beam-(2)-H9 OR #9005. Help plzzzz!!!!!! Just trying to get advice on what would look better.
Tomago 04-19-2011, 11:36 PM Here's the list for my 2008 Anni Edition. I'm sure it's not much different from the OP's list (if at all):
2008 MAZDA RX-8 (With HID headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
H9
Parking light
2825
2825ST
2825LL
Front turn signal
992 (7440A)
992/7440AL
Rear turn signal
992 (7440A)
992/7440AL
Tail light
7443
7443ST
7443LL
Stop light
7443
7443ST
7443LL
7440
7440ST
7440LL
Fog/Driving light
H11
H11SU
H11ST
H11XV
License plate
2825
2825ST
2825LL
Back up light
7440
7440ST
7440LL
Front sidemarker
194
194ST
194LL
Rear sidemarker
LED
Map light
2825
2825ST
2825LL
Dome light
DE3175
DE3175LL
Step/Courtesy light
2825
2825ST
2825LL
Trunk/Cargo area
2825
2825ST
2825LL
__________________________________________________ _
Installation of aftermarket LED light bulbs may produce electrical noise that may interfere with the operation of the Remote Keyless Entry System.
See...
http://www.rx8club.com/showpost.php?p=4024250&postcount=15
Globetrahter 11-14-2011, 11:13 AM What Color bulbs would be illegal to have as my parking lights? I don't want to get stopped by the cops because of my lights but I wanted to have a HID - ish yellow lights there as I'm planning on buying the HID Foglight kit as well.
Any suggestions?
AKuntze 11-29-2011, 01:02 AM Looking for a bit of advice. After reading through a LOT of these light threads, I am not sure what bulbs would look good to replace the ugly yellowish parking lights to make them white. I would like a bulb (not led) that would match the stock HIDs well. Any suggestions?
Globetrahter 12-02-2011, 03:58 PM So I have the HID Lights but whats the maximum brightness the stock lights can handle?
I guess I mean Can I go 6000K, 8000K, 12000K , etc without melting anything causing damage I dont have money for? like wires ect
6000K, 8000K, etc. do not refer to brightness, that is the color temperature. Think about what you may have learned in a science class about the color of stars and the temperature. the coolest stars are red (outside the spectrum of color temps in HID bulbs), warmer are yellow, warmer than that are white, and warmer than that are blue.
Globetrahter 12-03-2011, 10:42 PM I was getting temperatures mixed up with watts or wattages. So as long as I use the correct wattage I can use any color I want ?
Yes, that's correct. Personally, I've purchased 8000K D2S bulbs from vvme.com and they've been working great in my RX8 and my MS3.
Globetrahter 12-04-2011, 01:10 PM Yes, that's correct. Personally, I've purchased 8000K D2S bulbs from vvme.com and they've been working great in my RX8 and my MS3.
Thanks, Ill check out that site too. And Nice, you got an MS3 also, best of both worlds
Globetrahter 12-15-2011, 03:33 PM Quick Question, Im looking into getting some Hi Beam Bulbs but when I go to Vleds.com and go to H9 or 9005 all they wanna show me are HID Bulbs and kits.
I do have stock, HIDs already but the H9/9005 are just going to be a halogen bulb right?
StealthTL 12-15-2011, 04:30 PM You can't use LED bulbs for high beams (well you could, but it would be pathetic)
Halogens put out (lumens) in the 1000 - 1300 range,
upgrade to HID and you'll get 4000 - 5000,
a good LED bulb will emit, maybe 300.......
(I have HIDs hi's, but I'm also a maniac)
I know Audi is working on some LED beams, but they are years away, and you won't find these at VLEDs!
Globetrahter 12-15-2011, 04:50 PM You can't use LED bulbs for high beams (well you could, but it would be pathetic)
OH Yeah! NO, I totally no that! lol But I guess why the site was trying to get me to get HID's because it is a LED Site lol My bad
Globetrahter 01-05-2012, 10:38 AM So has anyone done hid hi beams? If so what kit did yall get and where did u place the ballasts?
