Pass firewall no drilling needed
Old Apr 10, 2004 | 10:42 PM
blueMT6's Avatar
Running an 8 gauge amp wire from battery to trunk. Found an oval cutout in firewall near seam with fender about a foot away from the washer fluid container. It is taped over but a wire pokes
right through it. That same wire will also poke into the foot well on the inside of the car once the floor mats and carpet is out of the way. No pictures but in my case the wire came out just above a metal bracket on the side that curves around to the front foot rest area. Note that this is a car with no options so maybe some
cars use that cutout already.
Old Apr 12, 2004 | 12:24 AM
emailists's Avatar
thanks for the info - I may be soon doing a remote radar laser unit and need to run wires- this wil come in handy.
Old Jun 2, 2004 | 12:58 PM
RX80wn3r's Avatar
ThankyouThankThankyou!
I used that one to route my radar detector wires. I completely missed that spot. Guess I can put the drill away now.
Old Jun 2, 2004 | 01:15 PM
moRotorMotor's Avatar
Rotary eXperimental-8
Thanks for the info. I am planning to install a sub in the trunk and it might come in handy, since I really don't want to do any drilling if possible.
Old Jun 2, 2004 | 01:38 PM
StealthTL's Avatar
Metatron
Cool No problem....
There is no secret to getting thru the firewall....
Since it is also made to accomodate right-hand drive models, there is a huge (3") rubber access, where the steering column would go. It is between the engine and the washer fluid bottle, and comes out behind the glovebox.
Both the heater tubes and the a/c pipes use it, and there is plenty of space left for wires......
S
xAgyex
Jun 3, 2026 03:47 PM
Jazzmeson
Aug 30, 2015 02:23 AM
Jazzmeson
Aug 2, 2015 09:49 PM
Jazzmeson
Jul 31, 2015 01:48 AM
Jazzmeson
Jul 31, 2015 01:47 AM
