Burning Rubber in Automatic
Old Apr 10, 2004 | 09:05 PM
Flawless's Avatar
Just wondering... is it possible to burn rubber in an automatic 8? I have tried numerous times and it just doesn't work. I've turned traction off by pushing the DSC button and then turning it FULLY off by holding the DSC button. Still nothing. I even tried in the rain and it won't work. Has anyone burned rubber in the auto 8 and if so can you give me some tips?
Old Apr 10, 2004 | 09:15 PM
RX8Lover's Avatar
Re: Burning Rubber in Automatic
Yep - sell it and buy a manual. :D
Old Apr 10, 2004 | 09:43 PM
therm8's Avatar
Bummed, but bring on OU!
Re: Re: Burning Rubber in Automatic
Typical reply , I'm actually surprised there's only one.
As for "burning rubber", it's not gonna happen in the auto (just not enough torgue). With DSC and TCS off I've gotten small amounts of wheelspin only by bringing the revs up to about 3K with the brake depressed. Perhaps with a high stall speed aftermarket torque converter you could. On a wet road however (even a dry one if driving hard enough) with no traction control you can hang the rearend out very easily.
It's good being back in a rwd car. Went fwd with my last one, and it's just not nearly as fun (and I never could get used to torque steer.
Old Apr 10, 2004 | 11:56 PM
B-Nez's Avatar
Re: Re: Re: Burning Rubber in Automatic
Man, I KNOW I don't have to tell you that the auto has a bit MORE torque than the MT...I know you meant something else. lol :p
Old Apr 11, 2004 | 12:28 AM
shams42's Avatar
Peak torque doesn't matter. The Renesis doesn't make much torque at low RPM. With the manual, you can rev up to a higher engine speed (where the torque is) before you drop the clutch. The tight factory torque converter of the auto just doesn't let the engine get far enough in its powerband.
Matt
Old Apr 11, 2004 | 12:34 AM
rotarygod's Avatar
The easiest way to "burn rubber" in the auto is to learn how to "properly" drive using the emergency brake!
Old Apr 11, 2004 | 12:35 AM
JeRKy 8 Owner's Avatar
Stuck in a love triangle
I lovehow these morons who dont own an automatic think they know so much about my car.
AnywayThere aretwo ways I have burned rubber in the automatic. Oneway is to be in neutral and rev to at least 4500 RPM and then quickly drop into drive. This is badfor the transmission but should almost always work.
The other wayIve done it is by doing a brake rev launch. This means holding your left foot on the brake pedal while your right footis on the accelerator. RPMs will probably get to about 2500 - 2750 RPM. Release your left foot and you are off. You can get a short chirp usingthis method and its not as damaging as the other way. It doesnt always work though.
Old Apr 11, 2004 | 12:43 AM
Flawless's Avatar
I think i may try this method as I don't want to do anything that could possibly harm the car.
Old Apr 11, 2004 | 12:57 AM
rotarygod's Avatar
I love how these morons who dont own an automatic think they know so much about my car.
I really hope I'm not one of the "morons" you are referring to!
I'm talking about using the e-brake from a stunt driving, spin the car around, sarcastic point of view. Not for power braking.
I do know alot about your car! :p
Old Apr 11, 2004 | 12:59 AM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
I second that, when Rotarygod says it's true.. it must be true. *bows to the almighty Rotarygod*
Old Apr 11, 2004 | 01:18 AM
rotarygod's Avatar
Hey now! Only I am allowed to be an arrogant *** about myself!!!
Old Apr 11, 2004 | 01:39 AM
magixpuma's Avatar
that sux u cant even get wheel spin in the rwd rx8 cuz i drive a buic rondevous fwd and i spin those tires of dead stops lik ehteres no tomorro
Old Apr 11, 2004 | 02:12 AM
rotarygod's Avatar
That's because weight transfers backwards off of the front wheels when you accelerate. This places far less weight load on your Buick Rendezvous' drive wheels which cause them to lose traction very easily. If it does not have a limited slip differential it makes matters even worse by supplying all of the power to the wheel with the least traction. Even my fwd 127 hp Civic EX can spin the front wheels easily. If it were rear wheel drive and had a limited slip, it would be a far different story.
Old Apr 11, 2004 | 02:29 AM
rotarygod you posted several seconds before me I did not evensee your post and I appologize for makingit look like you were included w/the group I was referring to. :o
flawless you can do the neutral rev method once or twice just dont get into a habit of it.
Old Apr 11, 2004 | 12:52 PM
beachdog's Avatar
Your car has very soft springs. You're not so much spinning the tires as wheel hopping them. I know, I always seem to get stuck with Rendezvous rental cars. How can you stand to drive that thing?
Old Apr 11, 2004 | 12:59 PM
wakeech's Avatar
mostly harmless
if you want to burn some rubber (ie, do a burnout), it's really quite simple (though not necessarily easy)... doing an RPM drop from neutral to drive is about as stupid as it gets... with your TCS and DSC systems off (of course), hold the brake, floor the gas with the transmission in manual mode (so you can keep it in first), and try to get a nice hard launch on the tyres. now the tricky bit is to try and dab the brakes ever so softly so you can stop the cars forward progress while the rear tyres aren't getting any grip (a little puddle of bleach in front of the rears would help immensely and give you an incredible smoke show), then to control the cars forward movement while you continue to try and peg the needle... if you press the brakes too hard you'll stop your wheels from spinngin. burning your tyres just takes a couple seconds of spinning, they'll overheat and smoke up somethin' awful after that.
Old Apr 11, 2004 | 01:23 PM
B-Nez's Avatar
Well, I hope I wasn't included with that group, as all I was trying to do was inject some pro-AT humor amidst a storm of MT-only negativity (not just in this thread).
Old Apr 11, 2004 | 03:18 PM
GiN's Avatar
GiN
ロンリードライバー
I've never driven an automatic RX-8 so I'm not sure what it really feels like. However, I've done some great burnouts with automatic Hondas and such. Put the car in neutral, rev to about 5000rpm, lift off the gas for a split second while you shift into driving gear, then immediately jam on the accelerator at full blast. You should be able to get some pretty wild wheelspin this way as opposed to just dumping into drive with your foot on the gas.
Old Apr 11, 2004 | 03:31 PM
magixpuma's Avatar
driving a rendevous is like driving every other land yacht but im not wheel hoppin im def spinning the tires and its fun and funny to see a land yacht burn out
Old Apr 11, 2004 | 03:38 PM
red_rx8_red_int's Avatar
Maybe I'm wrong but I do not think lifting off the gas for a split second will save your transmission from the large damage 5 K rpms would cause.
Old Apr 12, 2004 | 02:58 AM
sjt's Avatar
sjt
look MA! No PISTONS!!!!
another way to burn rubber would be donuts.
turn off TCS/DSC & throw it in the 1st gear of 'M' mode then accelerate moderatelywith a LOT of room around you then turn one direction slightly then quickly/abruptly turn it the opposite direction while getting on the gas hard.
Good luck, I accidently had this happen to me.
Old Apr 12, 2004 | 05:41 AM
cas2themoe's Avatar
PoloRican Rotary
I've never done a burnout from a standstill, its just not possbile in the auto. But what I have done thats just as sweet is turn the DSC off and make a U turn and put the pedal to the medal. I've down this several times and you will get a nice spin out of those back tires! Oh by the way put the car in Manual mode!
Old Apr 12, 2004 | 10:49 AM
NAVILESRX8's Avatar
FWD Hater
this thread is hilarious......good info here....
but one should never rev in nuetral and slam into drive....bad bad bad....
Old Apr 12, 2004 | 12:06 PM
stangmatt66's Avatar
North County Boi
Exactly what I was going to suggest. I love making tight u-turns in my auto and standing on the throttle. The wheels will always break loose into an easily controlled slide!! Just remember to turn off all traction control, DSC, blah blah blah...
I've tried brake-torquing with my RX and it doesn't work. The engine won't rev past about 2500rpm. The small amount of torque and HP generated at that point can't break loose the big tires the RX-8 has. I beleive peak torque isn't hit until 5k.
Old Apr 12, 2004 | 02:47 PM
Smoker's Avatar
RX-8: Hmmmmmmmmmmmmm.....
Keeping everything else equal, you are SUPPOSE to get more wheel spin from a FWD car than a RWD. As someone mentioned, this has to do with the transfer of weight from the Front of the car to the back. This is exactly the reason why performance are designed to be RWD.
Back to your question, For a quick launch, Hold the brake pedal nice and tight, rev the engine to 4K, release the brake very quickly and then floor the gas pedal.
For a tire burnout show, find a empty parking lot, put you car in reverse and get your self going like 2,3 mph backwards, don't touch the brakes, put it in neutral, rev the engine to 5K, put it to Drive quickly and then floor the gas. (hurts tires and transmission big time but you get a good show)
