Another Strake thread...
Old Apr 9, 2004 | 07:18 PM
Redfusion3's Avatar
Detroit Muscle
I read the DIY for the strakes...make plenty of sense seems easy but I ran into a problem when I was about to put them on. My front splash guard..its adhered already t the body do I heat it up and take it off and then heat it up again to put it on? I dont want to ruin anything but I didnt even think about my front splash guards.
Old Apr 9, 2004 | 09:27 PM
adrian-1's Avatar
Ex- member.
Are you talking about heating up the double sided tape? Sorry I don't have the splash guard, but I've got the strakes.
How many screws are holding it on? Is it 2 on the side and 1 underneath.
I don't think heating them up is neccesary. Remove the screws and gently pry it off. Take off as much as possible of the tape and replace with a new strip after the strakes are on. homedepot has some strong 3M ones.
Old Apr 9, 2004 | 10:32 PM
WHealy's Avatar
Mr. Blue Man
Have you tried removing as many fasteners as you can on the wheel well without removing the splash guard? You don't need much room to reach in there to pop the vent out.
Old Apr 9, 2004 | 11:39 PM
D MENAC 7's Avatar
Moderator with a mycocardium
That tape is sticky but...I think you should be able to pull it off with a bit of working it back and forth, it should just pop off. This will, of course, ruin the tape, but, you can buy the 3M trim tape at a lot of places to replace the tape that was originally on there. If you have the rear splashgards, you should have kept the extra clamps that came off of them so you have something to replace the ones you are going to have to pry off.
Old Apr 11, 2004 | 01:30 AM
Redfusion3's Avatar
Detroit Muscle
I guess...I'll try that stuff
wayloco
Sep 1, 2015 09:03 PM
Kahl
Aug 20, 2015 11:49 PM
cschoeps
Aug 6, 2015 12:44 PM
ColeParkerrr
Jul 23, 2015 10:50 AM
RX8-U-UP
Aug 9, 2003 10:11 PM
